The Car Trailer.
#26 _Kush_
Posted 02 July 2010 - 05:37 PM
#27
Posted 02 July 2010 - 06:05 PM
#28 _Kush_
Posted 02 July 2010 - 06:27 PM
#29
Posted 02 July 2010 - 06:40 PM
Are truck trailers and bogies the same?
No, a truck trailer can either be single axle or bogie.
#30 _Kush_
Posted 02 July 2010 - 06:58 PM
#31 _gen3torrie_
Posted 02 July 2010 - 07:58 PM
once i have time and more money i will start to build this but the torana needs to be finished the ute needs to get the 5litre and the shed needs an extension before all this happens
they need to be built to ADR Requirements i'm basically making a replica of another trailer
ie lights in properly fitted posistion... good structure decent axles brakes blah blah blah
and as a requirement you need to have it weight tested and stamped with the TARE weight
Edited by gen3torrie, 02 July 2010 - 07:58 PM.
#32
Posted 02 July 2010 - 09:28 PM
Mr gen3 first stop for you is the transport buiding ask for the current design and construction requirements for trailers in WA.
Now excuss me as I havent made one in Wa but made a few plus a covered one for my hatchback in Rocky QLD 1996 to be towed behind my bus. I now reside in Kalgoorlie.
Mr gen3 making a structual car transporter envolves prior planning. Once you have read WA requirements you will understand its not just a matter of getting a caravan frame and presto. Stear clear of this idea. Some requirements need to take into consideration trailer hitch rating, length, width, clearance markers, lighting, Draw bar position, length.
Axel placement from centre of trailer for good towing, there is a rule of thumb every foot of length set 1/2 inch back from centre.
Even the way you position structual floor beams to reduce sag from carring weight after continual use. Brake away chains and size.
Brakes - electric require a a separte system another battery on trailer to activate brakes in the unfortuate event of trailer leaves vehicle.
Other words trailer brakes apply when trailer goes for ride by its self.
And all this cost losta money My enclosed carter back then cost roughly three grand not incuding my labour and consumables.And yes it would be nice to know that the car trailer traviling down the TONKIN beside my pride and joy has been welded together by a competant welder its one thing to do panels and another when it comes to structual strength.
Well thats my 2cents worth more like 5cents come in hard on me first post. Down the track I will post picts of my SS 6th and final rebuid only had her for a short time 27years.
#33 _Kush_
Posted 02 July 2010 - 10:30 PM
#34
Heath its all about safety mate not having a dig at josh read ss hatch post above thats what its about G.Did you word that that negatively because it's Josh?
Or because he's young?
Or just because that is what you genuinely believe? And you would recommend that to anyone?
If I asked the same question as Josh asked in this thread, and you gave me that response. I would be very unhappy.
#35
Posted 02 July 2010 - 10:43 PM
reason why i jumped on that one is ive hired a few trailers and had them bust and one even buckle cant ever see this one having anything like that happeningYou do have to look after the lighter trailers and not overload them which is why the hire places build Sherman tanks, but I'd still say that lighter is better. Last hire trailer I used must have literally weighed the best part of a tonne by itself - there was little difference in feel with a car on it, it was ridiculous! There's no way i would even consider towing that kind of behemoth with the likes of a Commodore or Falcon, it would be downright dangerous, whereas something suitably smaller and lighter could well be safe to.
if ay gonna build your own dont go cheap on the materials i hear every one says lighter is better i dont trust the lighter ones coz a few ive borrowed and hired have been half rooted cos the steel is to light weight
also being that high up you do notice it if you go over a 100 ks but personally i dont really go that fast towing
apart from that it tows realy well im gonna put some tool boxes under those cut outs put tarps jacks ect also all my tie downs chains ect
fuel economy with stato towing a torry is not to bad dont even use a full tank to heathcote and back
#36
Posted 02 July 2010 - 10:57 PM
I've met plenty of people who have built their own car trailers in their backyards, had them registered in Victoria, everything legitimate, and none of them have needed to spend over $2000 on materials. That would cover a welding course at TAFE as well if you needed it.Heath its all about safety mate not having a dig at josh read ss hatch post above thats what its about G.
