Wish List
#126
Posted 10 September 2006 - 10:04 PM
LC LJ lower valance panel in steel ... rare panel to get hold of, normally rusts out , this is the panel that the number plate and front blimkers are on ..
if you get it right would fetch a good penny ...
#127
_The Baron_
Posted 10 September 2006 - 10:26 PM
What year crewcab rodeo?
Edited by The Baron, 10 September 2006 - 10:26 PM.
#128
Posted 11 September 2006 - 10:33 AM
Copied from Misk's original post, and still sitting on a post it note next to my deskMick, what's the chances you have the part numbers for those rubber gromits?
Hatch side glass grommets. Part number 8944810920, from Rodeo Space Cab, back then ~$3.50 each.
Darky, if you do get some, please get me 2 sets.
#129
_The Baron_
Posted 11 September 2006 - 01:46 PM
#130
_The Baron_
Posted 11 September 2006 - 02:05 PM
the 0 & 1 was wrong.
$2.20 at motor traders for a kit per window latch point.
#131
_The Baron_
Posted 11 September 2006 - 05:22 PM
It's $2.20 per gromet and you need 2 per side. (4 all up)
There was no "kit" as such.
Edited by The Baron, 11 September 2006 - 05:22 PM.
#132
_les_
Posted 11 September 2006 - 05:30 PM
We have had a couple of goes at making this panel in steel with no success we do have a fibreglass one, I am not confident we will be able to make a steel one in the near futureles
#133
_boynuz_
Posted 11 September 2006 - 11:19 PM
Every Lc Lj that needs to be restored needs one.
Actually i need 2 of them.
#134
Posted 12 September 2006 - 11:17 PM
New member and my first post. Would like to see repo rubber boot mats for LH / LX 4 doors.I dont know if their available,but a much needed item for my LH L31.
#135
_les_
Posted 13 September 2006 - 05:49 PM
We have managed to get the drawings complements of GMH unfortunately they are not that good , a sample would be great if anyone has one, it dose not have to be new but must have the correct shape
this is the hose off the car. It's actually a Commodore one part number is 92003988, suits VB V8. The left end mates up to the thermostat housing, the other end goes to the heater core. The Torana ones actually had another bent in them at the heater core end to go over the distributer better, their part number was 9939207.
#136
Posted 13 September 2006 - 07:51 PM
I would second that request.Hi Guys,
#137
Posted 13 September 2006 - 07:57 PM
do you need a sample or is measurments ok? The othe hose that runs to the pump is available and similar, it just doesn't have the bend round the accellerator bracketWe have managed to get the drawings complements of GMH unfortunately they are not that good , a sample would be great if anyone has one, it dose not have to be new but must have the correct shape
#138
_les_
Posted 14 September 2006 - 02:19 PM
#139
_les_
Posted 12 October 2006 - 07:12 PM
Les, I finally was sent in the Campbellfield area this afternoon. I left the samples with somebody at reception and told them they are bits you requested.
Chopper there is a new battery tray at Campbellfield for you in payment for giving us a sample, you can pick it up from there or we can send it to you. Let me know via a PM
Edited by les, 12 October 2006 - 07:13 PM.
#140
_Yella SLuR_
Posted 14 October 2006 - 10:56 PM
Bridgestone have just discontinued manufacturing of 265/50R14 and 245/50R14 S-330 Eagers. Is it possible for Rares to purchase the moulds/equipment while it still exists and organise an alternative manufacturer?
I've sent off a letter to Bridgestone to find out the exact status, but is this a possibility?
Hoping the answer is yes, would hate to be running BF Goodrich Radial T/A's, or heaven forbid, ricer rims and rubber band tyres on the old muscle cars (life just won't be the same).
Thanks in advance,
Pat.
#141
_the gts_
Posted 15 October 2006 - 06:51 AM
#142
_les_
Posted 16 October 2006 - 11:51 AM
We once had a slogan that said we make everything in Rubber for cars except tyres but this could change. Are these the original tyres on older Holdens?Les,
Thanks in advance,
Pat.
#143
_les_
Posted 16 October 2006 - 11:52 AM
Do you have a sample you can give usi would like the rubber grommet which seals where the steering column goes through the firewall. for an LH/X
#144
_Yella SLuR_
Posted 16 October 2006 - 02:00 PM
For those models carrying flares, yes, fairly standard sizes. Most tyre companies kept them as their "Street Machine" tyres, but seems that that is not so cool for em anymore. I heard that for the Veteran and Vintage cars they are ordering their small run tyres from small boutique tyre companies in Canada.We once had a slogan that said we make everything in Rubber for cars except tyres but this could change. Are these the original tyres on older Holdens?
Of all the wider tyres, the S-330 was my preference for general all round performance. The thought of having to use Radial T/A's scares me. Is it worth contacting Bridgestone now while the moulds/equipment to produce these sizes still exists, i.e. not having to return to square one?
I'd like to keep my Torrie as a driven piece of history, but as you can imagine, who in their right mind is going to be doing 100km/h on 15 year old hardened tyres?
Edited by Yella SLuR, 16 October 2006 - 02:01 PM.
#145
_Yella SLuR_
Posted 16 October 2006 - 03:16 PM
No flares, but mags to fill the guards --> 205/50R14
Flares - fill the guards ---> 245 front 265 rear/50R14's
Standard Torrie Rims are 13's, but not sure on widths. I also understand that these are like rocking horse stuff as well to get.
#146
_lx5008_
Posted 26 October 2006 - 03:10 PM
Posted 26 October 2006 - 04:08 PM
Andy
#148
_BCR42Y_
Posted 07 January 2007 - 06:46 PM
Is there any update on the LH SL/R 5000 ashtray fascia's?
They are the grained ones....
Also have you looked into Scuff plates for LH/LX Sedans?
Regards Halil.
#149
_the gts_
Posted 07 January 2007 - 08:22 PM
QUOTE (the gts @ Oct 15 2006, 06:51 AM)
I think so, what should i do with it? I am in perth. in the next few days
#150
_the gts_
Posted 07 January 2007 - 08:31 PM
PHIL
