Battery Boxes
Posted 21 May 2006 - 01:45 AM
What do people use to stop the battery moving around?
When I took it to the drags the guy said next time you come make sure it does not move around
Loui
#2 _MYLJ_
Posted 21 May 2006 - 11:20 AM
#3 _CHOPPER_
Posted 21 May 2006 - 11:56 AM
Posted 21 May 2006 - 01:57 PM
Loui
#5 _wildsix_
Posted 21 May 2006 - 07:48 PM
#6 _MYLJ_
Posted 21 May 2006 - 07:51 PM
#7 _CHOPPER_
Posted 21 May 2006 - 09:10 PM
Posted 21 May 2006 - 09:30 PM
Does anyone with some experience wanna list any issues that can arise from relocating the thing?
Edited by Heath, 21 May 2006 - 09:30 PM.
#9 _CHOPPER_
Posted 21 May 2006 - 09:39 PM
Posted 21 May 2006 - 11:14 PM
Posted 22 May 2006 - 04:36 PM
#12 _Oldn64_
Posted 23 May 2006 - 12:06 AM
if you use good quality parts and design the system well you will have a good setup. most people will forget to add ground points and have issues with starting the car, but this is easily fixed.
Posted 23 May 2006 - 12:46 PM
Posted 23 May 2006 - 01:11 PM
Posted 23 May 2006 - 02:19 PM
Cheers buddy. Chris
#16 _devilsadvocate_
Posted 23 May 2006 - 02:46 PM
Its the resistance of your cable and quality of your extra earth connections that are more critical than when the battery is mounted closer to the motor. (i hope no one is going to post about how the car is only held together by a few spot welds between the boot and the engine)
If they are poor, voltage drops will occur and this will be the reason as to why the motor might not crank fast enough to start, ie less than 9V at the starter when cranking and you have potential problems irrespective of whether you have a battery with high cca and Ah rating (Only be able to crank the motor longer at a speed which wont start it)
Edited by devilsadvocate, 23 May 2006 - 02:46 PM.
#17 _70rey_
Posted 23 May 2006 - 07:58 PM
Posted 25 May 2006 - 04:24 PM
Funny you should say that. Years ago, I installed a high power amp in an early model Magna (not mine), and had big noise and power problems. Started measuring resistance and voltage drop along the floorpan, and guess what? About an Ohm across the floorpan join where it had been "spot" welded. Braided cable connector across the join fixed things, but I don't think I'd own a Magna!(i hope no one is going to post about how the car is only held together by a few spot welds between the boot and the engine)
Edited by Dangerous, 25 May 2006 - 04:25 PM.
#19 _The Baron_
Posted 25 May 2006 - 05:49 PM
#20 _devilsadvocate_
Posted 25 May 2006 - 08:21 PM
Most multimeters dont offer better resolution than 0.1Ohm which is still significant resistance for an earth. Best way to measure is to look for voltage drops when drawing a significant current.
Here's what Ive done. Using a 12V 60W hand held spotlight with an earth lead long enough to go from battery to other end of the car. The voltage across the lamp was measured with the earth placed in various locations around the car(right through to the rear bumper) with the +ve fixed to the battery. Measuring the voltage to 0.01V resolution the max difference in moving to various points around the car was ~0.02V(those who can manipulate ohms law can work out the res). The drop with 3m of the best battery cable that money can buy is going to be significantly greater.
#21 _The Baron_
Posted 28 May 2006 - 10:30 PM
I have discussed this with others and all will agree the biggest issue with batteries is making sure the damb connections are 100%.
When you crank the thing, even the small resistance in the circuit works against you.
Remember it is only 12 pissy volts and you want hundreds of amps.
The Devils finding are sound, they do go to prove that .02v drop was the worst and as he said he even tested at the rear bumper bar.
V=I.R the challenge was. Therefore R=V/I, R= .02v/5A(60w), R= 0.004 ohms.
Small hey. But if you are sending say a wishful 400A through this circuit then according to Ohm's law the volt drop is V=I.R, V=400A x 0.004 ohms Vdrop =1.6V
Yep, a whole 1.6V, but that is a 13.3% loss.
Now think this is only one leg of the circuit and according to the Devil the positive cabling is worse!!
By the way a bigger battery does not get around the problem as it is the Voltage that dictates the Current through the Resistance. OK
So if you must put the battery further away in the boot, all that copper and steel is going to make it harder to start the bastard. An additional Earth cable back to the motor from the battery is only going to help "if" you have problems.
I hope I have explained my point better this time.
I will check the resistance of 95mm flexible cable tomorrow.
#22 _devilsadvocate_
Posted 28 May 2006 - 11:29 PM
400A.......perhaps on a stalled starter, but 60-100A is all one will see on a 6cyl
Correct, only increasing batt voltage gets over the prob, hence 24V systems in trucks etc.
Makes good numbers to look at the change in power at the starter
12 V 400A and the solely the 0.004Ohm body connection.
If the 0.004r wasnt there the starter would get 461A
Thats an increase in power of (4.61/4)^2 = 35%
This increase would only be 7% on a typical 100A starter.
All this is ignoring the internal resistance of the battery which will be the other major factor when creating currents this big. You'll see a drop of ~1-1.5V across a standard battery when only using 100A. So yes a bigger battery(more cca's) will have less voltage drop, so admittingly counteract effects of more resistance to a small degree.
Anyway, wouldnt be using my res readings in any journal though, only done by holding connections at various points onto bits of metal bared with a nail and remembering "worst readings" were 0.02V.
#23 _The Baron_
Posted 29 May 2006 - 09:44 AM
#24 _LJ355_
Posted 29 May 2006 - 06:32 PM
#25
Posted 01 June 2006 - 09:27 PM
one; "vented batteries" as opposed to sealed batteries let off gas as the work, the harder they work the more gas, so if you had say a hatch back as opposed to a 4door, you would have to ensure that any venting was to the outside of the car and not to the cabin not only to prevent a defect (we all follow the letter of the law here for road going cars dont we) but also for your health as worst case being if the battery split. (if you ever had this happen, if stinks etc) and hence the reason for it being illegal to not have the battery vented to the outside of the car.
two; if gas comes out of the battery then gas (and liquid) must be able to get back in.
