I've got a set of VN commodore struts
#1 _Keithy's_UC_
Posted 22 April 2006 - 02:30 AM
Could i convert the front end of my car to commodore pattern??
Obviously i would do the rear to compliment...
Keith
#2 _CHOPPER_
Posted 22 April 2006 - 10:58 AM
#3 _Keithy's_UC_
Posted 22 April 2006 - 06:16 PM
Money is not an option, but i would like to do it myself if parts can be sourced...
Keith
Posted 22 April 2006 - 06:46 PM
#5 _Keithy's_UC_
Posted 22 April 2006 - 09:32 PM
#6 _brett_32i_
Posted 23 April 2006 - 08:06 PM
ford height is a lot lower...
#7 _Sammy_
Posted 25 April 2006 - 10:02 AM
#8 _CHOPPER_
Posted 25 April 2006 - 10:17 AM
#9 _Keithy's_UC_
Posted 27 April 2006 - 04:08 AM
If i use commodore drum stubs on the front, it should be ok?? And for the rear, i have access to a complete VL Commodore rear end, is it more so just a matter of shortening the setup and modifying the parts, or is it more a job for the machinist??
Keith
Posted 27 April 2006 - 10:47 PM
You'd need Torana drum stubs
Then have them modified to suit the bracket
Then you need to buy the bracket and use the rest of the brake system off the struts you have
Then you throw the struts away (spindle that holds the bearing is part of the strut and not removable)
Or you could sell the struts to someone else and use the procedes towards a Hoppers kit that will bolt straight to your existing disc brake Torana stubs
#11 _Keithy's_UC_
Posted 03 May 2006 - 03:47 PM
#12 _Sammy_
Posted 04 May 2006 - 01:40 PM
Posted 04 May 2006 - 04:33 PM
#14 _[BOTTLEDUP]_
Posted 05 May 2006 - 06:21 PM
#15 _Keithy's_UC_
Posted 06 May 2006 - 09:26 AM
#16 _[BOTTLEDUP]_
Posted 06 May 2006 - 04:52 PM
#17 _Sammy_
Posted 09 May 2006 - 03:50 PM
im keen to trial fit it all, i just need some drum stubs, but none seem to be available anywhere
#18 _CHOPPER_
Posted 09 May 2006 - 07:32 PM
#19 _Sammy_
Posted 11 May 2006 - 02:24 PM
Thanks Chopper!
#20 _CHOPPER_
Posted 11 May 2006 - 06:33 PM
#21 _Sammy_
Posted 12 May 2006 - 10:35 AM
#22
Posted 12 May 2006 - 05:10 PM
Up to you though, I dont know your plans.
Chopper, do you still want those CRS adaptors for these drum brake stubs? I really would prefer to see them go to a good home - the spiders are building their webs in them in my garage.
M@
#23 _CHOPPER_
Posted 12 May 2006 - 09:39 PM
#24 _Sammy_
Posted 15 May 2006 - 03:06 PM
yes they are the same height as the torana stubs just with the HR/HQ KPI ... it does add a bit of extra camber to the front end, but it doesn't seem to bad, should be able to fix it with removal of shims atleast enough to give good handling (i hope) without too much effect to tyre wear.
i also had the thought, if i drill the front end to have the upper control arms sit 1 inch lower which i believe is A9X spec this should push the top of the stub axle out, as the car sits now the upper control arm is pointing down as it moves out towards the stub axle, so that should help with KPI and also mean as you corner more camber will pack on .... anyways im going to have a bit of a scope out of some other calipers etc but so far this is what looks like it will work ok ....
hr drum brake stub axle with commodore brake adaptor.
now with VK disc and caliper.
now i think this mag suits the car really well, all be it needing a smaller tyre! either way it all fits under the guard ok and clears everything else other than the front of the guard when you turn - please disregard the caliper on the rear of the stub axle, i was checking both ways to see which was the best for clearance (front wins)
bit of an idea how it all goes together ....
so yeah, i'd say i'll probably end up going for this option, just need to test a few more caliper theories i have .... and i will report back.
also need to find some more mags, if i use these on the torana then i need to get mags to hold up the FB UTE (project in the shed)
Edited by Sammy, 15 May 2006 - 03:09 PM.
#25 _CHOPPER_
Posted 15 May 2006 - 06:54 PM
No. KPI is set. It may alter the camber change, but whether it would be noticeable or not is another matter. But it should give you a bit more positive camber, or remove some negative camber.I also had the thought, if i drill the front end to have the upper control arms sit 1 inch lower which i believe is A9X spec this should push the top of the stub axle out, as the car sits now the upper control arm is pointing down as it moves out towards the stub axle, so that should help with KPI and also mean as you corner more camber will pack on ....
