This is Keithy's UC
#26
_Leakey_
Posted 07 March 2006 - 09:34 AM
Engine bay is awesome, really tidy, in fact I would go so far as
to say it is one of the nicest I have ever seen in a six cylinder UC.
The silver grey and black covers looks hot.
I think YELLA owes you an appology!! Probably thinking of a way
to explain that remark... come on Yella, say you're sorry!!
Well done Keith, as a member nearly twice your age, it is really
cool to see a young'n so in to cars like this.
Keep the pics comming.
Cheers, Leakey
#27
_Keithy's_UC_
Posted 07 March 2006 - 04:47 PM
I've got more pics, more detail too i suppose! I took a video of her running today! I still dont know how to post up links to video's yet...
Here's an 'updated' pic with all four wheels painted silver!
On my previous post you will note the bonnet latch is chrome, the brake booster has had a touch up, the ignition coil is remotely located on the lower engine bay panel and the lack of engine fan running off the belt!
I should post a current shot of the engine bay from the back and the sides also, its one of those things where detail has gone into all 360 degrees of the bay!
Keith
#28
_user asked to be removed_
Posted 07 March 2006 - 05:52 PM
#29
Posted 07 March 2006 - 08:17 PM
#30
_Keithy's_UC_
Posted 07 March 2006 - 08:22 PM
Keith
#31
Posted 07 March 2006 - 10:49 PM
When is it hitting the Dyno?
#32
_Keithy's_UC_
Posted 07 March 2006 - 11:26 PM
#33
Posted 07 March 2006 - 11:28 PM
#34
_Keithy's_UC_
Posted 08 March 2006 - 02:24 PM
#35
Posted 08 March 2006 - 05:47 PM
I cant wait to see it with the tripples on it!
#36
_Keithy's_UC_
Posted 08 March 2006 - 06:03 PM
It'll look hot with the triples!! I'm gonna polish them up before i get them fitted and tuned (then polish them after the tune)... Aiming for 170rwhp, which is achieveable! I'd settle for that! If i cant reach that, then the head's coming off for some more port work!! And a shave!
#37
_Eddie_
Posted 09 March 2006 - 07:30 PM
Anyway, not to take any credit away, it's all good all the same. I am doing up a 6 too so it's nice to see different variations. Nice work.
#38
_HatchmanSS76_
Posted 09 March 2006 - 08:18 PM
Can't help seeing a line from the movie copper everytime I see ya name
*Keithy's done himself a mischief* Sorry had to share it cracks me up
Don't do yourself a mischief and mess up the good work
#39
_Keithy's_UC_
Posted 10 March 2006 - 03:31 AM
I did a series of runs down the strip. I even posted my time slips in order of what run i did. I pulled off a few low 16's, couple of 15's and a 14.852 @ 95mph... It took a bit to get the right wheelspin to grip setting, and i played around with the timing and fuel/air mixtures a bit! Same deal with tyre pressures!
Next time it sees the drag strip it'll have triple SU's on there!
Cheers for the encouragement guys - 'Keithy appreciates it very muchly'!!
Keith
#40
_devilsadvocate_
Posted 10 March 2006 - 04:50 AM
Edited by devilsadvocate, 10 March 2006 - 04:55 AM.
#41
_Keithy's_UC_
Posted 22 March 2006 - 09:58 AM
I will be taking the UC to Townsville Mechanical Services within the next week for a Dyno Tune! I will post up the readout here, and also in the 'Expected Rear Wheel Horsepower' thread...
Stay tuned folks!
Keith
#42
_Keithy's_UC_
Posted 28 March 2006 - 06:22 PM
The average of the three runs was 96.3rwkW (about 130HP in old speak), and the highest of the three runs was 101.2rwkW, so roughly 135HP!!
Here's the average run printout!
It unfortunately doesnt say what rpm its at, but he said he took it up to about 6500rpm, max HP was at 5800rpm, so im pleased about that!
Keith
#43
_UCV80_
Posted 28 March 2006 - 06:46 PM
Im sure you will be pullin even more hp with ur tripples when they go on.
Cant wait to get a dyno reading and tune on my beast
,Nathan
#44
_Keithy's_UC_
Posted 24 April 2006 - 11:20 PM
I got bored people, so i will post up the 'final' spec list (current) of the goodies in my UC...
