DROP TANK
#1 _JNR_ATE_
Posted 13 May 2006 - 09:45 PM
Anywhere in melb decent and cost effective. is it worth having the mob who make it up fit it aswell,
I'd like to go strap less if i can aswell.
I have an SLR cluster, do the tanks come with any elec components to make the guage work or should i just have an external fuel guage mounted in the car instead.
JNR_ATE
#2 _CHOPPER_
Posted 13 May 2006 - 09:51 PM
#3 _LX_SS_
Posted 13 May 2006 - 10:14 PM
we still make many alloy drop tanks to suit your Torana, they are fully
baffled and come in a mill finish polish.(all our performance car tanks are
fully baffled to eliminate fuel surge)
back in the 70's we made most of the touring car alloy racing drop tanks and
still make road car tanks that look exactly the same
(we still make race car tanks for the current V8 supercars as well)
our standard tank for the Torana is 120lt (smaller tanks can be made as
required) and is designed to take the
standard pickup/gauge sender assembly, fills through the standard filler
spot & connects to the original venting system to keep it roadworthy, they
have no ugly straps under them but bracket into the chassis rails as did all
the original race car tanks
1/2" pick ups & swirl pots can be fitted into the tanks for EFI or big
engined cars as we make
them using the original pickup as the return if needed
all our drop tanks fit under the standard floor so the vehicle structure
does not change - you do not have to cut the boot floor - no registration
problems
our standard tank cost is $950.00
depending on which state you are from you will not need an engineering
cert. - our tanks are approved in all states, we are on the list of approved
manufacturers in WA, NT & QLD.
we fit an ID plate to keep in line with the rego requirements in specific
states
delivery varies between 1 to 3 weeks
darn, means i gotta spend more.
#4 _JNR_ATE_
Posted 14 May 2006 - 08:48 PM
Thanks for your help LX_SS.
Definately getting on that deal i think, whats the general feel of a drop tank without flares and only 215 wide rear bags in a LH sedan. Hot or Not?
JNR_ATE
#5 _kangur_
Posted 14 May 2006 - 08:53 PM
#6 _@milco@_
Posted 14 May 2006 - 09:28 PM
Posted 16 May 2006 - 11:49 PM
Thanks in advance.
#8 _mra9x_
Posted 17 May 2006 - 09:20 PM
#9 _JNR_ATE_
Posted 18 May 2006 - 02:47 AM
is the tank you ordered the 120 ltr brown davis strapless setup, how much did they sting u on price without them fitting it.
JNR_ATE
#10 _mra9x_
Posted 18 May 2006 - 01:32 PM
Posted 18 May 2006 - 04:49 PM
or I might just sump mine so I can get a decent pickup and a few more litres capacity
Edited by makka, 18 May 2006 - 04:50 PM.
Posted 25 May 2006 - 09:22 PM
#13 _Oldn64_
Posted 25 May 2006 - 10:18 PM
I understood that the strapped tanks need to have holes drilled as well.... Could be wrong....Do brown davis make the ones with straps as well? Personally would prefer straps since I'd rather not be drilling holes in the cars. Besides the straps aren't ugly and do suit especially if the tank has "indents" for the straps.
#14 _CHOPPER_
Posted 25 May 2006 - 10:56 PM
Brown Davis can modify stock tanks, but I think it's over the $300 mark.hmmm, I might have to get a new one, its not worth buying a secondhand no name tank for $600 when you can get a new brown davis one for that much.
#15 _Herne_
Posted 25 May 2006 - 11:27 PM
The strapped drop tank I have fits directly into the existing bolt holes of the standard tank. Not sure what brand it is though.I understood that the strapped tanks need to have holes drilled as well.... Could be wrong....Do brown davis make the ones with straps as well? Personally would prefer straps since I'd rather not be drilling holes in the cars. Besides the straps aren't ugly and do suit especially if the tank has "indents" for the straps.
Herne
Posted 26 May 2006 - 10:39 AM
From whathe informed me straps are illegal in some states so all his tanks bolt to the chassis of the car.
My tank from them fitted like a glove and i bolted to the chassis with no drama.
Cheers!
#17 _Viper_
Posted 26 May 2006 - 09:40 PM
-Cheers
#18 _kangur_
Posted 27 May 2006 - 02:55 PM
#19 _Viper_
Posted 28 May 2006 - 06:19 PM
#20 _Keithy's_UC_
Posted 28 May 2006 - 08:07 PM
www.armadale4wd.com.au/products/fuel.htm
I've just sent them an email and will let ye all know what they do for the ole UC Tozza!!
Keith
Edited by Keithy's_UC, 28 May 2006 - 08:09 PM.
#21 _kangur_
Posted 28 May 2006 - 08:58 PM
#22 _torana338_
Posted 29 May 2006 - 09:00 PM
#23 _JNR_ATE_
Posted 30 May 2006 - 03:16 AM
Just not sure if the 120 litre will be too big and low for a daily driver,i will get it but just dont wanna hurt it goin up driveways and pulling into the carpark at chapel st to lay a patch, anyone know how this feels. any ideas
JNR_ATE
#24
Posted 30 May 2006 - 11:01 AM
#25 _kangur_
Posted 30 May 2006 - 04:50 PM
