Webers On Again Off Again
#1 _dandapalm_
Posted 27 February 2008 - 11:53 AM
I can now say,I am world authority on ripping off a 600 DP and manifold and refitting webers which has been done now about 4 times since an allged "guru" made a mess of my last set. This time, the webers have come back from Carbtech Brisbane who I can highly recommend, the quality of linkages and general work is outstanding. Just thought I should share anyhow, and mess with my photobucket stuff for the first time.
#2 _CraigA_
Posted 27 February 2008 - 02:17 PM
Just replaced my manifold gasket, but my Weber's are on separate Warneford manifolds instead of the single piece one it looks like your using (a Redline one maybe??). Fitting mine is like trying to tie an octopus' shoelaces with your hands covered in butter. Add to that the very small area available for manifold washers and its a nightmare.
Set up looks great though. Congrats.
#3 _dandapalm_
Posted 27 February 2008 - 02:25 PM
I can tell you mate, we are a special breed , a club that to gain entry into you have to endure pain . And I modded to go onto a blue 12 port mate........I need my head read hey...
#4 _dandapalm_
Posted 27 February 2008 - 02:30 PM
Edited by dandapalm, 27 February 2008 - 02:33 PM.
#5 _dandapalm_
Posted 27 February 2008 - 02:35 PM
Sorry I was also going to add this pic....car colour is all screwed up because it has massive white light reflecting from next door neighbours house. It is Mitsubishi EVO yellow .....$%^in bright .
#6 _CraigA_
Posted 27 February 2008 - 02:50 PM
Well worth the effort though, looks a treat. And will make you smile every time you put your foot down
#7 _WYLDLC 6_
Posted 27 February 2008 - 02:55 PM
I think whoever designed these manifolds needs there head read.
Zero room for washers and crap extractor gaskets these days which never seem to seal properly.
If it wasn't for the added power and great noise I think I would have sold em and put a bloody holley on.
I just love removing 3 layers of skin on each knuckle just to do a gasket change.
Chris
#8 _dandapalm_
Posted 27 February 2008 - 03:03 PM
But you are so right....if it wasnt for the sound/power etc, it just wouldnt be a proposition..........This car is almsot ready to go and then my forsaken GTR will be in the spotlight.....yes I have a problem.. 1 X xu1 and this GTr and a 3rd GTR up for the resto..... I need mental help
Cheers though mate, we are all partners in pain with this damn manifold type!!!!
#9 _WYLDLC 6_
Posted 27 February 2008 - 03:32 PM
I had to grind my 3/8 spanner head a bit thinner to fit the tight spaces but a lot easier than other ways. Atleast I can get some leverage and do them up a bit easier.
The bolts set me back about $35 for 12 but thats the best $35 I've spent.
Chris
#10 _dandapalm_
Posted 27 February 2008 - 03:37 PM
Guys, i actually tried the redline one and despite the carbs not being set up perfectly, it didnt have the same punch as the old 3 piece.
Carbtech as well told me that the 3 piece ones are the dyno guys favourites when looking for max power .
#11 _CraigA_
Posted 27 February 2008 - 03:46 PM
I'm currently trying the metal sided extractor gaskets sourced from 'Straightline Performance' on eGay. As I put the Webers back on I kept glancing sideways at the original CD Strombergs thinking how much easier they would be. And then I remembered the sound of the air rushing into the Weber's trumpets.
The CD's are still on the shelf.
Oh, and I use a socket with a flexible shaft to do the bolts up. And have modified a combination of flat washers and standard Holden header washers, each one unique to its location.
Edited by CraigA, 27 February 2008 - 03:50 PM.
#12 _WYLDLC 6_
Posted 27 February 2008 - 03:47 PM
Whats the going rate fore a 3 piece I'd be interested to know.
By the way, I'd like first hit.
Chris.
#13 _CraigA_
Posted 27 February 2008 - 03:49 PM
#14 _WYLDLC 6_
Posted 27 February 2008 - 03:52 PM
#15 _CraigA_
Posted 27 February 2008 - 03:56 PM
I like your car lots Chris, was it at Toranafest 2007?
#16 _dandapalm_
Posted 27 February 2008 - 03:59 PM
I would never swap them, but between fellow weber owners, I just wondered if you know what I am talking about. READ ABOVE.........it is ever so slight.
BUT..........when I had the redline on it never had this minute dip , but was not as throaty either with redline...anyway more things to consider .
Guys this is just a query, and not sure what a warnerford manifold is worth???
#17 _WYLDLC 6_
#18 _WYLDLC 6_
Posted 27 February 2008 - 04:07 PM
I increased my timing a touch and the car now idle's at around 1100rpm and it has improved.
The guys who tuned them are very good and spend 5-6 months a year in the states running a classic race team with Austin Healeys with straight 6's and triple webers.
They believe without the finest of fine tuning it is a problem that comes with the carbs.
Edited by WYLDLC 6, 27 February 2008 - 04:08 PM.
#19 _CraigA_
Posted 27 February 2008 - 04:08 PM
Everything else is OK, starts easy, idles good, driveability when cold is great, and good under power.
I bought the engine and carbies off eGay as a complete unit so don't know jet/air corrector/choke sizes but I do know the guy I bought them off had them professionaly set up.
Chris I am looking to come to QLD for the QTCC event in June/July. Might see you there!!
#20 _WYLDLC 6_
Posted 27 February 2008 - 04:10 PM
#21 _dandapalm_
Posted 27 February 2008 - 04:14 PM
You are dead right about on the pedal and away.......and the most common slight hesitation is from a lean idle circuit, so thanks for confirming this mate.
And as I said.....I wouldnt swap them for any other set up, this was just a very minor point .
Cheers mate
#22 _WYLDLC 6_
Posted 27 February 2008 - 04:19 PM
I think each tuner has there own way and thats what makes it hard to find a good one.
With the plugs it's good to hear i'm not the only one with this problem, but I don't ever have to really clear them like that.
Edited by WYLDLC 6, 27 February 2008 - 04:21 PM.
#23 _CraigA_
Posted 27 February 2008 - 04:23 PM
My cam is of an unknown grind, but the car still makes reasonable power and idles with a nice roll at around 850/875 rpm @ 14 degrees initial timing. Possibly increasing the idle will keep the plugs a little drier?
After a good run I usually remove the plugs to have a look, and the centre electrode is nice and clean with a black dusting around the outer ring of the plug body.
I have been thinking about buying a Gunson ColorTune so I can see exactly whats happening at idle, and lean it off a little in the idle circuit.
Edited by CraigA, 27 February 2008 - 04:24 PM.
#24 _dandapalm_
Posted 27 February 2008 - 04:25 PM
My guy is just an old weber hard head and says that as you said, it needs the finest of fine tuning.
As I said dont get me wrong.............. they haul serious #SS, but I am very glad to hear from you about your set up.
Cheers mate.
#25 _WYLDLC 6_
Posted 27 February 2008 - 04:34 PM
As I said I find mine is quite good now with the extra idle speed and is very responsive. Only problem is if you get a crappy batch of fuel it will ping.
