355 HP For LH Guestimate?
137 replies to this topic
#1 _rorym_
Posted 07 January 2008 - 11:27 PM
OK guys, I am running this on another forum but you get a turn as well..hopefully on the dyno Sat.
Specs are:
VN 304 Block relieved for stroker crank and rods.
Eagle 355 Crank
Scat 5.7 rods 7/16" pins.
Federal Mogul H859P 12cc dish pistons.
Accel billet dizzy with Accel super coil
MSD 6AL with 7000rpm cutout.
Decked , shaved
Comp Ratoi 10.5:1
VN heads..flowed to 530hp.
Torque Power Dual Plane (Cant get anything else under the bonnet) with 1" spacer.
B/G 750 DP.
Crane C288 cam/Solids with lifters.
Yella Terra Roler rockers. 7/16" pins in head.
2.02 Inlet Valves 1.6 Exhaust Manley S/Steel.
ARP everything.
Pacemaker PH 5275 1 3/4" primaries,2" seconds,2 1/2" collectors.
Usual hi volume oil pump, Hi Energy sump...etc etc
Might add more I have forgotten but you get the drift..
Whats the predicted power and torque figures at the flywheel?
Go hard!!
Winner gets a 2008 really trick leather bound Master Builders diary..!
#2 _the gts_
_the gts_
Posted 08 January 2008 - 01:30 AM
450 guess
give me the head flow at 100 200 ...... 500" lift and i will do it on dyno 2003 for ya
#3 _MRNOS_
_MRNOS_
Posted 08 January 2008 - 05:56 AM
456.5hp... :D
#4 arrimar
arrimar
  • 3,134 posts
Posted 08 January 2008 - 06:51 AM
392
#5 _Herne_
_Herne_
Posted 08 January 2008 - 07:00 AM
Hi Rory, how soon are you expecting to have your engine running? It will be interesting to compare figures with mine. The engines will not be exactly the same as I will be running standardish VN heads with just LT1 springs. I am running the TP dual plane though. I traded the Harrop back in again lol
Initially I will be running the cheap VN factory extractors but in time I will be changing to a more suitable set - maybe pacemakers...
At a rough guess I would say at least another month before I am ready to install the new 355.
Herne
#6 _rorym_
Posted 08 January 2008 - 09:32 AM
Herne,
Hopefully on the dyno Sat.
#7 _The Baron_
_The Baron_
Posted 08 January 2008 - 09:55 AM
487hp
#8 _TJ253_
_TJ253_
Posted 08 January 2008 - 10:19 AM
440hp
#9 _Herne_
_Herne_
Posted 08 January 2008 - 10:28 AM
Herne,
Ok Rory, thats quick :) I will be very interested to see your figures, then we can compare them a little bit later with my figures.
Herne
#10 _smcbr6_
_smcbr6_
Posted 08 January 2008 - 12:29 PM
Put me down for 408hp
#11 _v8slrtorana_
_v8slrtorana_
Posted 08 January 2008 - 12:49 PM
428 HP i guess
#12 _rorym_
Posted 08 January 2008 - 01:43 PM
You can go and stand in the corner.... :<_<:
flywheel...not rear wheels.
#13 _Dirty Deeds_
_Dirty Deeds_
Posted 08 January 2008 - 01:49 PM
467
#14 _ezy_09s_
_ezy_09s_
Posted 08 January 2008 - 02:52 PM
470 hp/450ft/lb..shame about the dual plane manifold
#15 _v8slrtorana_
_v8slrtorana_
Posted 08 January 2008 - 08:31 PM
Can i change my mind? :<_<:
442HP @ 6500rpm
401 ft-lbs @ 5000rpm
#16 _Monkey_
_Monkey_
Posted 08 January 2008 - 08:45 PM
465..Lock it in!
#17 _rorym_
Posted 08 January 2008 - 08:55 PM
Its getting interesting now.
Edited by rorym, 08 January 2008 - 08:57 PM.
#18 _rorym_
Posted 08 January 2008 - 08:57 PM
442HP @ 6500rpm
Yep...you looked harder didnt you?.. :clap:
#19 _Bomber Watson_
Posted 08 January 2008 - 09:07 PM
Im going to guess around 28hp and 3ft-lb's.
Or if i wanted to flatter you i could go 708hp and 3000000000 ft-lb's.
But i think i'll make my real guess at 472.3HP
#20 _ezy_09s_
_ezy_09s_
Posted 09 January 2008 - 10:18 PM
So Rory,when are you going to dyno this?& where are you dynoing at?
#21 _smcbr6_
_smcbr6_
Posted 09 January 2008 - 10:39 PM
lol - perhaps I'll end up in the corner. Until the dyno sheet proves me wrong.... i'll be roaming!
My 202 hits the dyno late next week... sadly, i may put myself in the corner. :tease:
#22 _revmaniac_
_revmaniac_
Posted 09 January 2008 - 11:01 PM
435.6HP at flywheel
#23 _rorym_
Posted 09 January 2008 - 11:55 PM
Straightline Performance....Hervey Bay ...This guy builds Pro Stock engines.
#24 _rorym_
Posted 11 January 2008 - 01:54 PM
Should have the numbers Sat arvo.
#25 _Herne_
_Herne_
Posted 11 January 2008 - 01:56 PM
yeah big day tomorrow Rory :)
Did you get your dizzy recurved to suit the engine mate?
Herne
