TRIPLE CARBS BACK FIRING help
#51 _LC-TORANA-1970_
Posted 30 October 2007 - 07:34 PM
#52 _troy_
Posted 30 October 2007 - 10:06 PM
Edited by troy, 30 October 2007 - 10:13 PM.
#53 _sunburst_metalic_
Posted 31 October 2007 - 09:31 AM
#54 _rorym_
Posted 31 October 2007 - 09:49 AM
#55 _troy_
Posted 31 October 2007 - 11:54 AM
#56 _sunburst_metalic_
Posted 10 November 2007 - 03:31 PM
#57 _troy_
Posted 12 November 2007 - 08:20 PM
I then took the head into the head shop again and got them to completely check it over,nothin wrong with the head,or double valve springs,or valves i thought i may have a stuck valve,i didnt.I then assumed the cam or valve train is f%$ked,i pulled the side covers off and was removing the solid lifters ,some of them 3 to be exact arent solid anymore,the bottom of them is scooped out into a moon shape which isnt normal,i been tryin to pull the balancer off and get the cam out at the moment do u have to rip the oil pump off too??to get the cam out,absolue disaster is what i reckon a $5000 motor thats done 200km maximum been pulled down rebuilt twice and for this to happen have to rebuild the bitch again
#58 _Yella SLuR_
Posted 12 November 2007 - 08:26 PM
Leave your side covers off till last. Make sure both lifters are down when you set your initial timing to ensure you are on the power and not the intake/exhaust stroke. Produces the same results as you are talking of.
#59
Posted 12 November 2007 - 08:47 PM
Swapped carb, dissy, plugs, you name it.
While I was checking the cam timing I noticed that 3 of the valves were barely moving and another couple were only opening about halfway.
fitted a new cam and she ran like a beauty.
The valves were letting enough air in at idle but as soon as you asked the question, it couldn't cope.
#60 _troy_
Posted 12 November 2007 - 09:07 PM
#61
Posted 13 November 2007 - 12:05 AM
Something to look for next time when your re-adjusting valve clearance?
Edited by rodomo, 13 November 2007 - 12:08 AM.
#62 _Yella SLuR_
Posted 13 November 2007 - 07:22 AM
#63 _troy_
Posted 14 November 2007 - 09:43 AM
#64 _@milco@_
Posted 14 November 2007 - 10:13 AM
hope the next build goes better for you mate
#65 _rorym_
Posted 14 November 2007 - 05:30 PM
