Compounding Paint
#26
Posted 11 March 2008 - 08:18 AM
#27
Posted 12 March 2008 - 09:42 PM
I followed Pete's instructions and the paint work came out stunning! Looks like i paid 8k for a paint job!!! I am stoked!
#28
_Yella SLuR_
Posted 18 April 2008 - 11:39 PM
Thanks again for your advice Pete, looking a million bucks.
Moral of the story, let the sandpaper do the work.
Edited by Yella SLuR, 18 April 2008 - 11:40 PM.
#29
_Big T_
Posted 19 April 2008 - 02:15 AM
#30
_Yella SLuR_
Posted 19 April 2008 - 07:17 AM
#31
_Yella SLuR_
Posted 19 April 2008 - 07:21 AM
#32
_Yella SLuR_
Posted 19 April 2008 - 06:23 PM
Little bro learns the frustration of painting highlighting all the defects in the panel.
#33
_Yella SLuR_
Posted 19 April 2008 - 06:32 PM
#34
Posted 20 April 2008 - 09:17 AM
#35
_Yella SLuR_
Posted 20 April 2008 - 05:40 PM
#36
Posted 20 April 2008 - 07:28 PM
it will go milky looking causing you to paint it again,havent used arcylic since i was 1st year apprentice that was 17 years ago
#37
_Big T_
Posted 20 April 2008 - 10:21 PM
I have since sanded back the clear and put another two coats of colour on. The colour has now been blocked back with 1200 and its flat (no orange peel) but not really shiney though. I can see light scratching/sanding marks in the finish but Im not sure if I should cut back with 1500-2000 before putting the clear on.
Before I put the clear on last time I had done as above but the clear that wasnt milky seemed to bring the colour up with no signs of sanding marks and nice and glossy. I figured I would just do the same this time around but now Im not too sure.
When you say "Solid Colour" Pat, does that mean no clear coat?
#38
_Yella SLuR_
Posted 21 April 2008 - 03:59 PM
Fair enough, I think you are right. Being near the coast I think you'll find the humidity really jumps up at dusk in addition to temperature drop, giving you plenty of dramas. As always, if I can save you some time.
1200 should be fine. If you go too fine, you won't have enough of a key for the top coats, particularly clear, although acrylic will meld into the lower layers anyway.
Happy painting. If Brock can add to this, then all well and good. Always happy to learn more and/or alternative techniques, although with painting, I find it's more a case of whatever works for you and your technique.
#39
Posted 21 April 2008 - 07:45 PM
awell here,if you are painting outside (not in a heated booth) u are better
to make sure that it hasnt rained in the last three days and make sure you start around lunch time as its the hotest part of the day,as for the problem u have now if you wet rub with 1000 grit w/d and paint again but make sure its a good day
and hasnt rained as you will get little bubbles showing up in your paint work 3 months later and that means strip it and start from scratch anymore question just pm
Edited by brocks72xu1, 21 April 2008 - 07:52 PM.
#40
_Big T_
Posted 21 April 2008 - 11:09 PM
Now I just gotta wait for the sun to shine consistently before a weekend so I can get back into it. You would reckon in QLD that wouldnt be a problem, not so recently..... ah well.
