He did this when it was able to start and also when it was slow to crank.
I'm happy to actually measure the voltage myself and see what happens.
However I'm not the best wit electrical. If I can get som simple instructions would be great and rough reading on what each voltage should be.
Ok, a basic cheapo digital multimeter will do. Depending on what you are measuring use the 0-20V or 0-2V scale, DC( it will be labelled as such or have an underscore line and dotted line as a symbol, rather than the AC which has the symbol(~)
Attach the probles to the where you want the voltage to be measured.
From +ve to -ve of battery.
Should see ~ 12.6 V when battery is resting.
When cranking cold, given the size of the battery , would probably see somewhere from 10.5 - 11V when cranking.
It is the hot cranking(non start voltage) that should tell a story.
If the starter motor is overloading the system(either by short or by motor being hard to turn) we will see the voltage go much lower across the battery, possibly 8V or lower.
If it remains in the 10.5 - 11V range or higher it indicates that there is a problem with the connections within or to the starter, or that the starter windings have got so hot that their resistance increases and stops the starter from allowing enough current to create the necessary torque.
Also measure the voltage between +ve of starter and engine block for hot and cold cranking. These will be lower than at the battery, more than 1V diffence(to what you see at the batt) will point to problems with your leads/connections.
Edited by torbirdie, 10 October 2012 - 08:36 AM.
