Battery Boxes
#26 _The Baron_
Posted 01 June 2006 - 09:43 PM
There is no seal between that air space and the cabin.
#27
Posted 01 June 2006 - 09:55 PM
#28 _Hotrodder_
Posted 02 June 2006 - 12:30 AM
Anyone contemplating putting the battery anywhere in the car (boot area) should also use the correct battery box too, the el-cheapo $15 marine boxes do not comply as they do not seal the box properly, and gases can still escape into the cabin.
#29
Posted 02 June 2006 - 12:38 AM
be warned though they are about three to six times the cost, but with new technology they also last longer and perform better, save weight and space, but thats another topic.
also most dont leak, even if punchered or need topping up as they use gel.
Edited by ALX76, 02 June 2006 - 12:44 AM.
#30 _devilsadvocate_
Posted 02 June 2006 - 12:58 AM
How much H2S is actually released in normal battery operation compared to H2?
#31
Posted 02 June 2006 - 07:39 PM
Now we are getting somewere, is this what caused the rust in the first placeWhat is the requirement for venting, would appear that they need to be vented from the top and the bottom.........H2S being heavier than air and H2 being lighter.
#32 _devilsadvocate_
Posted 02 June 2006 - 08:43 PM
#33 _Hotrodder_
Posted 04 June 2006 - 10:15 PM
Hydrogen sulphide gas is corrosive in a confined area, under the bonnet of a car is definately not confined, way too much air movement under there to be of any concern.
#34 _toddy_
Posted 07 June 2006 - 01:18 PM
I have a hatch and I need a sealed battery box that is vented to the out side of the car. The black cheapo boxes are not sealed and the only sealed ones I can find are morroso items at around 200 bucks doesnt seem practical.
How has evryone else sealed there boxes?
Or are the black boxes ok to use???
#35
Posted 07 June 2006 - 06:27 PM
dont know if this helps, nothing on venting capasity requirement yet.
#36 _TORANR AMORE_
Posted 22 June 2006 - 07:41 PM
* It DOES make a difference where you put your battery.
* When you increase the distance and the amount of steel that a DC current has to pass through you WILL increase the resistance in that circuit.
* Using a higher cca battery WILL provide better performance, especially in this situation. And especially when you have a situation where you are cranking for long periods of time.
If you have other concerns such as leakages, then you might consider looking into Gel Cells, although they are more expensive.
#37 _TORANASS_
Posted 27 June 2006 - 12:16 PM
John
#38 _QIKSLR_
Posted 27 June 2006 - 08:00 PM
#39 _devilsadvocate_
Posted 27 June 2006 - 08:09 PM
The other consideration is that you will need to have a window open if you are going to get good flow through your front vents or through the heater(could be annoying in the cold and the rain) Also keeps things in the boot a little warmer if you have......... the heater on
thats why if you leave a flat battery for a few minutes it might start your car again were as a gell cell doesnt have a high CCA.
Not sure what this is saying, basically all batteries can initially recover with rest, the chemicals are still reacting inside.
Edited by devilsadvocate, 27 June 2006 - 08:11 PM.
#40 _QIKSLR_
Posted 27 June 2006 - 08:17 PM
Well thats what I'm saying, the boot is vented so that shouldn't be a problem right? I don't think airflow matters...Yes, you can seal it up, but perhaps airflow through there is good to keep any moisture from accumulating....rust........or more to the point, any build up of fuel vapors.
Edited by QIKSLR, 27 June 2006 - 08:18 PM.
#41 _devilsadvocate_
Posted 27 June 2006 - 09:52 PM
Edited by devilsadvocate, 27 June 2006 - 09:54 PM.
#42
Posted 28 June 2006 - 06:52 PM
http://www.optimabat...034R_082304.pdfI dont think GELL cells have a high CCA rating, they are more used in stereo systems where high current is drawn for longer periods of time, i think thats why cars still use lead acid batterys today...CCA stands for Cold Cranking Amps were the first 60 seconds of life the battery can give huge amounts of current, but after its initial burst they drop dramaticly, thats why if you leave a flat battery for a few minutes it might start your car again were as a gell cell doesnt have a high CCA.
John
800 CCA.
#43 _@milco@_
Posted 05 July 2006 - 10:21 PM
#44
Posted 05 July 2006 - 10:45 PM
720CCA $286 and 800CCA $346. either is reccomended for our type applications.
i know for sure what my next battery is.
AMVM 9833 1900 St Marys.
