Supra 5 speed into LX
43 replies to this topic
#1 _NEWSUX LX_
_NEWSUX LX_
Posted 09 May 2011 - 07:21 PM
Hi all i have the oppertunity to snap up a supra 5 speed cheap for my LX hatch but i dont really wana cut the floor in any way shape or form. Will this box (behind a 308) fit in the tunnel without cutting? Cheers
#2 _rob350hatch_
_rob350hatch_
Posted 09 May 2011 - 07:43 PM
yes i have a w58 behind a 350 chev in my red hatch.its a beautiful box id grab it if i were you.floor just needs a bash here and there but it fits.
#3 _NEWSUX LX_
_NEWSUX LX_
Posted 09 May 2011 - 07:52 PM
Ok cool what diff ratio r u running?
#4 76lxhatch
  • 7,156 posts
Posted 09 May 2011 - 08:14 PM
The angle won't be ideal without a bit of a trim but nothing major
#5 _NEWSUX LX_
_NEWSUX LX_
Posted 09 May 2011 - 08:36 PM
What needs to b trimmed? By how much?
#6 76lxhatch
  • 7,156 posts
Posted 10 May 2011 - 07:10 AM
Just the hole around the shifter, aside from fitting the shifter housing through the tunnel snugly I found that enlarging it forward a little helped with a precious extra few mm of height. No modification to the tunnel shape required
#7 _NEWSUX LX_
_NEWSUX LX_
Posted 10 May 2011 - 08:47 AM
Ahh thats good thanks mate
#8 _BLACK LH_
_BLACK LH_
Posted 10 May 2011 - 07:53 PM
just put 1 behind my 308 fits in tunnel no bashing required just cut maybe an inch in tunell to get shifter housing in :buttrock:
#9 _NEWSUX LX_
_NEWSUX LX_
Posted 10 May 2011 - 08:39 PM
Awsum thats what i wanted to hear, what diff are you using?
#10 _rob350hatch_
_rob350hatch_
Posted 11 May 2011 - 04:24 PM
3.25 limo with 15 inch wheels with 285/40/15s.i didnt have to trim anything luckily and the shifter came up in exactly the same spot as the factory 4 speed which was what i was relieved about the most as i still use the console.but buggered if it was going to fit without a bash.maybe its different with the sbchev
#11 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 11 May 2011 - 04:32 PM
same, easy job compared to a T5
#12 _NEWSUX LX_
_NEWSUX LX_
Posted 11 May 2011 - 05:07 PM
Thanks guys :buttrock:
#13 _BLACK LH_
_BLACK LH_
Posted 11 May 2011 - 07:47 PM
LSD 9inch 3.55
#14 _NEWSUX LX_
_NEWSUX LX_
Posted 11 May 2011 - 08:39 PM
Do u have any clearance troubles with the 9 inch?
#15 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 11 May 2011 - 08:49 PM
I think there is at least 3 different shifter positions on Supra boxes - maybe that's why some of the above comments vary regarding trimming the gear stick hole.
#16 _BLACK LH_
_BLACK LH_
Posted 11 May 2011 - 09:04 PM
had to adjust ( bend) the fuel tank edge back a few mm but all good
#17 76lxhatch
  • 7,156 posts
Posted 11 May 2011 - 10:06 PM
Yeah but you want want the rearmost position for best placement
#18 tsn007
tsn007
  • 1,010 posts
  • Name:Tony
  • Car:LX hatch, LX sedan
Posted 18 May 2011 - 06:38 PM
this my supra in my hatch
#19 _NEWSUX LX_
_NEWSUX LX_
Posted 18 May 2011 - 09:43 PM
Is that the rear most shifter type?
#20 _Darklord_
_Darklord_
Posted 19 May 2011 - 12:40 AM
For those of you that have one already - how do you like it? How much power are you running through it?
#21 76lxhatch
  • 7,156 posts
Posted 19 May 2011 - 07:18 AM
@NEWSUX LX - looks like the rearmost shifter version to me, mine sits a bit higher to get a decent driveshaft angle (with HQ engine mounts though), and I have cut a bit further forward to accommodate (the driveshaft is very close to the floor but nothing is cut/modified behind the shifter).
@Darklord - mine's behind a warm-ish 308 which has had steady improvement over the last 5 years and it seems to be holding up fine no matter what I do to it which is a little surprising. I didn't do the conversion but I suspect that the box may have received some attention before being put behind the V8. The worst part of it is the shift quality, new shift bushes and a nice short shifter have made enough of an improvement that I am happy to keep it for now, but it still doesn't have very good feel.
#22 rexy
rexy
  • 3,602 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 19 May 2011 - 08:25 PM
More than 300 ft/lb of torque will eventually pull teeth off if applied regularly. The shift quality is ok-ish. I must admit I preferred the direct notchier feel the old steel case celica box had before I replaced it with the w series box.
#23 tsn007
tsn007
  • 1,010 posts
  • Name:Tony
Posted 19 May 2011 - 08:32 PM
I love my supra !!
its behind a sweet 253 and shifts beautifully with my hydraulic clutch setup, smooth direct gear changes
welcome to test drive
#24 rexy
rexy
  • 3,602 posts
  • Name:Rexy
Posted 19 May 2011 - 08:58 PM
Once was second gear....
Did this with my warm 308. 325hp/340ftlb at flywheel.
#25 TerrA LX
Posted 19 May 2011 - 11:34 PM
Hey rexy did the input shaft bearing have wear?
