building ozzie v8's
#26 _micksgtr_
Posted 19 May 2006 - 10:00 PM
#27 _dannylxss_
Posted 19 May 2006 - 10:06 PM
#28 _micksgtr_
Posted 19 May 2006 - 10:21 PM
#29 _dannylxss_
Posted 19 May 2006 - 10:31 PM
#30 _LJ355_
Posted 19 May 2006 - 10:47 PM
#31 _1QUICK LJ_
Posted 20 May 2006 - 01:50 AM
Edited by 1QUICK LJ, 20 May 2006 - 01:55 AM.
#32 _1QUICK LJ_
Posted 20 May 2006 - 02:17 AM
308 stroked to 336
forged pistons
10.5.1 comp
std chev rods arp bolts
rollmaster timing set
CRANE CCH304 hyd cam (236@050)
ported b cast heads
roller rockers
edelbrock performer manifold with 2in open spacer
extras:
750 carb
1 5/8 headers
msd or crane ignition
and most of all a good dyno tune
this is a really strong combo on the street and will smoke the tyres every gear in a torrie its good for around 300-320hp @ wheels (380-400hp@flywheel)
this is super driveable on the street and works well with a 3000 stall and 3.5-3.7 gears.
you would be suprised how this would go in a LH good value for 7k.
#33 _micksgtr_
Posted 20 May 2006 - 12:53 PM
"1quicklj" yeah i guess 500hp is a figure that popped in my head, yeah i have been in a few cars around that mark, but until you learn what can go wrong and what power can do what i wont understand what to buy.
your list is exactly what i was after, one question however is would it matter much going for a solid cam??
also now that i no i have to go for a block around the same age a the car what the best to start with??
#34 _1QUICK LJ_
Posted 20 May 2006 - 05:31 PM
#35 _1QUICK LJ_
Posted 20 May 2006 - 05:32 PM
Edited by 1QUICK LJ, 20 May 2006 - 05:36 PM.
#36 _micksgtr_
Posted 20 May 2006 - 08:49 PM
#37 _1QUICK LJ_
Posted 21 May 2006 - 01:50 AM
#38 _Lostit_
Posted 23 May 2006 - 04:35 PM
#39 _LJ308injected_
Posted 23 May 2006 - 06:02 PM
I just had my motor come off the dyno and it made 527hp with standard stroke roller cam harrop inlet and 10.8.1 comp and made that on pump fuel with vn heads although even builing a stroker unless you are i wouldnt even bother with vn heads as it costs alot more and you can make 440hp with early heads and that is plenty.I have a mate who also has a 500+hp 326 stroke and he uses dave bennet alloy heads and the early types but 500hp for 7k please.My motor cost me in excess of 15k plus.As stated then $2500 plus on auto and converter and another $1000 on diff it all adds up.But to be realistic 450hp is streetable and you can do it with 10.5.1 comp no worry's so all i can say is dont beleive all you hear on to many opinions in my eye's.
Regards.... Steve
#40 _micksgtr_
Posted 04 June 2006 - 04:05 PM
just after some advice on heads, i've been offered some HQ heads flowed to 450hp, how would these go with the setup i'm planning?? also being in a LH would i have any promblems with decent headers??
any advice would be great thanks
#41 _LHoon_
Posted 04 June 2006 - 04:48 PM
Those HQ heads flowed to 450hp would be perfect for a nice street/strip engine making around 350-400hp.
The advantage also for going for HQ / early heads is that you don't need to change headers or exhaust system. The exhaust system you currently have is also very high quality and suitably sized for that sort of power.
#42
Posted 04 June 2006 - 04:55 PM
Ev
#43 _1QUICK LJ_
Posted 04 June 2006 - 10:19 PM
#44 _1QUICK LJ_
Posted 04 June 2006 - 10:21 PM
#45 _MAWLER_
Posted 04 June 2006 - 10:22 PM
#46
Posted 04 June 2006 - 10:58 PM
Evan
#47 _[BOTTLEDUP]_
Posted 05 June 2006 - 12:28 AM
Apart from having a much better port layout and design, the castings are a lot newer, and hence are generally in much better condition. Also they aren't prone to cracking around the exhaust seats, and the valve material itself is a lot better.
#48 _micksgtr_
Posted 07 June 2006 - 08:50 PM
thanks for the great advice there guys, very helpful indeed. will be starting to do a bit more serious research very soon.
one other question, what order to people start to decide on things, like do i buy heads, then a block then a crank and cam?? might sound silly but i would be thinking you buy them all in an order to better match
Posted 07 June 2006 - 09:20 PM
dont outlay money on heads till you work out what cam you want to run as performance and reliability rely heavily on the correct combination.
#50
Posted 08 June 2006 - 04:16 PM
253 commodore engine lol.My engine number starts with VR whats that out of neither engineer or rta say anything ?
