Which springs for dedicated LX 308 track car?
65 replies to this topic
#1 _Hazza_
_Hazza_
Posted 11 April 2007 - 03:33 PM
Hi guys.
Newbie here. Have done some searches, but only found info on street springs mostly. We have a dedicated circuit race car we just bought, and the rear guards scrub on the tyres, so we need to lift the rear up a bit, but we want basically the stiffest springs possible.
Anyone here circuit race a LH/LX sedan? We were thinking Kings HHD but not sure what options are out there.
Hazza
PS - Also what is the best LX workshop manual? Are there any cd/pdf versions of LX workshop manuals?
Edited by Hazza, 11 April 2007 - 03:34 PM.
#2 Racehatch
Racehatch
  • 1,028 posts
Posted 11 April 2007 - 05:01 PM
Hi Hazza,
I race an LH Sedan (Improved Production), it really will depend on whether you are running a street style tyre or slicks. My class rules dicate I have to run a Yokahama ADVAN tyre so I'm running 1280lbs front springs, and 450lbs rears. Be carefull with how heavy you go on the rear springs, too much and you'll notice it will have trouble putting power down coming out of corners.....which is okay if your a drifter...haha
hope this helps,
cheers,
Sam
#3 _rorym_
Posted 11 April 2007 - 09:33 PM
Jesus Sam...the front must never move and be like riding on concrete!
#4 micklx
micklx
  • 1,785 posts
Posted 11 April 2007 - 11:09 PM
Rather than lifting the car to clear the tyres, maybe you need to look at tyre size, wheel arch mods, wheel offset etc
#5 Racehatch
Racehatch
  • 1,028 posts
Posted 11 April 2007 - 11:22 PM
Sorry I didnt really answer your question... :blink:
Re the scrubbing, what tyre/wheel combo are you running? Flares? As Mick mentioned, certainly sounds like a tyre/guard clearance issue.. Just making the suspension harder wont help from a handling point of view.
Re my car, yeah its pretty stiff, I actually wasnt aware how heavy they were, they were on the car when I got it, got them rate tested the other day and was surprised. It actually dosnt feel that bad on the track, certainly wouldnt want to be any lower, and thats not running on slicks! You need to run a decent shock with a spring of that weight though.
#6 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 12 April 2007 - 09:56 PM
What sort of shock are you running with that spring, and where did the spring come from. I have tried to source an Eibach but have been told it's not available for LX torana.....
Dave
#7 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 12 April 2007 - 10:38 PM
1280lb!!!! I thought my 840lb Lovells front springs were hard..........
#8 Racehatch
Racehatch
  • 1,028 posts
Posted 13 April 2007 - 01:13 AM
With regard to the suspension setup, its based on information given to me by a chap called Rick Kemp from Toperformance (in melb) This guy has been responsible for suspension setup in a number of racing Torana's, so I thought it was worth going with what he said. He recommended the spring rates and shocks that I run, and it certainly has made a big difference to the way my car handles, which has definately helped my lap times!
The shocks are as follows:
front - koni pt number - 82-5074 (designed for a Pajero!)
rear - koni pt number - 80-2299
Apparently the valving on that particular front shock will suit the spring rate I specified, and to go 1 click off the softest setting. The rear shocks will need to be revalved to go with the heavier rear spring though. I get all my springs made at Industrial Springs here in Adelaide, I just give them the dimensions of the spring (installed height and desired rate) and they make them.
The other thing to take into account is that I run a light front sway bar. Its the Kmac 24mm adjustable front mount type and I run NO rear bar at all. I've tried it with and without, and without suits my driving style the best. The fact that it runs a full spool 3.8 ratio diff also plays a part in how it feels (handling wise) - in racing conditions.
I'm not one to hide what I'm running, as far as I'm concerned if its working and been of benefit to me, then why not share the info.. :)
Somthing else to consider, different ppl like the car to handle different ways, or should I say, feel more comfortable with the car setup a certain way... Some like it to push, others like it more pointy... Really you just have to get out there with a base line setup, if you dont like it, make adjustments ONE AT A TIME, try it out and record the results. THERE IS NO ONE SETUP THAT SUITS EVERYONE!
hope this helps!
cheers,
Sam
Edited by 350LH, 13 April 2007 - 01:28 AM.
#9 _CHOPPER_
_CHOPPER_
Posted 13 April 2007 - 01:51 PM
I'm with Sam. Everybody has their own preffered setups for everything. If you're happy with what you have, leave the bloody thing alone.
#10 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 13 April 2007 - 02:02 PM
But then you may never know how good it could be?
#11 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 13 April 2007 - 06:38 PM
How would you describe the setup you currently have, pointy, likes to push or oversteer?
Pajero shocks!! Do they bolt in just like the standard ones.
