Painting Engine
#1 _BCR42Y_
Posted 06 March 2006 - 07:53 AM
I am not to sure if i have put this in the right section, but i thought i would just ask.
Previously my engine was painted Blue and it looked trick in the engine bay, as the car is blue.
I am about to start putting it back together and my friend has said to paint it black instead of blue.
Now i know that black has better heat carrying capabilities, but would it make that much of a difference?
Also, do any of you have a photo of a black motor in a torrie engine bay that is also black?
Its not a show car, just a clean streeter, so i am not after any awards with it, but i do want it to look the part.
What are your thoughts..............
Regards
Halil.
#2 _draglc_
Posted 06 March 2006 - 10:36 AM
A1
#3 _Eddie_
Posted 06 March 2006 - 10:48 AM
I've got a pic of a black engine bay and motor but need somewhere to host? Heath?
EDIT: <------------------- you can almost see in my little pic there. See?
Edited by Eddie, 06 March 2006 - 10:49 AM.
Posted 06 March 2006 - 10:57 AM
i done a 308 in a blue HQ by painting the lot silver then getting some blue in a cup and a brush and just flicked the paint everywhere that was a good 2 year ago and it still looks awesome (i also highlighted the eldebrock manifold etc)
get creative! nothing worse than a nice car with a black engine (other than a matt black car (eww!) with a black engine)
Posted 06 March 2006 - 02:00 PM
#6 _[BOTTLEDUP]_
Posted 06 March 2006 - 02:43 PM
#7 _devilsadvocate_
Posted 06 March 2006 - 04:13 PM
Its not really the thickness of the paint that makes the difference(well too thick a coating of paint can be an insulator), it is the colour. Didnt you do the experiment at school where you painted some aluminium cans black and see if they cool faster than unpainted ones, the results are significant.The colour of a 2mm thick enamel paint won't make any noticeable difference to an already seering hot block. HPC coating the extractors may reduce heat slightly.
You are right though, it wont make much of a difference to a engine block where the principal method or removing heat is via the radiator, not air cooling of the block.
The engine will absorb heat from the exhaust though so perhaps painting the motor white or silver immediately adjacent to the exhaust might have some merit, but doubt it would be worth the effort.
What colour, go withwhatever you feel looks good.
#8 _Eddie_
Posted 06 March 2006 - 05:10 PM
Significant yes on an aluminium can where the paint is as thick or thicker than the wall thickness, but not significant on an engine block.Didnt you do the experiment at school where you painted some aluminium cans black and see if they cool faster than unpainted ones, the results are significant.
#9 _devilsadvocate_
Posted 06 March 2006 - 08:37 PM
Edited by devilsadvocate, 06 March 2006 - 08:40 PM.
Posted 06 March 2006 - 10:13 PM
I am putting a black motor in my LJ and it will be rocket red for a little bit of originality but chrome bits too.
Ultimately your choice.
RACV MAN
#11 _Bomber Watson_
Posted 06 March 2006 - 10:26 PM
bitch to keep clean though.
#12 _Keithy's_UC_
Posted 07 March 2006 - 12:14 AM
My 179HP is silver with black KC alloy rocker cover... Here's a pic!
IMHO, its easier to spot oil leaks (not that i have had any yet) and further repair them in due time! I chose silver to compliment the dark blue of the rest of my car...
#13 _devilsadvocate_
Posted 07 March 2006 - 03:56 AM
Edited by devilsadvocate, 07 March 2006 - 03:57 AM.
Posted 07 March 2006 - 09:42 AM
i will get a better pic of it in this weekend
#15 _73LJWhiteSL_
Posted 07 March 2006 - 07:19 PM
Yeah yeah i know, the rest of the engine bay needs a cleanup
Steve
#16 _Bomber Watson_
Posted 07 March 2006 - 07:23 PM
#17 _Keithy's_UC_
Posted 07 March 2006 - 08:40 PM
Car colour is Galaxy Blue pearl
Engine colour is Engine Enamel Silver
Rocker cover is matt black with silver highlights (KC Alloy version)
Edited by Keithy's_UC, 07 March 2006 - 08:42 PM.
#18 _devilsadvocate_
Posted 07 March 2006 - 10:07 PM
Keith there is nothing in the photo that suggests any adr27A stuff,did the photographer get the wrong car. I dont care if you have got it or not, but you think you do but I believe you are mistaken - which could land you in hot water.My UC has the ADR27a gear - just not visible in the photo (cut off by bad photographer)
Which of the below have you got?
line from rocker cover to air cleaner assembly with filter
thermostat valve in aircleaner assembly
vac operated valve on tube of aircleaner connected to flexible stove pipe to draw underbonnet air or preheated air.
Idle stop solenoid
Vac advance solenoid - typically attached to thermostat cover
Thermal vacc switch - attached directly to top of thermostat cover
Cold feed switch -between 2 and 3 spark plugs on head
Switch on transmission for top gear connected to cold feed and vac advance solenoid
Exhaust gas heat valve - valve in exhaust manifold
Exhaust gas recirculation valve - vacc operated, sits on exhaust manifold.
Edited by devilsadvocate, 07 March 2006 - 10:19 PM.
#19 _Herne_
Posted 07 March 2006 - 10:14 PM
For what it's worth I am prepping my EFI engine right now and the colour will be silver with rocker covers and EFI injector covers to be a contrasting colour and as yet still to be decided. I would like chrome but that may have to wait till another day and a few more dollars.
Herne
#20 _SSHatch_
Posted 08 March 2006 - 07:51 PM
oops!! Where did that come from??
Try this instead
This was before I pulled it all out and tidied it up!!
I know that the Chevy Orange and Mandarine Red arent exactly the same colours but it goes to show that you can use similar colours and they dont need to be contrasting like Blue and Yellow for example.
All depends on what effect you are after!!
#21 _Bomber Watson_
Posted 08 March 2006 - 08:15 PM
#22
Posted 08 March 2006 - 11:48 PM
RACV MAN
#23 _BCR42Y_
Posted 09 March 2006 - 07:59 AM
Thanks for all the photo's, i dont have any chrome bits in the engine bay apart from the air cleaner, i was going to get the VN covers polished, and possibly the holley aswell.
I have a picture of the engine when it was blue in the engine bay, but dont know how to post it so it just comes up.
#24 _user asked to be removed_
Posted 13 March 2006 - 06:31 PM
Go for the rocket red, but you can see oil leaks pretty easy I guess....
*Liam
#25
Posted 13 March 2006 - 07:16 PM
What oil leaks?The rocket red looks nuts, but if you want your bay to be cool couldn't you just get that tape that you put over extracters? Forgot what it was called, but they always have it in street machine under the name of COOLIT...
*Liam
Your not putting it on thick enough.
RACV MAN
