Rear Wheel Horse Power
#51 _Yella SLuR_
Posted 29 March 2006 - 12:31 PM
#52 _Keithy's_UC_
Posted 29 March 2006 - 04:09 PM
Keith
#53 _WYLDLC 6_
Posted 29 March 2006 - 04:59 PM
They look sensational, they add power when set up right and you will love the induction noise at full rev's. I used to have a 350 holley now have webers and you can't wipe the smile off my face at 7000rpm. Just go for it.
Cheers Chris.
#54
Posted 29 March 2006 - 06:04 PM
By the way, what'd it cost to get it on the dyno, I wanna have a go...
Les
#55 _Keithy's_UC_
Posted 29 March 2006 - 06:22 PM
The dyno cost $385, but that included pulling my carby down twice, new gaskets, labour to do it yadda yadda.... The cost to do a dyno tune and 3 power runs was $195...
#56 _WYLDLC 6_
Posted 29 March 2006 - 06:34 PM
Good luck.
Chris.
#57 _[BOTTLEDUP]_
Posted 29 March 2006 - 06:41 PM
I think he has SU's and not webers... Personally I'd have the DCOE's but it comes down to $$$
#58 _WYLDLC 6_
Posted 29 March 2006 - 06:46 PM
Cheers Chris.
#59 _Sammy_
Posted 30 March 2006 - 01:34 PM
I originally had the 350 holley on my motor (unfortunately didn't dyno it though) and steped up to the VK EFI and it made a nice improvement, probably in the 10-15hp area, give or take a bit so you should notice a bit more from the su's, probably more top end but hey, why not
i've recently made some changes to the motor in the torry, its now running a smaller cam and VN V6 rockers which are 1.6:1 ratio, so im keen to throw it on the dyno in a few weeks time in the hope i will get a similar figure to the previous 132rwhp, it definately feels better ....
anyways enough of my dribble, good work!! look forward to seeing the quarter results after the dyno!
#60 _Keithy's_UC_
Posted 31 March 2006 - 12:12 PM
As i stated, the dyno bloke would be happy to tune the eyeballs out of it if i had fuel injection and an aftermarket computer!! He rekons i'd see close to a 40rwkW gain (so... about 180 - 190rwHP all up then)...
I dont wanna ruin the heritage of the old girl, so im gonna stay carby though... For a 350 Holley on a 186cu motor - them's some good power outputs!!
Keith
#61 _355lxss_
Posted 31 March 2006 - 12:38 PM
#62 _Keithy's_UC_
Posted 31 March 2006 - 02:40 PM
Keith
#63 _Sammy_
Posted 31 March 2006 - 07:46 PM
anyways i had a opel 4 cylinder in my car so i've #@$^%& all originality just by removing that
im in the process of fitting the VN commodore computer throttle body and sensors to a holden 6, im hoping the tunability of it will give me some ponies along with the fact it wont have the restrictive air flow meter ..... so yeah, intersting times to come ... if i could get anything like 20hp more out of it i would truely be cheering!
#64 _Keithy's_UC_
Posted 01 April 2006 - 12:02 AM
#65 _Sammy_
Posted 03 April 2006 - 01:34 PM
#66 _Keithy's_UC_
Posted 03 April 2006 - 04:42 PM
Keith
#67 _Sammy_
Posted 04 April 2006 - 12:19 PM
#68 _NVMYLH_
Posted 04 April 2006 - 07:43 PM
PS i have 10.3:1 comp, and a 222 degree @.050", and .448" lift cam.
#69 _Keithy's_UC_
Posted 04 April 2006 - 09:21 PM
Note: same for intake and exhaust - all figures that is...
Duration - In & Ex 280
0.050 Duration - In & Ex 217
Cam lift - In & Ex 286
Valve lift - In & Ex 456
Lobe spread - 111
#70 _Sammy_
Posted 05 April 2006 - 01:15 PM
with a cam that big and making those times sounds like you either have the wrong gearing or the head is not up to it. .... rb30 with a few tweaks should go well
#71 _NVMYLH_
Posted 05 April 2006 - 07:47 PM
Edited by NVMYLH, 05 April 2006 - 07:52 PM.
#72 _Keithy's_UC_
Posted 05 April 2006 - 11:29 PM
I launch at 1500rpm and stomp it as the clutch is going out, get wheelspin still, but better traction through first...
I could let my tyres down a bit and get a higher rpm launch... i run 24psi in the rears at the drags... I'm gonna start running 20psi, or 16psi...
Keith
#73 _Sammy_
Posted 06 April 2006 - 01:31 PM
what type of tyres do you guys run ? i have bridgestone SF340 Eagers and they seem to hook up pretty well, i know the Yokies are a bit softer tyre and good for grip but i prefer the all round performance of the eagers .... well used to ... i will have to find an alternative now that theres no more made for my 13's!
#74 _NVMYLH_
Posted 06 April 2006 - 06:06 PM
#75 _Keithy's_UC_
Posted 08 April 2006 - 03:01 PM
NVMYLH, you'll be surprised the difference a couple of psi in the rears will make! Try dropping them to 24psi, then 20... Times and 60 footers will drop!
Cant wait to hear the new motor's times, keep us updated!
Keith