CAR:
UC Sunbird (no typing mistake there) 1980
VISUAL & INTERIOR:
PPG Galaxy Blue Pearl paint
14" X 7" Globe Bathurst rims with 225/60 Yokohama A509's all round
Darkest legal tint
Woodgrain steering wheel
Superplush Pebble Brown carpet (brand new)
3 gauges
- 5" Autometer Cobalt shift light tacho
- 2 1/8" Speco Oil Pressure (mechanical)
- 2 1/8" Speco Water Temp (mechanical)
Custom Blue dash lights
Cyclops Alarm/Immobiliser system
Pioneer 200watt head deck (mp3) with Kenwood 6" (door mounted) fronts and Kenwood 6" by 9" rears in custom parcel shelf, MTX Thunder 350watt Amplifier and MTX 12" Subwoofer
'Hidden' Ignition cut-off switch (used for cranking over to gain oil pressure and as a secondary anti-theft device)
Toggle switch activated Davies Craig thermo fans
ENGINE & DRIVELINE:
179 Red Motor (HP Block)
Bored to 186
Precision Hypatec Pistons
Starfire Rods
Steel Crank (factory fitment)
Lightened Flywheel
JP High Performance timing gears
JP High Volume oil pump
XU-1 Camshaft (big lift and long duration)
Brand new Electronic Ignition and NGK Iridium IX spark plugs
Top gun 10mm Leads
ACL Race Series bearings (all)
Rubber rear main seal
All parts were acid dipped and/or linished
Head - Shaved
- Ported
- Oversize Valves
- Double High Performance Valve Springs
- Grub Screwed (brand new) rocker studs
- ULP/LPG Valve seats
- Yella Terra Roller Rockers
202 Black pushrods
Standard lifters
Larry Perkins edition ACL Race Series Head Gasket
KC Alloy 'Black' Rocker Cover
Chrome side covers and oil pump cover
Pacemaker primaries into single hi-flow 2 1/4 exhaust (with chrome tip)
Painted Engine enamel 'Aluminium'
Runs 350 Holley (rebuilt) on polished CAIN manifold
10mm flexi fuel line
HV fuel pump
4 Speed manual with same custom LX tailshaft
3.08:1 Salisbury diff
Slotted Disc Brakes (Front)
Standard Drums (Rear)
Cam specs
Compression is 10.0:1
Note: same for intake and exhaust - all figures that is...
Duration - In & Ex 280
0.050 Duration - In & Ex 217
Cam lift - In & Ex 286
Valve lift - In & Ex 456
Lobe spread - 111
Edited by Keithy's_UC, 24 April 2006 - 11:25 PM.
#45
_UCV80_
Posted 25 April 2006 - 12:21 PM
Nice long list of goodies you have there, im getting excited about seeing it
cant wait to feel the power of another hot 6
there awsome engines lol
Goodwork! any future plans for her or him?
,Nathan
#46
_Keithy's_UC_
Posted 25 April 2006 - 07:02 PM
I've got to do the interior, which will be re-trimmed in VT SS Blue with UC embrioded in the seats, ill remove the spare wheel well and get a nice shiny 100L drop tank fitted and im gonna remove the 179HP in a month or so and get the engine bay re-sprayed in Subaru Brumby silver. To compliment that, im taking the chrome side plates off the 179 and putting black KC alloy ones on, the triple SU's will be getting rebuilt while the motor is out, the head will go in for a shave and more port work and im gonna make a custom alloy plenum for the triples.
I'm gonna gerni the undercarriage and spray it in black (its a daily driver so nothing fancy), paint my tailshaft and diff again then look into a custom boot install as well... I have a 12" subwoofer in there now, so im gonna do a custom install with the spare tyre sitting in a 'false floor' directly above the tank. The drop tank will sit low enough to fit the spare in there... Failing that ill just simply not run a spare tyre!
I'm gonna also get the bumpers professionally straightened and re-chromed/buffed! The exhaust from the diff will be 2 1/2" stainless and i have a secret custom UC tail light design on the cards too...
If thats not enough, i'm gonna have the word 'TORANA' airbrushed on the bonnet either side of the badge (i.e. TOR[]ANA). And a mural painted on the bonnet also.
If i've missed something, i sure as hell cant remember it!!
Keith
#47
_Keithy's_UC_
Posted 06 May 2006 - 06:04 PM
I arrived safely back from brisbane with only 2 small stone chips on my car :( , but thats cool cos my housemate's uncle is a spray painter...
Anyway, this is more of a photoshoot cos i was bored and thought about taking some photos of the car! As you do.....
Here they are (photos taken today)
Unfortunately my back seat didnt like the cargo on the trip down, and as a result i now have a few tears in the seat... Shame!
And YES i have my new GMH-TORANA sticker on the car, the other two small ones i have are in decision on where they should go yet!
Enjoy!
Keith
#48
_JBird_
Posted 07 May 2006 - 12:52 AM
#49
_Keithy's_UC_
Posted 07 May 2006 - 09:54 AM
I'll do a detailed write-up with plenty of pics!!
Keith
#50
_JBird_
Posted 07 May 2006 - 11:09 AM
