what is your holden 6 combo
#1 _rb3torana_
Posted 13 January 2010 - 06:43 PM
Induction
Exhaust
Cam
Compression
Head
Power adders
1/4 mile and mph
Driveline
#2 _rb3torana_
Posted 13 January 2010 - 06:48 PM
Induction holley 600 vac
Exhaust 1 3/4 primaries 6>1 3 inch collector half way under 3 inch into 2.5 inch
Cam 275@50 solid with 540" lift
Compression 11.2-1 soon to be 12
Head ported 9 port 161 head large valves
Power adders n/a
1/4 mile and mph 14.8@93mph vk commodore pulp 95
Driveline m22 4 speed stock 3.08 gears open wheeler
#3 _Bomber Watson_
Posted 13 January 2010 - 06:50 PM
Sounds interesting.
#4 _beergut_
Posted 13 January 2010 - 07:00 PM
estimated speed off ute and into tip=30secs@5mph
lol
Posted 13 January 2010 - 07:21 PM
Induction 465 Holley
Exhaust Extractors, no exhaust fitted as yet, neighbours not happy
Cam Crow cams 35616 IN. 40/80 EX.80/40 dur 300 050 dur 240 lift .450" range 3500 6800 rpm
Compression 10.2 to 1
Head Red 9 port, converted to 12 port, small combustion chamber
Power adders nil
1/4 mile and mph not run as yet
Driveline Exedy clutch, Aussie 4 speed, ratios 2.54, 1.83, 1.25 1.1 Banjo LSD running 3.9 gears
Edited by debkar, 13 January 2010 - 07:23 PM.
#6 _CraigA_
Posted 13 January 2010 - 08:19 PM
Induction: Triple 45mm Webers on Warneford manifolds
Exhaust: HM headers, 2.5" system, low restriction dual 2" outlet muffler
Cam: Crow cams 35803 IN. 34/68 EX.70/32 dur 246 @ 050 dur 246 lift .490" range 3000 6400 rpm
Compression: 10.5:1
Head: Superflow small combustion chamber 9 port with additional porting
Power adders: NIL
1/4 mile and mph: 14.2 @ 96mph with old engine, TBA with this one but want a low 13.
Driveline: RPM Cushion Button Clutch, YT lightweight flywheel, M20, 3.55 LSD
Edited by CraigA, 13 January 2010 - 08:20 PM.
#7 _rb3torana_
Posted 13 January 2010 - 09:06 PM
Geeze that cam has stupid duration, but not so much lift?
Sounds interesting.
yeah i know it does seem kinda huge lol, wont idle below 1400rpm lol, although i did try a smaller stick 245@50 and it didnt go aswell, i know it makes no sense but yeah. needs more comp with this cam, I can run up to 39 degrees timing without detonation on pulp95 lol.
#8 _OLC383_
Posted 13 January 2010 - 09:22 PM
Wayne
Posted 13 January 2010 - 09:26 PM
#10 _rb3torana_
Posted 13 January 2010 - 09:37 PM
rb3torana,(is this Tim) maybe try some of that E85 fuel, it'll need 20% more on the fuel supply, but should handle a heap more timing, works a lot like methanol in its delivery needs heaps more fuel but should gain more power over ULP.
Wayne
yeah it is lol.
itll be good when we actually can get it readily available in qld, bring on 13:1 comp lol.
with the cam size thats in it it could prob handle 12.5:1 with alot less timing and should make more power.
have to wait and see gota start building a new motor, been through 1 crank(huge cracks in no6 big end gave it 10 lightish hits with a hama and it broke clean off :0)
put another blue crank in it, been in for bout a month and its starting to vibrate again grrr, and yes the flywheel is still tight lol.
Posted 13 January 2010 - 09:46 PM
275@50] solid with 540" lift
#12 _OLC383_
Posted 13 January 2010 - 09:48 PM
Wayne
Edited by OLC383, 13 January 2010 - 09:51 PM.
