Yours had a biff in the side or boot carpet, or anything like that??? a 185 will definitely fit - obviously not dead upright though.In fact a 185/70/13 tyre on a 5.5 inch GTR rim will fit - just.
I tried to fit a 175/70R13 upright in the spare wheel well in my 12/73 LJ, and failed...
Tim
GTR spare wheel bracket(s)
#26
Posted 18 May 2007 - 12:46 PM
#27
Posted 18 May 2007 - 02:31 PM
the ones I am picking up were fitted from the factory, will see monday!
a mate paid $400 for his 4 door LC 6 months ago, with reg, one owner.
well looked after.
lots extras fitted. perfect grill etc. some are luckier than me!
rims are light green, not black ?
#28
Posted 18 May 2007 - 03:50 PM
Sounds like the mate had a good bargain!
#29 _tuffgong_
Posted 18 May 2007 - 06:59 PM
chees the gong
#30
Posted 18 May 2007 - 07:09 PM
i will post a pic of the S, tonight
#31 _finer70_
Posted 18 May 2007 - 08:00 PM
No I am not wrong. You can put a v8 into a LC/J and it proves nothing.
The last word says it all JUST. The wheel well was never designed for a 5.50JJ13 wheel. Just because you can squeeze it in, easier still if the tyre is flat, proves nothing.
The issue was that bracket arrangement was altered to suit the required diffenence in retention of the larger wheel. That is the point I was trying to make; pity it went over your head.
Yes things went wrong in manufacture in those early days. I have seen the fire wall mounted GTR Belcrank bracket on a S 2 door that was totally unmolested.
But it is a long bow to pull if you expect to prove a GTR is still original by the reliance of mistakes that might have been made at manufacture.
Tuffgong has made the most relevant point in that is further scrutiny would be required before being confident that it is a real GTR.
#32
Posted 18 May 2007 - 10:40 PM
John, i was wrong, think of another car. The S is an Adel build and this is the one. I know the boot is identical to my old gtr. I remenber read something about the boot a few years ago, and went out the shed to have a look at both.lakeside, without being narsty, the brizzy built lc gtr is not the same as the s model it only has one braket.
chees the gong
#33
Posted 19 May 2007 - 03:29 PM
I'm well aware of what the spare tyre brackets should be - I'm asking if anyone knows of any GTRs where they are not as they should be - simple as that.
Edited by Dangerous, 19 May 2007 - 03:34 PM.
#34 _Pete_
Posted 19 May 2007 - 08:28 PM
I remember this from a "Hottest Torana's" magazine or similar from years ago and even remember comparing my LC GTR with an LC XU1 that was in a caryard years ago and noticing the difference in wheel well size.
#35
Posted 19 May 2007 - 08:37 PM
Edited by bullitljv8, 19 May 2007 - 08:39 PM.
#36
Posted 20 May 2007 - 12:19 AM
Bullit - thanks. I've no doubt that at least 99% of GTRs have only one bracket, as they should do, but I'm trying to establish if any had two brackets. Oh, on second thoughts, I think yours are all fakes, so can I buy them cheap ??
#37 _dave720gtr_
Posted 20 May 2007 - 02:29 PM
mabe its one of 1% that when throught with two
#38 _rorym_
Posted 20 May 2007 - 03:03 PM
#39 _blkwatch_
Posted 21 May 2007 - 12:01 AM
but want to respond to some comments
about my gtr its 7/71 lc matching tags and body no.s never been removed , colour code blackwatch green all original panels and curently rubbed back to original colour. paint under door cards still original and shiney .
car was confirmed by hg350 over a year ago
now about the spare wheel bracket i have the one on the floor near the well and a threadedhole on the inner panel which i asume is for the spare bracket .
havent had a real good look for panel replacement will do tomorrow,
now before anyone says that this gtr may not be original i would like one of yuz if ever in cowra nsw to stop in and have a look see for me and yourself just call me on 0415745893 Deano (make sure i got a couple of coldies)
i would post pixs but dont no how ( 44 year old still learning) just took me an hour to write this)
But just to get yuz reved up again think it has the two carby brackets also ,,
hey now i now ya thinking moc up but dont say that until one of yas have a look
vin 82911ch202520 will go see what i can do about photos
blkwatch
#40 _tuffgong_
Posted 21 May 2007 - 06:21 AM
cheers the gong
P.S i cant wait for you answer on question one.
#41 _blkwatch_
Posted 21 May 2007 - 10:01 AM
blkwatch
#42
Posted 21 May 2007 - 01:02 PM
Good question Tuffgong - I hadn't thought of that one being the one that blkwatch was referring to.blkwatch, just a question for you, when you say that your gtr has the [ threadedhole for the stand up braket to bolt into] do you mean the one up neer the taillights on the inner quarted panel
blkwatch, one of the photos in the beginning of this thread shows quite well the two floor mounted brackets that I am referring to.
#43 _blkwatch_
Posted 21 May 2007 - 02:17 PM
blkwatch
#44
Posted 21 May 2007 - 04:02 PM
The threaded hole is intended to hold a spare wheel clamp - I think it's the same setup as what was used on HK series Holdens, but it requires the spare wheel to sit dead upright, so it's not much good in an LC.
#45
Posted 21 May 2007 - 04:56 PM
If i stand my LC spare upright the boot won't shut.. I always thought this was because my well is bogged for protection, recuding its depth slightly. They are not supposed to be upright then? I usually just let it rest on the second (larger) bracket. I also found a photo which shows GTR wheel should lay flat, bolted to the small bracket.. with the jack and crap in the hole.
This leads to another question. So if there is a bolt for securing a horizontal laying wheel, and a hook for holding a verticle wheel.. what bolt can be used to secure the angled spare while it rests?
out of curuosity.. how should bathurst xu-1s keep their spare if they don't have the resting bracket nor space to lay it down?
sounds like some oversight from holdens... with a few quick work-arounds.
Edited by smeer, 21 May 2007 - 05:01 PM.
#46 _tuffgong_
Posted 21 May 2007 - 07:07 PM
blkwatch, thanks for that.
dangerous, im not being smart man but it seems like you will need to let your mate know to check this one right out.
cheers john
#47
Posted 21 May 2007 - 08:36 PM
I thought that the Sprintmaster (being 6") laid completely flat. The following pic is from the LJ handbook.
Bazza
#48 _devilsadvocate_
Posted 21 May 2007 - 10:56 PM
#49 _NRV051_
Posted 22 May 2007 - 05:51 AM
#50
Posted 22 May 2007 - 04:39 PM
John, no hassle, I know you're not being 'smart' about it - telling this bloke to check lots of little things very thoroughly was the first thing I said to him, before jumping onto the forum to ask others about their knowledge or experiences.dangerous, im not being smart man but it seems like you will need to let your mate know to check this one right out.
cheers john
Cheers for the input
