V6 WB Panno
128 replies to this topic
#1 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 26 September 2011 - 06:03 PM
So, after little interest in the VS Acclaim I was trying to sell, I ended up doing a straight swap for this.
84 WB Panel Van with VP Commodore V6 and T700. Has duel fuel, working aircon and power steering.
Drives good, just needs a bit of work to look good. Will have 12 months rego on it tomorrow :)
Plans are (as cash allows, so slowly) piss the WB lights and front off for HQ items, tidy the body up and a coat of paint.
#2 _Quagmire_
_Quagmire_
Posted 26 September 2011 - 07:56 PM
hj-x will bolt straight up you won't even need to change the bonnet....hq are different around the windscreen/bonnet lines
and someone told me the doors where a different shape to the guards
your wb front is worth some coin to the right person so don't just junk it :P
#3 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 26 September 2011 - 07:58 PM
Cheers mate, H-anything is better than WB. Good to know I can get something back on the wb front though. Will be a while yet anyway. It'll be my daily once registered tomorrow.
#4 Statler
  • 6,282 posts
Posted 26 September 2011 - 08:33 PM
Great score! :spoton:
#5 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 26 September 2011 - 08:55 PM
WB Statesman Caprice front clip, that or the HJ/X/Z twin lights are the ones I would choose if I ever get to own a pano.
+2 on the good score
#6 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 26 September 2011 - 09:45 PM
I would love something like this as a project! Great pick up! Will be awesome with the new look!
#7 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 26 September 2011 - 10:24 PM
Thanks fellas, it just sort of fell into my lap. Right place at the right time :spoton:
#8 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 26 September 2011 - 10:31 PM
Wish I could be that lucky, s'pose I was with Tracie's Torana but that's not my Sandman van
#9 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 26 September 2011 - 10:41 PM
Yeah well I know if it was the other way around, there's no way I'd swap a panel van for a VS commodore.
Though my LH may have to go now. I guess I can survive with the panno and only two Toranas...
Edited by slr_v8, 26 September 2011 - 10:45 PM.
#10 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 27 September 2011 - 07:15 AM
Following on from Quagmire's post, do any of the HJ/X/Z fronts bolt on without changing the bonnet and/or guards? This is my first "big" Holden. I've only owned Toranas and a HR.
#11 _CHOPPER_
_CHOPPER_
Posted 27 September 2011 - 11:25 AM
No, WB guards are different to HJ-HZ. The front of the HJ-HZ guards go in a straight line from top to bottom. The WB guards have the front lower section missing. The earlier model nose will bolt up, but there will be a gap at the lower front edge of the guard.
#12 yel327
  • 13,114 posts
Posted 27 September 2011 - 11:31 AM
Most HJ-HZ will almost fit straight on. The only ones that won't are normal HJ-HZ 1-tonner fronts which use HQ style fronts. The problem areas you will have are:
Bolt threads: Some WB are metric.
Harness: Will need mods to run the HJ-HZ lights.
WB inner guards fit a bit different to HJ-HZ, you'll want to keep your WB ones as they have all the crap mounted on them already.
Front bar: HJ-HZ front bar doesn't mount properly to WB rails. Only 2 bolts align (of the 3).
Radiator: WB radiator won't fit the HJ-HZ support. Spend a day on it unpicking spotwelds and modifying the HJ-HZ one and it will (recommended).
I would recommend you keep the WB guards, inner guards, bonnet, stone trays, front bar and radiator support. Modify the radiator support to allow Statesman lights to fit. And get a Statesman top panel, grille, lights and bumperettes.
What you have is easily converted to a V8 EFI later. It'll all bolt in unless they've stuffed the chassis fitting the V6. Will need EFI 304 with engine harness and barttery harness, HQ-WB V8 sump and mounts, WB V8 radiator and V8 memcal. If the conversion is done right it should just about plug in and work.
#13 _CHOPPER_
_CHOPPER_
Posted 27 September 2011 - 11:43 AM
Can you recall which ones? I don't remember finding any on my 1982 WB van. Just curious.
#14 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 27 September 2011 - 01:12 PM
Sounds like it'll be easier to leave the WB front on it. Or to go the WB statesman front for the easiest swap.
And I've already thought about the EFI 5L. I have a 5L VN sitting here...
On the plus side, it's regoed now, so I can drive it :burnout:
Edited by slr_v8, 27 September 2011 - 01:12 PM.
#15 _CHOPPER_
_CHOPPER_
Posted 27 September 2011 - 01:28 PM
The WB Stato front would be the easiest, unless you could get hold of an HJ-HZ complete front clip. The wiring mods would be easy, as the headlight connectors etc. are available new.
#16 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 27 September 2011 - 02:11 PM
If you dont like the WB front you could fit a HJ-HZ prem front, HJ-HZ GTS gaurds and do it up like a Sandman.
#17 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 27 September 2011 - 02:57 PM
Yeah I'll see what happens as I go.
Meanwhile, I can generally read Torana tags, but dunno these. Can someone help?
Chassis-EWB 52047A
VIN-8M70LD L122418B
Model-WB8WM70
Body-122418-A
Trim-3038-66V
Paint-1J 052-D
Built April 84
Eng. L14
Trans. M40
Axle. GV4
Also has BH93 stamped above the drivers side headlight? No idea what that's for...
Any help much appreciated.
Edited by slr_v8, 27 September 2011 - 02:58 PM.
#18 _CHOPPER_
_CHOPPER_
Posted 27 September 2011 - 04:50 PM
WB8WM70 = WB van
L14 = Blue 202
M40 = trimatic
GV4 = diff ratio, probably 3.36:1 with the auto
#19 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 27 September 2011 - 05:24 PM
Thanks mate.
#20 yel327
  • 13,114 posts
Posted 27 September 2011 - 05:35 PM
Varies. Some of the normal body bolts and captive nuts plus the screws that hold the inner guard to thee guard are often metric. Sh!ts you when they are different threads across the same car.
#21 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 27 September 2011 - 05:39 PM
Speaking of that, I found the same on a 78 UC I wrecked. Can't remember exactly which bolts, but while the majority was imperial, there were a few metric ones in there.
#22 rodomo
  • 17,999 posts
Posted 27 September 2011 - 05:50 PM
LH v WB Panno? :dontknow: .................... No contest! :fool:
#23 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 27 September 2011 - 05:55 PM
My LH is a shell. Has been for bout 4 years or so now. This is regoed and running, plus I got the HB and LC.
I may keep it yet, just means it will stay sitting in the shed.
#24 Statler
  • 6,282 posts
Posted 27 September 2011 - 05:57 PM
REGO!!!!!!!! :clap:
Now!, go forth & copulate..... or is that populate? :dontknow:
#25 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 27 September 2011 - 05:58 PM
Yep, already been out in it mate :)
