TRIPLE CARBS BACK FIRING help
#26 _troy_
Posted 27 October 2007 - 04:50 PM
#27 _threeblindmice_
Posted 27 October 2007 - 11:17 PM
#28 _willo_
Posted 27 October 2007 - 11:21 PM
aahh that also happened to me.. it turned out that the o ring in the end of the fuel line to the carb was "crimped"....funnily enough that was also the middle carb....troy check that.If it only the middle carbie, I once had the middle SU ,small, bowl to jet hose block up on me it was thirty years ago so I can't remember the symptoms ,but simple to check.Other than that put on a holley to eliminate or prove its the carbies
#29
Posted 28 October 2007 - 12:25 AM
#30 _troy_
Posted 28 October 2007 - 03:25 PM
#31 _threeblindmice_
Posted 28 October 2007 - 04:04 PM
#32
Posted 28 October 2007 - 04:07 PM
That way you could possibly eliminate issue with the carbs or not
i no its more work but its 1 way of working out if its the carbs or not
#33 _rorym_
Posted 28 October 2007 - 04:12 PM
Still reckon its electrical....Yea i had the head machined,it was backfiring in the middle carb mainly ,now is all 3 but idles sweet and has absolutely no guts at all,undrivable..
#34 _troy_
Posted 28 October 2007 - 05:31 PM
#35
Posted 28 October 2007 - 05:55 PM
#36 _threeblindmice_
Posted 28 October 2007 - 09:24 PM
#37 _LC-TORANA-1970_
Posted 28 October 2007 - 09:37 PM
#38 _sunburst_metalic_
Posted 28 October 2007 - 09:40 PM
#39 _sunburst_metalic_
Posted 28 October 2007 - 09:43 PM
#40 _troy_
Posted 29 October 2007 - 10:59 AM
#41 _threeblindmice_
Posted 29 October 2007 - 11:05 AM
#42
Posted 29 October 2007 - 08:19 PM
#43 _threeblindmice_
Posted 30 October 2007 - 08:37 AM
#44 _troy_
Posted 30 October 2007 - 02:05 PM
I have even compression
I have fuel
changed the dizzy and coil
changed the carby and manifold
advanced and retarted the timing
changed spark plugs
readjusted the rockers from 20 thou back to 15 thou
had a timing light on it
Honestly whats fkn left ???I have an earth strap on the motor and to the radiator,that wouldnt be the problem??
I had the solid lifters refaced maybe it sliced a bit of the cam lobe off???If it did then would there be even compression??
I just rung rocket in sydney and spoke to claude, and he reckons its more than likely the head shim so off come the head...........pushrod length is the problem hopefully ..
Edited by troy, 30 October 2007 - 02:17 PM.
#45 _oz772_
Posted 30 October 2007 - 02:14 PM
#46
Posted 30 October 2007 - 02:23 PM
incorrect firing order
way out timing - check that the TDC (top dead centre) mark on the harmonic balancer co-incides with TDC of piston number 1 by having a look through the plug hole of Cyl 1 while rotating the motor by hand. Also check that it's the compression stroke, and that you haven't got the dizzy 180 degrees out - unlikely, as it shouldn't idle if that's the case, but it would backfire like buggery.
bad crossfire from your plug leads or dizzy caps (yes, both types of dizzy)
valves not closing properly (what is your average compression, and how much variation?)
too much compression - see above
some very wierd fuel problem
valvel springsd too weak for the solid cam?? - clutching at straws here, but are the valve springs new, and strong?
very low fuel pressure - I think I recall that you're running an elec fuel pump, but if you're running the stock mechanical pump, then it is actually possible (but difficult) to get the plunger cam under the cam lobe instead of over it. The cam will still move the plunger a small way, but will only pump a very small amount of fuel. As soon as you need more, you lean out and the egine will not run.
If you've definitely ticked off al of the above, .............
- it still sounds like weak ignition. Plonk the electronic ignition and coil back on, temporarily hook the coil +ve directly to the battery +ve and start it. Any difference? Is the spark, big, fat and bright, or is it a pissy little spark?
#47 _troy_
Posted 30 October 2007 - 04:22 PM
#48
Posted 30 October 2007 - 04:29 PM
#49
Posted 30 October 2007 - 04:40 PM
#50
Posted 30 October 2007 - 06:11 PM
