replacing steering bush with uni joint
#26
Posted 04 October 2009 - 08:04 PM
Mine had solid mount steering rack and urethane mounting bushes before I changed, however I must admit I never gave it much thought.
#27 _mowie_
Posted 07 October 2009 - 12:07 PM
Tom
#28
Posted 07 October 2009 - 12:46 PM
As for the comfort angle, that was the idea with the LH/LX steering rack bushes but they ended up back-pedalling on that one. Commodores don't have rag joints
#29 _mowie_
Posted 07 October 2009 - 01:13 PM
#30
Posted 07 October 2009 - 03:35 PM
There are other styles of vibration reducers available for Hot Rod builders and replacing rag couplers.
Edited by ls2lxhatch, 07 October 2009 - 03:36 PM.
#31 _stu.slr_
Posted 07 October 2009 - 08:12 PM
#32
Posted 08 October 2009 - 06:15 AM
#33
Posted 08 October 2009 - 12:57 PM
#34
Posted 08 October 2009 - 02:42 PM
#35 _stu.slr_
Posted 08 October 2009 - 10:47 PM
p.s. extractors going in at same time so cant have 'nolathane ' coupling. way easier when motor is out of car
Edited by stu.slr, 08 October 2009 - 10:54 PM.
#36
Posted 09 October 2009 - 12:04 PM
Do you spline it or keyay it?
Maybe a sticky?
#37 _Herne_
Posted 09 October 2009 - 12:11 PM
Someone above (cant remember who) commented that it would be harsh on the driver on a long trip. Wrong, its fine
Herne
#38
Posted 09 October 2009 - 01:40 PM
The rag coupler and uni use the same cotter pin setup. It is basically a matter of swapping one for the other. The only modification required is to trim about 10 mm off the end of the steering rack shaft so the cotter pin in the uni will line up with the pad on the shaft.For those that have done this, what do you use for the middle shaft?
Maybe a sticky?
Yes it is that simple, only mod is to cut the excess off the steering rack input shaft (it doesn't do anything no matter what coupling you use). Its probably a fair bit easier to to do this with the rack out of the car, otherwise no more difficult than replacing the coupling as normal.
Edited by ls2lxhatch, 09 October 2009 - 01:42 PM.
#39
Posted 09 October 2009 - 02:08 PM
As with the diff and brakes, I'm sure Rory has done the step-by-step with pictures version somewhere...Maybe a sticky?
edit: maybe not, I can't find anything - may have been thinking of rodomo's lower column bearing mod thread (who knows what I'm thinking, its Friday afternoon)
Edited by 76lxhatch, 09 October 2009 - 02:19 PM.
#40 _rorym_
Posted 09 October 2009 - 08:03 PM
The rack needs a narrowed 1/2" bit on the end knocked off slowly with a angle grinder...this allows the new knuckle to slide on further to engage the key/pin slot..get a rack..you will see what I mean.....as stated..no more mods...the little half shaft is reused with the new 2nd knuckle...thats it...
The sticky on the diff is at the top of the Driveline thread...The brakes are a sticky at the top of brakes threads.
knuckle.jpg 261.24K 36 downloads
As in the pic...on the rack end..if you dont cut the 1/2" off...the knuckle wont slide down far enough.
Brakes
http://www.gmh-toran...showtopic=38028
Diff
http://www.gmh-toran...showtopic=29806
#41
Posted 26 December 2010 - 08:14 PM
#42 _bunkerjest_
Posted 26 December 2010 - 09:18 PM
#43
Posted 26 December 2010 - 09:49 PM
I guess its possible if the uni is really sloppy but seems unlikely, I'd be looking elsewhereMy LJ has had a LX steering uni put in place of the original rubber coupling, when I go around 110 kph the steering wheel shakes as if the tyres need to be balanced which I have had done 3 or 4 times which has made no difference. Could the steel uni be to blame or would it be a steering rack problem, how do you check the rack for wear.
#44 _DrFegg_
Posted 26 December 2010 - 09:55 PM
Ive had my column/shaft out and have carried it vertically without the pins shearing. The column would likely have been in a vertical position during racking and installation. It would have been engineered to require a certain amount of force to collapse and more than just its own weight. Also rust would not stop the shaft from collapsing in an impact. As for equating cost for the coupler, this would have been most likely bought from a supplier as one piece, disassembly and recycling would not be factors, just comparitive piece cost.Sounds like most like the second uni idea and I suppose steering response would be better, but I'm not so sure, long term.
My thinking is, if your gonna do it you should have urethane subframe & steering rack bushes installed first.
Otherwise any movement is going to travel up the shaft and cause either the colapsable center shaft to break its
plastic pins and move or pop your coffee pot bearing at the to top the shaft.
On the safety and legal aspect, I suppose Toranas being so old either the plastic are already broken or more than likely
the colapsable shaft is rusted on the inside and wont colapse anyway.
Therefore I would say the original flexible joint has some safety merits as well, by providing some possiblity
of absorbsion/movement or tearing to is some way dimminish the forward movement of the steering wheel crushing your chest
in an accident.
Anyway thats my thinking and if these rubber kits Dattoman are any good, all the better.
Food for thought.
#45
Posted 27 December 2010 - 12:58 AM
in an accident.
Food for thought.
I believe you're on the money there DR Fegg,
The steering shaft will not collapse under it's own weight if held vertically. The two plastic pins are designed to shear in the event of a sudden impact.
I read that it takes approx 15lbs p/sq" of static pressure to shear the pins (but don't quote me on that my memory is not quite what it used to be)
I doubt that a collapsible steering shaft that is currently in service and not directly exposed to the weather would ever be rusted so badly that it wouldn't collapse in the event of a sudden impact
I reckon when Toranas' were made recycling wasn't even a word in the English language, LOL.
AFAIK the flexible couplings serve two purposes, 1st and obviously is to allow for angular misalignment of the steering and pinion shafts and 2nd is to dampen road shocks transmitted through the steering gear, GMH further enhanced this by mounting the LH/LX steering rack on rubber bushes.
Naturally the bean counters play their part in every decision about parts being used in production of a vehicle.
Dave
#46
Posted 27 December 2010 - 07:28 AM
I think that an RTS front end with more caster than factory is going to track better and give less issues with twitching at higher speeds, so perhaps the damping action is most important on pre-RTS cars with zero/negative caster?AFAIK the flexible couplings serve two purposes, 1st and obviously is to allow for angular misalignment of the steering and pinion shafts and 2nd is to dampen road shocks transmitted through the steering gear, GMH further enhanced this by mounting the LH/LX steering rack on rubber bushes.