If everyone had the same attitude you had in that first post, nothing innovative would ever be thought up or constructed.
#37
Posted 02 July 2010 - 11:30 PM
You will see so many different configurations of car trailer that all seem to be "doing the job".
You'll get some great ideas to suit your needs.
It's almost as interesting as looking at the cars.
But, as mentioned above, make sure it's legal to avoid any dramas.
#38
Posted 02 July 2010 - 11:43 PM
I cant see you putting one together using new components for 2 grand or less,especially if you decide to fit
electric brakes,.Sorry.
#39
Posted 02 July 2010 - 11:57 PM
the cost of mild steel has amost doubled in 18 months.
That's interesting.
I took a trailer load of steel to the scrappy 3 years (or so) ago and came out with about $60
Most of it was panel steel, a radiator and a battery.
Then, 12 months ago I went again with more panel steel and a battery.
They paid me for the battery and that was it.
They have a sign out the front saying they'll take this, that and the other metal but no mention of steel.
The tip will take the steel with no charge.
#40
Posted 03 July 2010 - 12:01 AM
Find another scrappy.An aquaintance of mine drove a buggered XD wagon to the scrappys round here and walked home with $280.
#41 _SS Hatchback_
Posted 03 July 2010 - 12:51 AM
It dropped in price for a while,but its gone way up again.
Gee $280 for a XD wagon , mustof had 12 months rego and new tyres
#42 _Gunmetal LH_
Posted 03 July 2010 - 01:24 AM
What are they called again?
Oh yeah- TOWTRUCK
(I really don't like car trailers anymore...) 10-01-04_12-33-46.jpg 5.24K 100 downloads
#43
Posted 03 July 2010 - 08:05 AM
I agree that being able to DIY is a great thing and it shouldn't be actively discouraged, but I know I am always wary of posting recommendations on public forums where safety issues may arise. Its very difficult to check out exactly what is being proposed even let alone have any assurance that it will be done right, so its best to err on the safe side. The guys who are really switched on and involved with the innovations you speak of will take the info in and put it together with other research and knowledge to make it happen. Whereas the ones with less experience get the message about safety and will (hopefully) at least consult with an expert in person before undertaking the project, if not discover that they need partial assistance or to farm the job out completely (which can often be cost saving).If everyone had the same attitude you had in that first post, nothing innovative would ever be thought up or constructed.
Scrap value here is through the roof, heaps of cars are being carted off to the scrap dealers, some with the paddock grass still hanging out the rust holes!the cost of mild steel has almost doubled in 18 months.
#44
Posted 05 July 2010 - 01:21 PM
add another $200 or so if you want to run a winch.
over-rider brakes are 100% fine, no need for electric unless you are planning on towing it on a daily basis.
You want the load as low as possible, and the trailer as light as possible. you dont want too much ball weight so have the car sit resonably centred over the axles.
ohh and fit light truck tyres. they make life alot easier and are higher load rated.
all the lights etc are cheap as chips (try boat shops for tailights and number plate lights, 100% waterproof)
DONT panel the floor completely, only panel where the wheels will go, otherwise you are just making it unnecessarily heavy.
#45 _gen3torrie_
Posted 06 July 2010 - 04:20 PM
but i am still going to go electric brakes...
i dont need breakaway brakes its not a truck
and it'll do probably 4-5 runs a year and when-ever i lend it to mates
#46 _Woodsy_
Posted 06 July 2010 - 04:29 PM
#47
Posted 06 July 2010 - 05:05 PM
I've thought of getting one but thinking of the space it would take up plus the cost involved I can't justify it.
#48
Posted 07 July 2010 - 08:44 AM
#49 _gen3torrie_
Posted 09 July 2010 - 10:54 PM
and they borrow my stuff ie trailer, tractor lots of things and its never come back broken
but when i lend it to family the drawbar comes back bent
#50 _Herne_
Posted 09 July 2010 - 11:06 PM
Herne
