I installed mine a few weeks back now - a 3 core, triple pass.
Before installing, the temp was on the red within about 15min of running.
With the desert cooler in, temp is about 1/4 gauge (80deg C) even after over an hour.... traffic doesn't evenh seem to effect it.
Granted, I've probably on done 100-150km with it in, but so far I'm impressed.
Only problem fitting was that the brackets don't come drilled (to allow you to install at your prefered height), and was slightly narrower than original radiator, meaning mounting holes were close to the edge, and there is no tabs on the side of the radiator to hold the overflow hose as per original... neither really a drama.
So so far, I'm a believer & a supporter!
