Connecting up 2 batteries in boot
Posted 01 August 2012 - 06:33 PM
Some of you may know that im having some electrical issues with my 383 stroker.
I need to fit a 1200 CCA amp battery in my boot. However a 1200 CCA Odyssey battery is $750.
That’s allot on money to spend on a battery i believe.
I'm looking at other options and considering to fit 2 batteries instead. (600 CCA each)
Would both batteries give me 1200 cranking amps and does it put more load on the alternator if i connect up both batteries? What are the positives & negatives?
Thank You
#2 _Bomber Watson_
Posted 01 August 2012 - 06:38 PM
If you do it probably use a dual battery system like they use on fourbies.
Why on earth do you need 1200cfm though?? My landcruiser Diesel only has 720 lol.
Posted 01 August 2012 - 07:06 PM
#4 _CHOPPER_
Posted 01 August 2012 - 07:24 PM
Voltage Drop and Cable Size Calculator for ELV Solar Power Systems
Allowable Voltage Drop 1 % Run Length 2 m Current Demand 1000 A System Voltage 12 V Voltage Drop 0.06 mV/A.m Recommended Cable Size 70 mm2
#6 _CHOPPER_
Posted 01 August 2012 - 07:27 PM
Posted 01 August 2012 - 07:34 PM
Posted 01 August 2012 - 07:57 PM
You shouldn't need 1200cca
VE Commodore only has 600cca and they're in the boot.
#9 _CHOPPER_
Posted 01 August 2012 - 08:03 PM
Posted 01 August 2012 - 08:29 PM
The problem im having is my car starts up perfect but when i turn it off, its cranks very slow.
If i leave it for a few hours it will start up fine. I have had 3 electricians’ looks at it and they all reckon it’s the battery. When they jump start it, its starts first go. I recently had my starter tested and it was all ok. I’m using thick welding cables which i have sent and got the ends professionally pressed as well. All 3 electricians have tested the voltage drop form various positions and can’t find any problems.
So I guess to sort out whether it’s a battery problem or not, the cheapest way is to fit 2 batteries and see what happens.
#11 _Bomber Watson_
Posted 01 August 2012 - 08:31 PM
Posted 01 August 2012 - 08:34 PM
The one that i have now is actually a 660.
#13 _Bomber Watson_
Posted 01 August 2012 - 08:36 PM
Electrics make my head hurt.
Posted 01 August 2012 - 08:42 PM
#15 _Bomber Watson_
Posted 01 August 2012 - 08:43 PM
Most trucks run around 1200cca, just why i find it hard to believe you might require it.
Posted 01 August 2012 - 08:49 PM
I dont think i need the full 1200cca but i dunno. Im confused cause all three electricians said you need to double the power.
I am running 11:1 compression but surely that doesn't need 1200cca.
This is why i want to try 2 batteries, its allot cheaper than buying an odyssey battery.
#17 _Bomber Watson_
Posted 01 August 2012 - 08:53 PM
#18 _SLR Goat_
Posted 01 August 2012 - 08:57 PM
Posted 01 August 2012 - 08:59 PM
However i didn't go with it cause knowing my luck i get it and it probably still doesn't fix the problem.
Posted 01 August 2012 - 09:02 PM
#21 _SS Hatchback_
Posted 01 August 2012 - 09:20 PM
By what your saying it seems you cables and setup should be fine, anyway it worked for me as i was pulling my hair out too
#22
Posted 01 August 2012 - 09:28 PM
I have no thermos in mine so im fine there. I can’t find any anyone that would lend me there battery for the day that’s why i might just connect up 2 batteries and see what happens.
#23 _SS Hatchback_
Posted 01 August 2012 - 10:12 PM
Pity you cant ask a specialised battery place their thoughts and say can i return it if it doesnt help
#24 _torbirdie_
Posted 03 August 2012 - 12:00 AM
If jump starting it fixes your problem then there is your indication that fitting another battery in parallel will work.I agree, 1200 CCA is massive.
Have you posted this prob before.....or was this someone else.?
Did you get around to measuring what the voltage at the starter and the battery was when trying to crank it when it was hot?
Will you need a bigger alternator, probably not. Larger alternators are needed for larger electrical loads while you are running the car, so unless you have added a whole lot of accessories then standard alternator should suffice. A standard battery draws about 5 A when fully charged, so if you have two that doubles to 10 A, your alt should cope with another 5A.
What is important is that you don't fall for the folly of running a separate wire from the alt to the battery, leave the setup as it is with the alt wire going to the starter terminal
Edited by torbirdie, 03 August 2012 - 12:12 AM.
#25 _torbirdie_
Posted 03 August 2012 - 12:23 AM
Edited by torbirdie, 03 August 2012 - 12:24 AM.
