The Car Trailer.
#1 _gen3torrie_
Posted 30 June 2010 - 10:53 PM
me and a mate got talking last night (he builds patios for a living)
we were discussing making a car trailer
what would be the legalitys and what would be a good way of making one do they make trailer kits for them....
i haven't really done any homework into it but from what i hear its alot more cheaper then buying a brand new one or one out of say the autotrader, quokka
i guess what im asking is has anybody got plans or blueprints or even can give me step by step instructions on how to build one
i need it to tow comfortably behind my VT which has a 2100 rated Reese Hitch, i have towed a few trailers behind it and theres one that i hire from classic hire in kelmscott and its such a lightweight trailer it sits behind me no problem even loaded up with a full car
but all im going to be towing with it most of the time would be my Torana, but i do want it to be able to tow other things as well
so should i have it braked or unbraked or what should i do, any suggestions???? maybe even buying buying a bunky car trailer and restoring it or would building one from scratch be the cheapest?
Posted 30 June 2010 - 10:57 PM
SO thats out unless your carrying a very light car
So it must be braked
#3 _gen3torrie_
Posted 30 June 2010 - 11:00 PM
Posted 30 June 2010 - 11:09 PM
Posted 01 July 2010 - 01:01 AM
When I researched building the torailer, I came across heaps of plans for building trailers and it came with lists of everything needed to pass a roadworthy all from a google search.
Unfortunately none of this info is on this computer, but from the top of my head:
- Full brake, reverse and indicators
- Reflectors on the front and rear of the trailer
- Braking systems required if full load weight exceeds 700kg on single axle, 2 axles if full weight exceeds 1250kg.
- Arches covering wheels/tyres
- Weight ratio of 70/30 towards front of trailer.
As I said these are off the top of my head so may not be 100% and they are for NSW rules and regulations. May be different in WA.
Ill try and find some info, but i think that computer went bang
Posted 01 July 2010 - 08:50 AM
Posted 01 July 2010 - 09:30 AM
Posted 01 July 2010 - 10:00 AM
Id just buy a trailer, if something falls apart off your trailer and kills or hurts someone you could be sued for millions.
Posted 01 July 2010 - 10:46 AM
To avoid making something that comes together and ends up being shithouse to tow, try and get some nice magic number dimensions off other people who have built them before. Or you can pretty much do a replica of someone else's
But you seriously need to sort out your projects. Reach a milestone before you start thinking of building other things that you want. You say you work all the time, so you must have a bit of money for hiring trailers on the odd occasion that you need to do so. Pay off your stupid loan, put a grand aside for building a trailer later on, get one of your cars sorted. That's my opinion
#10 _niterida_
Posted 01 July 2010 - 11:12 AM
any one who has seen my trailer knows its pretty heavy duty it is heavier than most and car sits higher but because the wheels sit directly over the trailers wheeels it tows very well and makes it easy to see whose behind you ect
Got any photos of this ? I have a flat tray trailer that is real heavy duty and I was going to turn it into a car trailer, but it sits too high with the wheels under the tray. It sounds like you have this same set up but didn't push the wheels outside the tray to lower it like I was planning to do.
If I read your post correctly your trailer wheels are basically the same width as your car and the car sits over the top of them ? If I could do that to mine it would save me a fortune :-)
Posted 01 July 2010 - 11:39 AM
#12 _Woodsy_
Posted 01 July 2010 - 11:53 AM
#13 _niterida_
Posted 01 July 2010 - 11:57 AM
Here is my car on mr5000's trailer
Thanks Heath.
Looks nothing like mine or how I envisioned mine will look when converted. So it tows OK sitting up that high - that was my main concern that it would be top heavy and want to fall over in corners, or adversely affect the handling ??
Mine is a completey flat tray so the car will probably sit up a bit higher than on mr5000's by a couple of inches maybe. but the way it is built underneath it is too hard to do it any other way - it would be easier to build a new trailer. Its a really strange looking thing - the tray is 4.8m long x 1.8m wide and it only has a single axle. It also has pool fencing at 1.8m high all the way around it so it looks like a circus lions cage :-)
I will post a pic when I get home next week.
The plan was to remove the fencing and replace the single axle with two wider ones to drop the height of the tray down as low as possible, but if I can just add a second axle that would be sooooo much easier.
Posted 01 July 2010 - 09:11 PM
You do have to look after the lighter trailers and not overload them which is why the hire places build Sherman tanks, but I'd still say that lighter is better. Last hire trailer I used must have literally weighed the best part of a tonne by itself - there was little difference in feel with a car on it, it was ridiculous! There's no way i would even consider towing that kind of behemoth with the likes of a Commodore or Falcon, it would be downright dangerous, whereas something suitably smaller and lighter could well be safe to.if ay gonna build your own dont go cheap on the materials i hear every one says lighter is better i dont trust the lighter ones coz a few ive borrowed and hired have been half rooted cos the steel is to light weight
Posted 01 July 2010 - 09:26 PM
Can't say I'm a fan
#16 _gen3torrie_
Posted 01 July 2010 - 09:55 PM
in the shoutbox i did mention my welding is alright... me personally i will just be touching the mechanics side of things
i have decided to go with electric brakes... speaking to the boss today his mate lost his porsce 944 race car off the side of roleystone hill because of those dodgy hydraulic brakes...
i have access to boxed steel which is what my trailer will consist off...
too keep weight down i will not be using a sold floor instead a ribbed type of floor as they can be useful for strapping down as well as working on whilst on the trailer
a mate of mine is going to give me his old tractor trailer so i can base it off that
#17 _Woodsy_
Posted 01 July 2010 - 10:14 PM
#18 _rorym_
Posted 01 July 2010 - 10:31 PM
is that driving over an artificial hill?
Try this.
http://www.nevco.com.au/nevco/productDetails.php?productId=1
Posted 01 July 2010 - 10:59 PM
Posted 02 July 2010 - 12:27 AM
And you say your mate builds patios god help us all.
#21
Posted 02 July 2010 - 12:00 PM
Or because he's young?
Or just because that is what you genuinely believe? And you would recommend that to anyone?
If I asked the same question as Josh asked in this thread, and you gave me that response. I would be very unhappy.
Edited by Heath, 02 July 2010 - 12:06 PM.
#22 _Kush_
Posted 02 July 2010 - 12:48 PM
#23 _Woodsy_
Posted 02 July 2010 - 04:26 PM
#24
Posted 02 July 2010 - 04:58 PM
#25
Posted 02 July 2010 - 05:00 PM
Edited by mitchg, 02 July 2010 - 05:01 PM.
