Supra 5 speed into LX
#26
Posted 19 May 2011 - 11:50 PM
#27 _rob350hatch_
Posted 20 May 2011 - 08:32 AM
i would never have bought one but it came with the 350 out of a jag.and im glad i did now.
and the shifter feels very good precise .may have been refurbished not long before i got but i never miss any gears.im happy with the shift.
#28
Posted 27 May 2011 - 06:40 PM
What is everyones opinion on clutch adjustment? Ive alwaya found with my celica box in the lj and with the ute that the clutch needed to be slightly over adjusted, so causes a bit of premmy clutch wear. Anyone else have issues?
#29
Posted 27 May 2011 - 09:29 PM
the dellow short shift feels alot better, you know its in gear but i found the shifter pattern too close which makes for an extremely heavy geartick, a mate made up a longer stick out of a big chunk of ally bar which made it heaps better feel & closer pattern than standard shifter. biggest drawback with standard shifter is the 2 piece shifter with rubber connecting the two, i could still push the shifter forward 3/4 of an inch while in gear with the standard shifter
try stay away from dellow bellhousing, they are made of melted down sigma timing covers etc and warp/twist/crack and end up wearing out the input shaft bearing.
look at a dellow bellhousing then look at crs. dellow is greyish in colour and crs looks like aluminium! the colour says it all.
all in all, fr0cking tough box behind a 6 cyl, no matter how many 7000rpm launches on slicks you do, but shitty feeling shift
Ive got a supra box in the hx ute, shifter is very sloppy and has bugger all feel, im thinking its the actual.shifter though, so first chance I get it mighy need pulling out.
you dont mean making the thrust bearing ride and wearing out the thrust ring on the crank prematurely do you?
#30
Posted 28 May 2011 - 07:59 AM
http://www.torrie.co.nz/forsale.htm
The best thing you can do with the standard shifter is replace the two bushes, ditch the rubber damper and set up a solid stick to whatever length/position suits best.
orangeLJ sounds like you need a bit longer pedal lever to give you more overall travel on the clutch. I had the exact opposite to begin with, whoever set mine up had around 1 1/2 inches of pedal travel to disengage the clutch! I don't think people spend too much time on getting these things right, even with bolt-in conversion packages.
#31 _Chamois hatch_
Posted 01 June 2011 - 08:55 PM
#32
Posted 18 October 2011 - 02:56 PM
#33 _76S.L.R_
Posted 22 October 2011 - 11:06 PM
the T350 was fitted some time ago cause I got the box in top shape(still is) for $250.00 ! and prior to this had broken 2 Aussie 4 Speed boxes then a Ford single rail set up too but I think the Supra conversion is the way to go....
Edited by 76S.L.R, 22 October 2011 - 11:07 PM.
#34 _L32M20_
Posted 15 November 2011 - 08:17 PM
#35
Posted 16 November 2011 - 08:51 AM
Check my thread on keeping the costs down on the conversion.
http://www.gmh-toran...for-the-torana/
If you still want a Supra, PM me as i have one for sale.
Ev
#37
Posted 16 November 2011 - 11:37 AM
Going to a Muncie now
#38
Posted 16 November 2011 - 03:54 PM
I did the same thing recently, didn't quite take enough teeth off that I couldn't nurse it home which was good though.
Ditto on the teeth (lay shaft 2nd gear) and limp home. Going to a Tremec TKO 600 (expensive) another W58 went in in the mean time.
$500 + delivered out of melbourne. Took 3 months to find one, there are 3 gearshift positions and parts are impossible to find, so have all but a layshaft for sale.
Dellow got nothing, a dozen gearbox shops got nothing and can't find any spares.
Balfizar
#39
Posted 17 November 2011 - 06:57 AM
The shifter I have is a little on the expensive side but very well made and works great - it has a relocated pivot and a weighted knob along with a decent length stick: http://www.torrie.co.nz/forsale.htm The best thing you can do with the standard shifter is replace the two bushes, ditch the rubber damper and set up a solid stick to whatever length/position suits best. orangeLJ sounds like you need a bit longer pedal lever to give you more overall travel on the clutch. I had the exact opposite to begin with, whoever set mine up had around 1 1/2 inches of pedal travel to disengage the clutch! I don't think people spend too much time on getting these things right, even with bolt-in conversion packages.
Have you got another link to that shifter assembly?
it goes to a photo site now?
thanks,
Chris
#40
Posted 17 November 2011 - 07:25 AM
http://www.trademe.c...n-422789757.htm
edit: I think he sells them on eBay Aus too
Edited by 76lxhatch, 17 November 2011 - 07:26 AM.
#41
Posted 17 November 2011 - 09:40 AM
I found this-
[url="https://cache.gmh-torana.com.au/i123.photobucket.com/albums/o299/casanas/S5301568-1.jpg"]https://cache.gmh-torana.com.au/i123.photobucket.com/albums/o299/casanas/S5301568-1.jpg[/url]
from here-
http://www.classic-c...er=asc&start=15
defnitely different!
#42
Posted 17 November 2011 - 12:45 PM
No wonder he was complaining about breaking shift forks, the Toyota box won't like being rammed through the gears like that!
#43
Posted 17 November 2011 - 01:32 PM
first get the tail housing out cut the side and weld a 3/4" aluminum small plate were the 3 shifter rods go tru and a machine shop will make the seal lands for all 3 of 'em after you get the seals i dont remember what seals i use but it should not be hard to find out in the macmaster catalog, then weld a 1/4" side plate of aluminum were the shifter will bolt in, cover with a 3/16 metal plate the factory shifter hole, cut the 3 shifter rods and discard the factory shifter assambly and mecanism, then drill em for the rod end bolts and put it together and adjust the new shifter.
Im so indecisive about buying one of those shifters, lots of $$ for something thats a luxury.
Are there any cheaper after market shifters floating around? just curious as to other options for my street car. I'm definitely looking at one of the NZ ones for the racecar though (where I can see good use/value)
#44
Posted 17 November 2011 - 02:09 PM
As I mentioned above, if you remove the rubber mounted part of the stick and muck around a bit with the angles and length, and solid mount the knob, you'll get a lot better feel and a little shorter throw. That and replacing the worn bushes are about the only options for a cheap solution (not that the bushes are particularly cheap).
