Removing battery tray from LH/LX
#1 _Squarepants_
Posted 13 June 2009 - 03:46 PM
Since I have relocated my battery to the boot, I decided that there was no point having a rusty, crappy looking battery tray in the engine bay.
So I cut it out.
I had to drill a couple of spot welds, but it's mainly grinder work.
I then made up a plate to fit the cut out.
From memory there is a spacer required underneath it for the bumper mounting bracket to bolt up to, approx. 1/2" thick as far as I remember, due to contours of the original tray. I can't remember the exact details of it, but if you're doing this sort of mod yourself, I'm sure you'll be able to figure it out for yourself. It's pretty obvious when your doing it.
This is it all welded, ground back and etch primed...
It gives a cleaner, smoother look to the engine bay and really wasn't that hard.
I hope someone finds this useful and/or inspiring.
Posted 13 June 2009 - 06:18 PM
Posted 13 June 2009 - 08:28 PM
i have replaced both sides of mine i fabricated a new battery tray as every one told me the uc one that rare spares sells doesnt fit
but i did the old mans lh tray using the uc one from rare spares took 10mins to modify and it looks the same as lh/x
Posted 13 June 2009 - 08:46 PM
sorry to take over ur post just thought i would show my replacements
#5 _Squarepants_
Posted 13 June 2009 - 09:46 PM
wouldnt it have been easier to drill spot welds and remove and fabricate new panel???
That's what I did. Did you even read the post??? Unless you are talking about the whole inner guard, in which case, No, it would not have been easier.
Mitch, it is finished, it has been for like 2 years, look here: http://www.gmh-toran...showtopic=36330
I posted this to try to make use of the new "Fabrication" section as it hasn't seen much action yet.
Posted 13 June 2009 - 10:03 PM
#7 _ass308_
Posted 14 June 2009 - 07:48 AM
#8 _Squarepants_
Posted 14 June 2009 - 08:14 PM
Are you confusing it with an LC/J battery tray?i meant the battery tray its spotted in place from factory
#9 _nial8r_
Posted 14 June 2009 - 08:26 PM
any neat job on the replacement of the batter tray to dude but i think i will be drilling all the spots out and where it over laps onto the rail i will do a neat butt joint weld so it can be smooth all the way from the firewall to the support, just my opinion, shoot me down if need be....
#10 _mello92_
Posted 17 June 2009 - 10:56 AM
Edited by mello92, 17 June 2009 - 10:56 AM.
#11 _nial8r_
Posted 17 June 2009 - 01:11 PM
Lee, in regards to that number, you could just cut the number out of the old section, clean it up, and weld it into the new piece. I havent done that, just what Ive heard.
Mello92 thats what i think i would have done but then i have to think of when i paint in the engine bay that number is gonna disaper under the coats of paint ??? just when i think i have one problem solved another pop's up !!!
Posted 17 June 2009 - 01:55 PM
have to make sure u use 8mm stamps not that easy to cum by these days
#13 _Squarepants_
Posted 17 June 2009 - 10:27 PM
You can still see them under a light coat...Mello92 thats what i think i would have done but then i have to think of when i paint in the engine bay that number is gonna disaper under the coats of paint ??? just when i think i have one problem solved another pop's up !!!
Mask it up and paint the rest of the bay, then pull off the tape and give it a light coat over the top.
#14 _mello92_
Posted 17 June 2009 - 10:58 PM
Thats what I was gonna suggest. That bit doesnt need heaps of layers, really.
#15 _nial8r_
Posted 18 June 2009 - 08:11 AM
Posted 18 June 2009 - 08:12 AM
Agreed.
Whenever you paint an engine bay you should always make sure that the chassis number can be read. The last thing you want is to be stopped by a police officer or an RTA inspector who wants to read the chassis number but can't. So what happens then is they can direct you to the have your pride and joy booked in for "identity check" to try and find the number. So you roll up to where you need to go and then they start scratching the paint off where the number should be. Nothing worse than having to touch up an engine bay which has had paint scratched off it only to reveal that the chassis number was there in the first place but was covered by layers of paint.
Edited by Ruts, 18 June 2009 - 08:18 AM.
#17 _moot_
Posted 18 June 2009 - 02:49 PM
#18 _moot_
Posted 19 June 2009 - 02:59 PM
by the time i have primmed and painted the bay in 2k im pretty sure the number will be none-more
you'll have alot of trouble at rego time if your chassis number has been re-stamped.you might wanna cut around it like i did
Posted 14 August 2009 - 07:57 AM
