Where to get spring spacers?
#26
Posted 11 January 2012 - 06:05 AM
WP_000127 (600 x 450).jpg 54.02K 2 downloads
#27 _injlc304_
Posted 11 January 2012 - 07:31 AM
#28
Posted 12 January 2012 - 01:29 PM
#29
Posted 12 January 2012 - 03:52 PM
#30 _injlc304_
Posted 12 January 2012 - 05:04 PM
#31
Posted 12 January 2012 - 07:51 PM
#32 _injlc304_
Posted 12 January 2012 - 08:28 PM
#33
Posted 13 January 2012 - 10:37 AM
P1000942 (600 x 450).jpg 102.22K 4 downloads
lcxu105
It doesn't sit up like a 4x4 but I do have plenty of ground clearance. Tyres are 26"(660mm)
Edited by warrenm, 13 January 2012 - 10:39 AM.
#34
Posted 13 January 2012 - 11:13 AM
I thought spring spacers weren't legal for rego?
As far as I can see the NCOP (WA) does not rule out spring spacers although there are limits to the amount ride height can be changed.
NCOP11 Section LS Suspension and Steering V2 01Jan2011
Depending on the amount of lift/drop required the spacers are often just thicker or thinner versions of the factory spring to body insulator. As long as the spring is still secure in the seat there should be no problems with rego.
Edited by ls2lxhatch, 13 January 2012 - 11:16 AM.
#35 _injlc304_
Posted 13 January 2012 - 12:25 PM
is that Australia wide of just state law?
Edited by injlc304, 13 January 2012 - 12:27 PM.
#36
Posted 13 January 2012 - 04:38 PM
You should start by giving the back part of the arch a love tap or two. This is the point at about 2oclock to 3oclock on your picture. If you are gentle and patient you will be able to move it quite a long way without hurting the paint. I did this to get the 275/50/15 drag radials to fit.
#37 _injlc304_
Posted 13 January 2012 - 05:33 PM
#38 _injlc304_
Posted 16 January 2012 - 05:06 PM
From this
to this
also fitted the 235 Mickey T's and they rub a bit
doesnt look too much like a 4x4 so im happy with that
think when the fronts get bald ill replace them with 175 60's instead of the 195 50's on atm to help lift the front up.
Edited by injlc304, 16 January 2012 - 05:09 PM.
#39
Posted 17 January 2012 - 06:42 AM
What offset (back space)rims have you got on the back?
#40 _injlc304_
Posted 17 January 2012 - 08:31 AM
Edited by injlc304, 17 January 2012 - 08:32 AM.