#13 _rb3torana_
Posted 13 January 2010 - 09:55 PM
Give Marielli performance in Belar st Yamanto or Churchill a call (07) 3812 0544 they sell E85, around $54 for 20ltrs,so ive been told ( they might do a 200ltr drum) we were going to try it before we went to methanol,wasnt worth the stuffing around sorting out the fuel system then changing to methanol.
Wayne
good to know thanks
#14 _monaroman68_
Posted 13 January 2010 - 10:24 PM
Induction-500 Edelbrock 4bbl
Exhaust-Pacemakers to 2.25"
Cam-Crow hyd 616 40/80
Compression-10.6
Head-Blue 173 12 port
Power adders- nil
1/4 mile and mph- 14.3 @ 94 mph
Driveline- M20 3.55 bango
Posted 14 January 2010 - 12:31 AM
Induction - triple 45 doce
Exhaust- 2.5" old genie extractors
Cam- crow solid stage 4 grind 3000 6000
Compression- 10.1
Head - 186 ported polished
Power adders- nil
1/4 mile and mph- first time out 13.7 99mph didnt get out of third gear.
Driveline- M21 rpm clutch banjo 3.36 waiting on new 3.9 gears.
Posted 14 January 2010 - 06:37 AM
Induction 2" SU's Armours manifold
Exhaust Custom 1.5" primaries
Cam 252 duration Camtech
Compression 10.8
Head Small chamber 12 port
Power adders
1/4 mile and mph 12.71 @ 104mph
Driveline Button clutch, Saginaw, 4.1 diff
#17 _CraigA_
Posted 14 January 2010 - 10:48 AM
Posted 14 January 2010 - 11:00 AM
Taking mine for another run in the next couple of weeks hoping to get a bit more out of her yet.
Wondering how drag lc is going with his new build.
And how far away are you from running yours graig.
#19 _CraigA_
Posted 14 January 2010 - 11:19 AM
Probably March or so.
I'd also love to hear how Hayden is getting along. I always watch his work with keen interest, as I have done with Grahame from NZ.
GTR600 , it will be interesting to see how yours goes with a shorter diff ratio.
Posted 14 January 2010 - 12:42 PM
Induction webers on a shitty lynx manifold
Exhaust 1 5/8 primaries down to 2 1/2
Cam 256 @ 50 roller
Compression11:1
Power adders none
1/4 mile and mph 12.21 @ 109
Driveline supra 5 speed 9 inch 4.88 gears.
in an FJ
230rwhp on pump fuel
#21
Posted 14 January 2010 - 01:46 PM
still not sure on rim sizes 14" or 15" will be trying both i think.
I always thought warrenm was on top as far a six went in the timeslip section
but the trussty old eh is that bit quicker and running that heavy 9" too.
Is that a daily driver greens nice.
#22 _rb3torana_
Posted 14 January 2010 - 02:34 PM
Engine 202 bored 60. blue crank, rods and acl's. 9 port
Cam 256 @ 50 roller
Compression11:1
Power adders none
in an FJ
how heavy would the fj be in race weight?
#23
Posted 14 January 2010 - 03:36 PM
lol it's a gasser! Don't think it has regoIs that a daily driver greens nice.
#24
Posted 14 January 2010 - 07:08 PM
eh is getting there, got some 2 inch su's for it so yeh, if it doesnt run 13 flat off the trailer theres something wrong.
the fj is about 1020kg, still not under factory fj, doh, o well, its got ute rails and extra strengthening everywhere.
and heath, not a gasser yet, its still on petrol !
cheers guys
#25 _ChevLX_77_
Posted 14 January 2010 - 07:21 PM
Induction: firestreak 2 barrel manifold
Exhaust: Jet hotted pacemakers into atmosphere
Cam: Yeah its got 1
Compression: around 11.1
Head: Ported 9 port
Power adders: 100hp shot of giggle gas
1/4 mile and mph: 10.4 @127mph
Driveline: 2sp 6cyl 'Glide 9 inch
