I'm going to pull mine apart soon to clean it up and paint it. Have you got any tips that you learnt whilst doing this? Or is it fairly straight forward?
Yeah it's pretty straight forward mate, however I would have probably had the Control Arm Bushes pressed whilst in primer and then Painted after. Then I would have done the Assembly myself.
"You" are the one that is going to take the most care with it and touching up is a real pain.
So yeah other than that, ummm... If you can get access to a sand/bead blaster I highly recommend doing that, and also the Bench grinder with a wire wheel worked well for the clean up on the arms Etc.
Tefa
