MSF are good to deal with on custom stuff.
http://msfracingcomp...ts.com.au/home/
They do some cool stuff it looks like..
Posted 30 May 2012 - 12:36 AM
Posted 30 May 2012 - 01:30 AM
They do a good job and unlike some of those Flee-Bay so called experts they know what they are doing. Their Watts, Sway-bars and floaters are all very good gear. They understand performance and handling which is what customers need when they ring for advice on what's best (not just sell what they have in stock). Far too many self appointed experts that simply don't deliver.thanks for uploading the link just ordered hubs from them. He took the time to talk things through explain whats been tried and what way to go about adapting my brembos to fit his hubs and what discs to try ect, unlike most other companies who only wanted to sell a complete kit.
and great prices
Posted 30 May 2012 - 01:10 PM
Posted 30 May 2012 - 03:47 PM
It's getting harder and harder now a days to find quality places to deal with, so that is really good to know a place is out there.
Posted 31 May 2012 - 06:37 PM
And I am going to go much bigger on my calipers soon as I get done loading containers now and have time to rest, ha ha...
I already tried on an 8 piston AMG Brembo caliper and it bolts straight on in place of my existing 4 piston Brembo's.
The caliper bracket I made was pretty straight forward and sure you could do a similar one as well. the Mercedes AMG SL55 rotor goes onto the hubs from the upc guy (who sells on ebay the brake kits) once you redrill them to Chev pattern (and open the center bore up slightly on the rotor.
Just doing all the working out of what to use was the hard part really for me...the actual fitting them on the car is really straight forward.
And my 360mm rotors fit my 18" wheels perfectly. Depending on what wheel you run though, you might have to watch caliper clearance.
Posted 31 May 2012 - 07:44 PM
Edited by ls2lxhatch, 31 May 2012 - 07:50 PM.
Posted 31 May 2012 - 08:24 PM
2005 MERCEDES-BENZ SL55 AMG 5.5L V8 Supercharged Part# 12035068 Weight 15 kg
Caliper SL55 8 pistion (Brembo). Weight 5.8 kg
Omg Thankyou so much ! So that's why you've used for the brembo 4 spots ?
Posted 31 May 2012 - 08:38 PM
Edited by ls2lxhatch, 31 May 2012 - 08:39 PM.
Posted 31 May 2012 - 09:35 PM
I do not have this setup. This information was posted by ls1hatch in another thread.
ls1hatch is now running the SL55 8 piston caliper.
Posted 01 June 2012 - 07:54 AM
Posted 01 June 2012 - 09:12 AM
Posted 01 June 2012 - 09:19 AM
Posted 01 June 2012 - 10:25 AM
Posted 01 June 2012 - 10:30 AM
Posted 01 June 2012 - 11:00 AM
Posted 01 June 2012 - 11:17 AM
Posted 03 June 2012 - 07:57 PM
If you were running custom wheel... you could always just have hubs made in Mercedes, etc bolt pattern and then run wheels to suit. Not like you are ever going to rotate tires front to rear obviously in most cases. (especially since most guys have wider wheels in the rear that is)
Then there would be no need to redrill them if that was an issue.
Being over here, anything goes.. ha ha...
Posted 03 June 2012 - 08:16 PM
Posted 03 June 2012 - 09:24 PM
Do you know where i can get discs from for the merc they want over 450 each in australia .
And freight from a few us sites are 160 for each disc which I thought was over priced ?
Posted 15 June 2012 - 06:38 PM
Posted 13 December 2015 - 06:31 PM
