Well ryan i have been buying parts! as there is no way i am puting a rice motor in it, the JL is coming out and a blue.6 3.3 turbo is going in this is the partsHey all im not really a turbo fan but i have seen some good power figures from turbo 202's and im thinking in a torana this would be fun for an every day driver
i no its been done b4 but what sorta engine/turbo/trans combo's are people running and what sort of power do they make? what needs to be looked at with the engine to keep it in one piece?
whats really got me interested is that i've heard of people using the wastegate to control boost, so one minute they have a virtually stock car then with a flick of a switch its goes like stink. how true is this?
im thinking of running engine on gas with the fuel prices atm.
all thoughts would be appreciated
cheers ryan
i used ,and machine work being carried out now.
BOTTEM END
Blue 3.3 block crank/rods all crack tested, line bored closed+honed main caps
Block :40 over+decked+groved o,ringed,deburred oilpassers+inlarged ,full stud kit
Crank:deburred/polished+knife edged counter waits,blanced, chamford oil passers
Rods:resized,deburred+polished machined for full floating pins,balanced .ARP bolts
pistons: custom aries full floating forged decomp/dished tops ,hastings Cr rings
JP,H/V oil pump,custom baffeled 7 litre sump+ big pick up+big arse oil cooler
Iven tie! turbo grind solid cam+crow lifters. straight cutts ,Cr manly push rods
Romaci race blancer, Y/T 18lb flywheel dowlled to the crank shalft new bolts
IgnitionMSD6al BTM boost timing master,two stage rev limiter, bluedizzy msd leeds
msd coil
Thats $4.000^^^ so far no turbo hopefully it wont handgrenade at 15=18 psi. i havent decidead on the head but the NEW YT12 port sounds nice!looking for 300 to 340 hp out of this motor not that much reaily? thats all u need in a street LJ
And those that want to no! the turbo is a garret T66/ custom manifolds yet to be made, by me and a mate using one of his lc toranas with a dummy block, this is going to be a draw thought set up using a holley660 ss D.P much the same as the pic,s above. i will post pics of us building the manifolds in the coming months
cheers dave.........
