Battery Box
#26 _SS Hatchback_
Posted 14 May 2009 - 12:04 AM
#27 _SS Hatchback_
Posted 07 June 2009 - 07:02 PM
#28 _SS Hatchback_
Posted 16 June 2009 - 09:30 PM
Posted 16 June 2009 - 09:32 PM
#30 _SS Hatchback_
Posted 16 June 2009 - 10:21 PM
#31
Posted 17 June 2009 - 08:10 AM
#32
Posted 17 June 2009 - 11:58 AM
#33
Posted 17 June 2009 - 10:15 PM
That's TOPS! You dont do anything by half do you!
#34 _SS Hatchback_
Posted 17 June 2009 - 11:34 PM
Fark Mee Rob! Who did the milling for you!?
I bought it for $140 , its pretty expensive for a battery tray but its probably worth it considering the amount of work in it. Its the only one that fits where i want to put it , hopefully ill get around to installing it properly this weekend . It was just sitting there in the pic.
#35
Posted 18 June 2009 - 07:28 PM
Looks great mate
#36 _SS Hatchback_
Posted 19 June 2009 - 11:33 PM
#37 _SS Hatchback_
Posted 23 June 2009 - 10:15 PM
Posted 23 June 2009 - 10:46 PM
You should be able to get something like this at your local REPCO.
Edited by ls2lxhatch, 23 June 2009 - 10:47 PM.
#39 _SS Hatchback_
Posted 23 June 2009 - 10:52 PM
It is a nice neat and simple setup. I think it would be worth fitting a cover over the battery clamp to reduce that possibility of an accidental short.
Yeah i was thinking of looking for something like that buthavent come acrosss anything yet, I was thinking while putting it together and mounting the top plate on the batt setup that it was a bit to close but there is plenty room to install the plate without any issues.
Just have to be a little careful when doing up the clamps and i do the negative last anyway and like you have mentioned something dropping in it. Even one of those soft red boots on newer cars may be the go.
#40
Posted 26 June 2009 - 12:01 PM
http://www.matson.com.au/covers.html
#41 _SS Hatchback_
Posted 26 June 2009 - 10:06 PM
#42 _WhiteKnight_
Posted 28 June 2009 - 04:58 PM
cheers Keith
#43 _SS Hatchback_
Posted 28 June 2009 - 08:19 PM
Rob if want that stuff just call me mate
cheers Keith
Yes Keith definately after ones like the top type on the matson link. Do you want a close up pic of my terminals to get the correct fitting type? Let me know and ill send one out to you.
I still have to see you about cable when i pull my finger out and get started in rewiring the car, i like punishing myself sometimes
#44
Posted 30 June 2009 - 08:16 PM
cheers Anthony
#45 _SS Hatchback_
Posted 30 June 2009 - 08:22 PM
#46 _WhiteKnight_
Posted 01 July 2009 - 05:26 PM
Sorry Rob i couldn't help with those battery terminal covers.
cheers Keith
#47 _SS Hatchback_
Posted 01 July 2009 - 05:49 PM
#48 _Squarepants_
Posted 01 July 2009 - 07:30 PM
I think that's how it is in QLD.hi all like the pics, just wondering is there any guidlines to follow with putting a battery in the boot for nsw reg my lj already has one in the boot just a plastic battery box bolted down beside the back left wheel arch and i have a bathurst tank aswell so do i need to vent the battery box to the outside of the car or what ? the car is currently unregisterd will a battery in the boot pass a blue slip ?
cheers Anthony
I run a maint. free calcium acid battery that is sealed with vent ports in the covers. I just run a small vent tube from these ports to the outside of the car (in the lower inner rear quater, behind the back wheel).
#49
Posted 01 July 2009 - 08:02 PM
yea that sounds like a good idea with the maint free battery dont like the idea of the other batterys vents in the lids it mite splash or something, like the box that is in it there is corosion on the bottom of the box lucky it plastic il get a new box an carpet it then run a hose down to the bottom of the wheel arch like you said
cheers for the help fellas
