Borg Warner strong enough?
#26 _hatch76_
Posted 16 February 2012 - 03:58 PM
If I was getting another one made I would get it done 20mm wider for clearance on the calipers as their close to the shockers. shits me because I asked them about it and rodtech said would clear easy.
The other thing is if you were running flairs, you could get some of those 20mm wider rear flairs and may not have to shorten the diff at all.
#27 _nos050_
Posted 26 February 2012 - 06:47 AM
#28 _troyboy74au_
Posted 01 March 2012 - 05:55 PM
I got my commodore diff cut down by Rodtech and was happy with the end result.
so what commodore diff did you use Daniel? was told to get VN/VP lsd. have been quoted $2200 to have it shortened (both sides) , new axles with HQ stud pattern fitted, and run whatever brakes.
#29
Posted 02 March 2012 - 08:50 AM
$770 for the borgy and $990 for a 9" with them suppling the housing,with the b/w you have to supply the housing
by the way dave..you have change your avatar..it's the city with drags now
Maybe, but it's still only baby drags!
Bring back the quarter!
#30 _hatch76_
Posted 04 March 2012 - 07:23 PM
I can't remember what model it came from, but I had it changed to HQ stud pattern, used the axles and commodore brakes. Bought new discs and purchased handbrake cables from a guy on Ebay that sells Torana to rear commodore disc conversion. All bolted up fine.so what commodore diff did you use Daniel? was told to get VN/VP lsd. have been quoted $2200 to have it shortened (both sides) , new axles with HQ stud pattern fitted, and run whatever brakes.
Edited by hatch76, 04 March 2012 - 07:23 PM.
#31 _robslxhatch_
Posted 05 March 2012 - 08:55 PM
