torana guy, a wastegate only vents burnt gasses (exhaust) back into the exhaust so it doesnt go through the impeller. a blow off valve would be dangerous on a draw thru setup because it would vent fuel/air directly into the atmosphere. I cant see any problems with controlling the boost with an adjustable wastegate, but I also dont deal with turbos all that often.....
Boost controller and adjustable wastegate are two differant things!
A wastegate is actuated by boost pressure from your manifold, in a draw thru setup that also happens to be a combustible air & fuel mixture.
To controll the boost level in a setup where the wastegate is set, you plumb in a boost controller, which limits the pressure the wastegate "sees" and means the wastegate stays closed longer, for higher boost. You have to bleed this somewhere, in a blow thru setup the guys usually just bleed it to the atmosphere, but you can't do that in a draw thru setup.
I've already got a 42mm wastegate, to get an adjustable one would cost me a lot, i looked at the idea, and for now it's just not affordable. In the future maybe.
ToranaGuy
Edited by ToranaGuy, 01 December 2005 - 11:17 AM.
