Gilmer belt keeps jumping off
33 replies to this topic
#26 hanra
  • 11,025 posts
Posted 14 December 2011 - 10:13 AM
As said, theres only one tried and true method to fix a gilmer belt setup.
Step one, remove all the gilmer belt components,
Step two, refit all the v belt components,
Step three, fit a v belt.
^ +1
#27 _injlc304_
_injlc304_
Posted 14 December 2011 - 11:17 AM
is the long nose water pump the right one for the vn-vt efi motor or is it suppose to be the short pump?
#28 _injlc304_
_injlc304_
Posted 14 December 2011 - 11:35 AM
just called a few wreckers and they said $200 for the original 3 pulleys?? Are you F**King kidding me!! think i might try fix what i got
#29 _Mint_
_Mint_
Posted 14 December 2011 - 05:03 PM
yes..i think..the long nose pump was for the efi motors coz they had extra pulley grooves on the crank,air con..power steering etc
as well as the multi rib belt..the main drive belt..the early motors didnt have that type of belt
Edited by lxssv8, 14 December 2011 - 05:05 PM.
#30 _injlc304_
_injlc304_
Posted 14 December 2011 - 05:13 PM
ok then. well i guess when i get the new belt ill just try adjusting it and go from their
#31 _Mint_
_Mint_
Posted 14 December 2011 - 07:51 PM
dont know if you want to go to the trouble but..an early short nose water pump would probably work in your app
#32 _injlc304_
_injlc304_
Posted 14 December 2011 - 08:30 PM
I'll measure the two and go from their I think
#33 dattoman
Posted 14 December 2011 - 08:54 PM
Short early pump 92mm face to pulley flange
Long later pump 110mm face to pulley flange
From memory
#34 _injlc304_
_injlc304_
Posted 14 December 2011 - 09:47 PM
From memory
Cheers mate
