Few qs..
#1 _draglc_
Posted 16 March 2006 - 08:23 PM
just browsing through VPW, ive decided that i 'need' some stuff
Just a few qs..
i wanna get a carter electric fuel pump, though i cant decide between
Electric Fuel Pump 72gph 7psi $112.89 or Electric Fuel Pump 100gph 7psi $120.79.. The site says 'The 72 GPH ideal for Street/Strip applications or the 100 GPH for race applications'. I plan to use my car for a bit of circuit racing, should i go for the 100gph one? I also drive this car everyday. This is with a 160rwhp 202 with triple SUs.
I also wanna get the alloy rocker cover, but in another thread, high_rpm mentioned that it doesnt fit due to the heater which needs to be modified. Has anyone done this, and is there much to it?
Thanks in advance.
A1
#2 _CHOPPER_
Posted 16 March 2006 - 09:03 PM
#3 _draglc_
Posted 16 March 2006 - 09:26 PM
im just after a nice electric fuel pump that will also suit racing every now and then..
A1
#4 _Aquarius - LC_
Posted 16 March 2006 - 09:29 PM
I have an LC with near enough the same rwhp
& triple su's also. I have been using a carter 72gph
for about 4 years now, it has been great ! No probs
with fuel delivery, oh.. just a tip I rubber mounted mine,
much quieter that way.
#5 _draglc_
Posted 16 March 2006 - 11:28 PM
A1
Posted 16 March 2006 - 11:45 PM
#7 _draglc_
Posted 16 March 2006 - 11:56 PM
A1
#8 _Keithy's_UC_
Posted 17 March 2006 - 11:31 AM
Keith
#9 _draglc_
Posted 17 March 2006 - 12:07 PM
Oh and by the way, does anyone know if the carter pump will come with a mounting bracket?
A1
Edited by draglc, 17 March 2006 - 12:08 PM.
#10 _high_rpm_
Posted 17 March 2006 - 12:37 PM
#11 _Keithy's_UC_
Posted 17 March 2006 - 02:35 PM
I have Yella Terra roller rockers on mine and the KC Alloy rocker cover, i had no trouble getting it on my motor... Unless i've mis-interpretted what your trying to say??
#12 _Leakey_
Posted 17 March 2006 - 02:51 PM
Leakey
Posted 17 March 2006 - 02:57 PM
#14 _high_rpm_
Posted 17 March 2006 - 04:35 PM
#15 _CHOPPER_
Posted 17 March 2006 - 07:55 PM
Last time I checked, 9.2 minutes was less than 60 minutes.Chopps got ya there 72 gph = 1.2 gal per min LJ 11 gal tank will b empty in 9.2 minutes (excuse the math) so i reckon that pumpl keep up with a 202 ay
#16 _Keithy's_UC_
Posted 17 March 2006 - 08:04 PM
Keith
#17 _Aquarius - LC_
Posted 17 March 2006 - 08:14 PM
My carter came with reasonable instructions & a
mouting bracket. Also just a thought on fitting the
alloy cover [i'm still using chrome one with my rollers]
if it's only by a small margin, that it wont clear the heater
box, it may be possible to tilt the engine forward just
enough by temp jacking gearbox up[ if u have engine driven
fan careful of radiator damage], or using a block of wood &
jack, temp remove drivers side engine mount, lowered very
carefully , may just get clearance.
I've looked at mine, i think once the covers on, engine/gearbox
mounted normally, it should just clear heaterbox.
hope this helps,good luck.
#18 _draglc_
Posted 17 March 2006 - 10:05 PM
ill let yas know how i go, and post some pics up when its done.
Thanks for your help aquarius!
A1
#19 _Aquarius - LC_
Posted 17 March 2006 - 11:28 PM
I will be following you progress with interest.
Posted 17 March 2006 - 11:43 PM
#21 _whiteLC_
Posted 18 March 2006 - 12:29 AM
I had to modify my heater box (LC) to get the KC alloy rocker cover to fit (using roller rockers). Just NO WAY it would fit otherwise. I can send some pics if that helps, when I get home. PM me your email address if you want.
I'm going the VK EFI route (inspired by sammy thx Web site here)... if I ever get the F&%$^ing thing finished that is...getting close now tho.
#22 _draglc_
Posted 18 March 2006 - 11:28 AM
and aquariuslc.. could u please tell me exactly where u mounted the carter pump?
cheers guys,
A1
#23 _Aquarius - LC_
Posted 18 March 2006 - 07:56 PM
I went out this arvo, took a couple of photos for you.
I rubber mounted mine so it is just visible, and level with the fuel tank.
It comes down to personal choice, though. You will notice, I have one
fuel filter between tank, and the pump.. and I have second fuel filter
in the engine bay,as close to the carbies as possible.
Hope the photos are ok.
https://cache.gmh-to...02/000_1359.jpg
https://cache.gmh-to...02/000_1365.jpg
https://cache.gmh-to...02/000_1353.jpg
#24 _high_rpm_
Posted 18 March 2006 - 10:10 PM
Edited by high_rpm, 18 March 2006 - 10:10 PM.
#25 _Bomber Watson_
Posted 18 March 2006 - 10:16 PM
just a q, any reason you didn't mount it up the other way, motor facing up?? that way you could have the fuel part lower and the motor up higher, out of harms way....
i'm planning on using something like that to keep my surge tank full and another for the nitrous side of my fuel system, will use a sb chev mechy pump for the carbs....so i gotta fit two pumps, a surge tank and a filter or two in that area....yay.
