Where to get spring spacers?
#1 _injlc304_
Posted 08 January 2012 - 05:58 PM
I'm looking at getting some coil spring spacers for my LC. I've read in a few very very old posts on here that you can get them from superpro but I cant find them. Can anyone tell me where I can find some cheap ones from
#2 _injlc304_
Posted 08 January 2012 - 07:30 PM
Page 46. Front Spring Insulator SPF0853-10K 2 1B Raises vehicle approximately 18mm
Will that work?
#3 _injlc304_
Posted 08 January 2012 - 08:10 PM
Posted 08 January 2012 - 08:27 PM
Posted 08 January 2012 - 09:25 PM
WA Suspensions have moved sometime in the last couple of years.
WA Suspensions
28 Colray ave
Osborne Park
WA 6017
http://wasuspensions.com.au/
#6 _injlc304_
Posted 08 January 2012 - 10:24 PM
WA Suspensions have a good range of SuperPro on the shelf. If they don't have it in stock then it can usually be sent overnight.
WA Suspensions
28 Colray ave
Osborne Park
WA 6017
Cheers mate I bought my Sway bar from there a few weeks ago. So If I get these spring insulators will it raise my car up the 18mm it says? Is this the easiest way?
Posted 08 January 2012 - 10:29 PM
But most shops can anyway
Autoline in Bentley are agents for them... saves going to Osi Park
#8 _injlc304_
Posted 08 January 2012 - 11:14 PM
I'll message you on here Tomoz neil
Edited by injlc304, 08 January 2012 - 11:16 PM.
Posted 09 January 2012 - 12:26 AM
Posted 09 January 2012 - 01:03 AM
#11 _glenn l_
Posted 09 January 2012 - 07:16 AM
#12 _injlc304_
Posted 09 January 2012 - 08:23 AM
Posted 09 January 2012 - 01:46 PM
My suppliers don't have stock in Perth
#14 _injlc304_
Posted 09 January 2012 - 01:54 PM
WA Suspensions in stock for $48 for the 2x Front kits
Wilkinsons was $37.30 for the 2x Front kits but was another $12 to freight in.
Edited by injlc304, 09 January 2012 - 02:09 PM.
Posted 09 January 2012 - 03:43 PM
#16 _injlc304_
Posted 09 January 2012 - 03:54 PM
#17 _CHOPPER_
Posted 09 January 2012 - 04:13 PM
#18 _injlc304_
Posted 09 January 2012 - 04:38 PM
Posted 09 January 2012 - 04:46 PM
#20 _injlc304_
Posted 09 January 2012 - 04:56 PM
I foolishly thought they would sell the spacers in pairs.
haha thats what i said when i called them!! a kit = a pair in the normal world??
#21
Posted 09 January 2012 - 05:31 PM
I'd go with Wilkos... and ask them questions
One of our members works there
And Peter knows what he's doing
#22
Posted 09 January 2012 - 06:05 PM
I don't see how a 10mm thickness gives you 18 mm lift
The spring ratio is around 0.75 on the LX (I guess the LC is similar) so when the stub axles travels 10 mm the spring is compressed 7.5 mm. The 18 mm ride height increase from a 10 mm spacer still does not sound quite right.
If the spring was mounted at the stub axle then the spring would travel about the same as the stub axle. This ratio is also the reason why the front springs have such a high spring rate (thickness) when compare with the same weight car running struts.
If you want to know how much difference a 10 mm spacer will make then put the car on stands with the load taken on the suspension arm and measure the distance between the control arm and the k-frame at the spring mount. Then lower the control arm 10 mm measuring at the spring mount and compare the height of the tyre.
Edited by ls2lxhatch, 09 January 2012 - 06:19 PM.
#23 _injlc304_
Posted 09 January 2012 - 06:25 PM
#24
Posted 10 January 2012 - 07:56 AM
10mm lower spacer.
P1010955 (600 x 450).jpg 63.35K 7 downloads
27mm lower spacer.
P1010958 (600 x 450).jpg 69.88K 5 downloads
27mm upper spacer.
P1010956 (600 x 450).jpg 66.66K 6 downloads
#25 _injlc304_
Posted 10 January 2012 - 08:21 AM
