If you have a banjo, a mini spool would be easier to get than a properly operating LSD. I personally will be running a full spool in ther drag car and hopefully Lock Right diffs in all my streeters.
Mini-Spool on the Street
_Viper_
, May 08 2006 09:52 PM
31 replies to this topic
#26
_CHOPPER_
Posted 19 May 2006 - 10:23 PM
#27
_user asked to be removed_
Posted 20 May 2006 - 07:14 PM
Umm, hate to sound silly but if your all saying how bad they are, whats the benifits, or have I missed a comment on the good side?
#28
_CHOPPER_
Posted 20 May 2006 - 07:18 PM
Full spools are designed for drag cars, as they basically only go in a straight line anyway. The Lock right diff is locked by default and unlocks for corners. So it's perfectly suitable and legal for the street.
#29
Posted 20 May 2006 - 07:44 PM
Liam: I didnt list their good points cause this was a discussion about the street...
But any spool ( mini or full) is designed as a race component, they lock the axle into one solid unit.
Having said that the benefits that come to mind are:
You'll know that if one wheel is to loose traction, then the other wheel will still take power and move the car, you wont get bogged by having one wheel in the air for example.
If your going to do a skid, both wheels will ALWAYS fry or nothing.. No unpredictable burnouts!
and really.. thats about it!
Drive ig given to each wheel no matter what, which is desirable in racing and thats about it!
Thats why i listed the negatives eariler cause there are ALOT of negatives and stresses that any kind of spool places on the driveline!
Posted 21 May 2006 - 08:11 PM
[edit] Would professional drifters use them, and V8 supercars
Edited by Liam.W, 21 May 2006 - 08:18 PM.
#31
_CHOPPER_
Posted 21 May 2006 - 09:16 PM
V8 super cars do use full spools.
#32
Posted 22 May 2006 - 12:55 PM
V8 super cars run a full spool diff, I belive professional drifters use 1.5 and 2 way LSDs... now theyre waaaay above my head but look at this site for more info on multi way LSD diff centres:
http://www.kaazusa.com/home/Home.htm
