Wish List
164 replies to this topic
#76 _les_
_les_
Posted 25 May 2006 - 03:26 PM
G'day Les, how about a run of the full color, illustrated parts catalogue you had at the FastLane member's night??
And any idea what's happening with the 30yr promo dvd's? Was promised one ages ago and Leith isn't returning my e-mails... Grrr....
Dick
Dick
The DVD�s are a no go legal reasons. Cya at Roxy Park.
Les
#77 _CHOPPER_
_CHOPPER_
Posted 25 May 2006 - 07:13 PM
Les, I finally was sent in the Campbellfield area this afternoon. I left the samples with somebody at reception and told them they are bits you requested.
#78 _les_
_les_
Posted 25 May 2006 - 08:14 PM
Thanks Chopper I had a doctor�s appointment today, Next time you are around the area drop in and I will show you around
Les
#79 _Swampy_
_Swampy_
Posted 27 May 2006 - 11:05 AM
I desperately need a Choke Knob (not cable) for my UC. Any chance?
#80 _les_
_les_
Posted 27 May 2006 - 07:27 PM
Swampy
The knob is part of the choke cable and not a separate part, if you are desperate and do not care about originality you could cut down a bonnet cable. We do have plans to make choke and bonnet cables for Torana�s but a few months away (possibly 9 mths)
#81 _Swampy_
_Swampy_
Posted 27 May 2006 - 07:57 PM
Swampy
I've coped since I've had it so another year won't hurt. Put me down for one.
#82 Dangerous
Dangerous
  • 948 posts
Posted 30 May 2006 - 04:37 PM
Les, what about the clear plastic lenses for the instruments in, well, everything from LC/LJ, LH/LX, HK/T/G etc? I know a few of mine are old and scratched.
#83 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 31 May 2006 - 04:31 PM
^that would be a good seller, I'm up for 3 to suit a LH-X. and I could probably supply some if you need some to make them
#84 _les_
_les_
Posted 31 May 2006 - 07:55 PM
Just a few questions on the lenses
Are they all plastic or is the XU-1 oil/temp glass?
Are the LH LX ones the same?
Is there a call for the warning lamp lenses like brake hi beam?
#85 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 31 May 2006 - 08:10 PM
I'm going to be doing a custom dash very shortly, and i'd like to be able to get some lenses or something that shows the icons for the different areas of the vehicle.
It's not something ive looked in to yet, but if there was something available i'd say i'd buy some!
#86 _les_
_les_
Posted 31 May 2006 - 08:14 PM
Sorry Tiny
We are only interested in original type lenses, genuine Rare Spares, I like that might use it in our advertising
#87 bullitA9X
bullitA9X
  • 4,168 posts
Posted 31 May 2006 - 08:37 PM
Hi les what about lc-lj wheel trims i know the hq ones arent doing so well but i think the lc-lj ones would sell like hot cakes
#88 _les_
_les_
Posted 31 May 2006 - 11:12 PM
try http://www.gmh-toran...?showtopic=4925
#89 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 01 June 2006 - 02:10 PM
Hi Les,
I'm not sure if this has been mentioned before but I was thinking of something that would be fairly easy to re-produce and you'd might sell a few.
The decal for the demister switch in the LX Torana. Most that I've seen are faded and are in pretty average condition. Also you might consider the decals for the power antenna and driving lights switch.
#90 _sstorana_
_sstorana_
Posted 01 June 2006 - 02:30 PM
antelopeslr5000
do you mean these..
I already do them..
PM me if you are interested
Mick
#91 Dangerous
Dangerous
  • 948 posts
Posted 01 June 2006 - 06:16 PM
It would be for the three identical plastic lenses on the LH/LX range - one each for (1) speedo, (2) blank/clock/tacho, and (3) fuel gauge/combined gauges. Where fitted, the clock one has a small hole in it, but this can be drilled if required by the purchaser. For the LCLJ/TA range, two identical ones in the LC/LJ dash, for (1) speedo and (2) tacho/fuel gage + idiot lights. In other words, one style for all LH/LX, with three needed per dash, and one style for LC/LJ/TA with two needed per dash. I reckon they would sell well.
The oil/fuel/temp/amp gauge in the GTR dashes have integral glass lenses which can't easily be removed, which I don't think would be a high volume seller. Ditto for the high beam/brake lenses - not a high volume seller.
#92 _les_
_les_
Posted 05 June 2006 - 05:56 PM
I have put them on the list and we will see what happens.
#93 _dannylxss_
_dannylxss_
Posted 08 June 2006 - 06:04 PM
hay les how about lc tail light lens i think they will sell great as good ones are very hard to find cheers :spoton:
#94 _les_
_les_
Posted 09 June 2006 - 01:37 PM
We have been down the road and they were decline due to lack of interest and high costs
#95 bullitA9X
bullitA9X
  • 4,168 posts
Posted 09 June 2006 - 07:59 PM
Hi les i remember reading in a post when i asked you about the lc-lj gtr wheel trims you said someone else had the rights have they made them or are you still looking at making them im hanging out bad man
#96 _les_
_les_
Posted 10 June 2006 - 09:41 AM
Last I heard they where a couple of weeks away but I have heard that for months now. We do not want to make them until we are sure that no one else is making them so yes at this stage we are still hanging out.
#97 goxu1
goxu1
  • 699 posts
  • Name:Paul
  • Car:4/73 Cyan Metallic GTR XU-1
Posted 10 June 2006 - 09:25 PM
Hi Les
You mentioneda while ago that you were going to put up some sample pics. Did this happen ?
Paul
#98 _HB1200_
_HB1200_
Posted 11 June 2006 - 09:35 AM
Hi Les,
The manual winscreen washer pumps from HB, LC, and LJ often die as the small rubber parts inside (valves?) perish. There are two types of pump that I have seen, The one that can be pulled apart has Holden Part No. 2818768. Both pumps were manufactured by Trico. If you could make a service kit for these pumps that would be great.
I haven't found a source for new pumps and/or kits yet but if anyone out there knows of someone doing repair kits, let me know and if so, Les please ignore this request.
HB1200
#99 _les_
_les_
Posted 11 June 2006 - 08:09 PM
Hi Les,
HB1200
That shouldn�t be to hard to do I will put it on the list
#100 _Torana/Fan_
_Torana/Fan_
Posted 12 June 2006 - 08:44 PM
Thats a shame as a good set just sold on ebay for $240 :cry:
Im sure people would buy them :D
Ash.
