Micks Racecar Project LX202 to VH308
181 replies to this topic
#151 GML-31
Posted 14 February 2010 - 08:36 PM
you left your nuts at home after valentines morning?
#152 _jay79_
_jay79_
Posted 14 February 2010 - 08:41 PM
nice did the bolt come all the way out?
#153 rodomo
  • 18,050 posts
Posted 14 February 2010 - 08:49 PM
*snigger* looks like he shot his bolt
#154 Heath
  • 18,401 posts
Posted 14 February 2010 - 09:56 PM
Far out! What happened to the bolt in there?
#155 rodomo
  • 18,050 posts
Posted 14 February 2010 - 10:56 PM
The bolt can be seen in the pic lying in the undertray
#156 _Brad1979UC_
_Brad1979UC_
Posted 14 February 2010 - 11:04 PM
:o........*Runs to garage to make sure his balancer bolt is tight*
#157 micklx
micklx
  • 1,785 posts
Posted 15 February 2010 - 04:52 PM
It sheared the harmonic balancer key, After trying for ages to get the broken bit of key out, I realised it also locates the timing gear and it was never going to come out, I was desperate to get back out, the car had felt great, and my 2 mates who race were there , so I pushed it back on, tightened it as far as I could, crossed my fingers and went out for 1 more flying lap - I broke my PB on this lap now 1.56.1 previously 1.56.8, Karl also broke his PB on the same lap, and better still I passed the XY under brakes going into turn 4 !!!!
I came in, tightened the bolt again and did this 2 more times before the day was over.
Out of 85 cars, I came 16th. All in all not a bad day although I've got some work ahead of me.
#158 rodomo
  • 18,050 posts
Posted 15 February 2010 - 05:07 PM
:clap:
Will the crank live? :huh:
#159 Heath
  • 18,401 posts
Posted 15 February 2010 - 05:08 PM
Love it Mick!
#160 micklx
micklx
  • 1,785 posts
Posted 15 February 2010 - 06:59 PM
Not sure about the crank.
There is a couple of things about this motor that suggest it was used in a boat at some stage. Boats usually drive off the front of the crank, so it's a possibility (clutching at straws here)that the front of the crank has some tiny amount of wear which contributed to the problem.
I might just change the key, and fit a new balancer using the appropriate locktight and take it to the drag day and see what happens.
If I have to change the crank, it will mean rebalancing, grinding the crank and new bearings as a minimum,
I probably should change rod bolts and valve springs,
I could easily cope with more comp and a bigger cam .......... I think this is known as the snowball effect !
Edited by micklx, 15 February 2010 - 06:59 PM.
#161 micklx
micklx
  • 1,785 posts
Posted 24 March 2010 - 06:43 PM
:clap:
No - the crank is stuffed !
With the timing gear off, there is a noticeable lip between where the balancer goes and where the gear goes.
But hey - it was fun while it lasted !!
#162 Heath
  • 18,401 posts
Posted 24 March 2010 - 07:24 PM
So will it be ready for the drag day!?
#163 micklx
micklx
  • 1,785 posts
Posted 25 March 2010 - 05:02 PM
Well it won't be fixed properly for the drag day, but I might put it back together with some loctite on the balancer and hope for the best. I got the broken key out which wasn't easy.
#164 GML-31
Posted 25 March 2010 - 07:14 PM
even if you get a few runs in at least you had a go mate. Better still you get to see (possibly) Bomber cut a great time in his hire car lol....
#165 micklx
micklx
  • 1,785 posts
Posted 01 April 2010 - 05:31 PM
It ran well at the drag day, no problems all day, didn't keep track of how many runs I did, but I think it was about 10. Best time was 13.6 which was .2 slower than last time 2 years ago.
I set my best time with my girlfriend in the car, the extra weight must have helped with traction - although I'm not sure I should have told her that....
#166 rodomo
  • 18,050 posts
Posted 04 April 2010 - 08:34 AM
When is your next circuit day Mick?
#167 micklx
micklx
  • 1,785 posts
Posted 05 April 2010 - 02:03 PM
Two video clips from Heathcote. My Commodore racing Heath and Matt.
I'm waiting for you to get your extractors built and then come to Phillip Island for a sprint.
Although I need to get the motor out and fix the crank and at the moment I've got too many other jobs on the go to even start that so not really sure when it will be.
#168 micklx
micklx
  • 1,785 posts
Posted 02 November 2011 - 10:33 PM
Fired up the racecar yesterday and drove it outside for a wash. I remembered I'd never got around to uploading any video of the lap when I passed Karls XY. Unfortunatley my camera wasn't going but this is the view from inside my mate Marks VN (V6 ex Saloon car)
Edited by micklx, 02 November 2011 - 10:33 PM.
#169 _Brad1979UC_
_Brad1979UC_
Posted 02 November 2011 - 10:52 PM
Tuff as Mick!!
#170 rodomo
  • 18,050 posts
Posted 02 November 2011 - 11:15 PM
The VN does orite too to keep up sorta? :)
Good under brakes!
#171 _CHOPPER_
_CHOPPER_
Posted 03 November 2011 - 10:23 AM
You must have been very busy if it took 18 months to change the crank. Or there was other things changed too.
#172 micklx
micklx
  • 1,785 posts
Posted 15 November 2012 - 07:16 PM
Haven't driven the car in anger since the 2010 drag day, I think its time I fixed that crank.
#173 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 16 November 2012 - 07:04 AM
ireckon so mate
#174 micklx
micklx
  • 1,785 posts
Posted 24 November 2012 - 04:09 PM
I went to Sandown today for the Shannons Nationals, it was the last occasion Commodore Cup will run as a national series, hopefully they will revive it as a state series, anyway, I bought some good used tyres that were fresh off the car and shouls have more grip than the ones currently on the car which have been there since about 2009.....
#175 _wblje_
_wblje_
Posted 24 November 2012 - 05:18 PM
you have inspired me mate. got one of the half finished jap cars out back, stripped it and off to the local sprints next week to flog the ring out of it. been wanting to do something like this for ages and your thread gave me a push.