Thanks,
Dave
#12 Racehatch
Racehatch
  • 1,028 posts
Posted 13 April 2007 - 09:48 PM
Hey there Dave,
With setup the way it is, I'd describe it as more of a pusher than a pointer.. :) The locked diff and lack of rear bar play a big part in this. The harder you drive it though the less it pushes. I found that with a rear bar the car was more of an oversteerer which Im not a big fan of, esp as high speeds under accel out of corners. Oversteer is cool, dont get me wrong, its just that I'd rather have the choice of inducing it..rather than having it snapping on when I least expect/want it. I may have another go with the rear bar later on this year, and play more with the spring rates, and wheel alignment.
The other big factor is tyres, in our class we have been restriced to a certain tyre make and size (225/60/15 for the Torana), basically a gumball of a tyre.... :blink: With the sidewall so big, the tyre is doing part of the suspension work, this also give you something else to consider re setup. Recent rule changes allow us to go to a 225/50/16, and I suspect we might have to make some adjustments to allow for this.
With those front shocks, you will need to make the hole in the lower control arm larger so the shock will fit through, and remove the dust cover from the shock. Nothing too drastic though.
When I run through some different setups, I'll post the results just for comparison to my original setup.
cheers,
Sam
#13 _rorym_
Posted 14 April 2007 - 10:03 AM
Very interesting Sam..thanks for the info...Keep it coming :spoton:
#14 _HatchmanSS76_
_HatchmanSS76_
Posted 15 April 2007 - 01:27 AM
Speeking to another Torana owner who races with Sam and also uses the same front spring rate. It stops the car fron nose diving at the front under hard braking causing problems at the rear end with grip and handeling.
#15 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 15 April 2007 - 09:37 AM
I was told many years ago (not sure if it was by Les Small or his workshop manager) that Grice used to run very hard springs and small sway bars while Brock used to run relatively soft springs and large sway bars.
It does come down ultimately to preferred style and experimentation is probably the only way to find what works best for you.
#16 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 15 April 2007 - 05:27 PM
Thanks for the great info, very informative. Still tossing up which way to go with my setup, front springs I think will have to be made, which sucks considering I had some 1000lb springs made but were not the ride height I specified
Dave
#17 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 15 April 2007 - 07:38 PM
Do you still have them Dave?
Where they too high or too low.
Welby
#18 Racehatch
Racehatch
  • 1,028 posts
Posted 15 April 2007 - 09:33 PM
If you are getting your springs made up, measure your installed height first, this will ensure that you get the ride height right.
The easiest way to do this is, firstly to jack the car up and put it on stands with the front and rear suspension unweighted. Remove the springs and reassemble the suspension. Put the wheel on and place a jack under the ball joint (or diff centre) and jack it up until the wheel is sitting at the desired position relative to the gaurd. You can then remove the wheel, and use a tape to measure the distance from the top of the spring seat to the recess in the lower control arm.This will be your installed height. Give this measurement to the spring maker along with the rate that you want.
#19 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 16 April 2007 - 11:41 AM
Great info again, thanks!! Welby, they were too low, by about an inch. Have a mate who wants to try them in his racecar now, so I'll be getting another set made. Because I have the Hadfield drop spindles (regretful purchase), I am having these drama's.
Dave
#20 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 16 April 2007 - 04:29 PM
Which CRS spindles do you have? I have been waiting for over 3 months for a set from them.
#21 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 16 April 2007 - 09:17 PM
Matt I have the Torana 9degree kpi to suit commodore brakes with 2inch drop spindles. I also have fitted those Edelbrock upper arms, thanks again for the tip on those!!
350LH roughly what price do the Adelaide springs cost to get made?
Dave
#22 Racehatch
Racehatch
  • 1,028 posts
Posted 16 April 2007 - 09:44 PM
Hey Dave,
From memory $200 -$250 for a custom pair of front springs (from memory) here is the link to their website Industrial Springs
cheers,
Sam
Edited by 350LH, 16 April 2007 - 09:45 PM.
#23 _rorym_
Posted 16 April 2007 - 10:07 PM
Good shit Sam! :spoton: I am onto the Pajero Konis...Dobinson quoted me $200 for special 1100lb springs..$165 for std off the shelf 780lb front A9X ones.
#24 _rorym_
Posted 16 April 2007 - 10:10 PM
Hi Hazza,
hope this helps,
cheers,
Sam
Do you get enough bite on the 450 lb rears? I want to run slicks so they might not spin up as much.
#25 _rorym_
Posted 16 April 2007 - 10:12 PM
This stuff is priceless..Mate thanks for the heads up..you probably saved me a shit load of $ experimenting...Give this man a clap! :clap: :clap: :clap: :clap: :spoton:
