Lowering Tricks, Other Springs to use?
Posted 23 October 2007 - 02:36 PM
I am in the process of Lowering my GF's UC hatch. I am wondering what other people have done in lowering their Torana's.
I have Heard of various springs being used (and modified) to fit in the rear of Torana's.
I know Makka uses Camira Springs in his LX, and it lowers the Car bout 4inches. I have heard of people putting commodore IRS springs in the rear as well (But we tried this and i think he might have got the wrong springs, cos the rear end is as stiff as buggery!!!)
What else have people tried?
I was wondering how LJ rear springs would go in a UC? Because we actually bought LJ rear shocks to allow for the lowered springs...
Anyway i am really interested to hear any tricks out there (Not really interested in Cutting rear springs because of the shape of the spring...)
Matt
#2 _torana_
Posted 23 October 2007 - 04:00 PM
but its not highly recommended though.
cheers julian
Posted 23 October 2007 - 04:05 PM
Yeah well we are looking into getting the Original Springs Reset a few inches lower. But just thought i would test the waters to see what else is out there...
#4 _TORANR AMORE_
Posted 23 October 2007 - 04:33 PM
Spicer Springs: 9720 0809
They're not far from you, and it's fairly cheap to get done.
Cheers,
Rick.
Posted 23 October 2007 - 04:53 PM
Thanks mate!
#6 _rhysandhisLJ_
Posted 23 October 2007 - 09:43 PM
is it possible to get them uncompressed say an inch? i ask this because my lx is ridiculously low, the cat part of the exhaust system sits a mere 55mm off the ground.
Thanks,
Rhys.
#7 _workinprogress_
Posted 27 October 2007 - 03:18 PM
#8 _Leakey_
Posted 27 October 2007 - 03:29 PM
Prob' wont ever do it myself, but great info none the less.
#9 _LX8VD69_
Posted 27 October 2007 - 03:38 PM
cheers adam
#10 _brett_32i_
Posted 01 November 2007 - 01:34 PM
#11 _Chriskoss-79uc_
Posted 08 November 2007 - 02:56 PM
I have a UC hatch also and am looking to lower it.
Is it ok to use front lowering springs from a V8 lx torana?.
I found these springs on ebay http://cgi.ebay.com....:MEWA:IT&ih=018
and was wondering if they'll fit my uc hatch.
They will just be a bit firmer as they are for a v8, correct?
Edited by Chriskoss-79uc, 08 November 2007 - 02:57 PM.
Posted 09 November 2007 - 10:17 AM
Posted 12 November 2007 - 09:49 AM
hehe that would last 3 weeks before the spring would break, sag or destroy itself,you can do the dodgy' heat with an oxy torch and push down on the car till the height you get is required then quench with water trick'
cheers julian
spring compressors, oxy and a bucket of old sump oil, water will cool it to fast and weaken the shite outta the steel.
but if there is a spring that would suit (never heard the camira one before) use that option.... bit safer.
Posted 12 November 2007 - 01:45 PM
#15 _Chamois hatch_
Posted 12 November 2007 - 02:50 PM
Posted 12 November 2007 - 03:00 PM
#17 _brett_32i_
Posted 12 November 2007 - 04:31 PM
#18 _rhysandhisLJ_
Posted 12 November 2007 - 06:13 PM
I don't have the measurements, but i do have photo's of my lx when i had 17's on + camira springs.
Posted 12 November 2007 - 11:41 PM
#20 _brett_32i_
Posted 13 November 2007 - 10:50 AM
they look about 1/2" lower than my irs springs. so i reckon a set of those and insulator pads and i'll be fine.
How soft/hard are they?? i need soft to get traction. thats why the irs are no good.
#21 _rhysandhisLJ_
Posted 14 November 2007 - 07:13 AM
The Camira springs are quite soft, softer than standard lx torana ones! The reason i have changed them over with custom lowered king springs is the camira ones were way too low. My cats were nearly rubbing on the road.
My king springs are still around 40mm too low but the car handles a whole lot better than with the camira ones in.
Rhys.
#22 _brett_32i_
Posted 14 November 2007 - 08:25 AM
#23 _brett_32i_
Posted 14 November 2007 - 08:53 AM
that could be a good thing. who knows the std spring rate of torana, and the spring rate of say a HD pedders?
cost is $55 a pair.
they also suggested Brown springs in thomastown to do custom springs. i think chopper has mentioned these blokes before.
#24
Posted 14 November 2007 - 09:52 AM
HAHA, That price seems to change each time someone calls, but its getting cheaper!just spoke with spicer springs (in bayswater) and they said that resetting the springs will typically increase the spring rate by 30%
cost is $55 a pair.
its was 75, then my gf called the other week and it was 65, now its 55! haha.
I would recommend finding a pair of like 1" lowered pedders or something and getting them lowered. seeing as they have less coils in them, they will probably perform better.
#25
Posted 16 November 2007 - 10:42 AM
4 inches or so down on standard, I can measure the wheelarch to centre if you like
camira springs are not as soft as you would think, they are a bit soft at the start of the stroke but they stiffen up as they are progressive rate.
