#126
Posted 25 March 2014 - 08:46 PM
At the moment I'm on crutches left leg in a splint. No work, no shed time, stuck on the couch.
As they say That's Life.Looking forward to you're updates.Maybe it's about time I start my own build thread .
Time is something I have at the moment for a change.
Cheers Graham .
#127
Posted 26 March 2014 - 07:39 PM
Yeah get into a build thread, always interesting to see what people have done or are working on.
Also Dave forgot to mention thanks for the kind words. I must admit I borrowed the update number method for my posts after reading Grants build thread. Using a numbering system makes it easy to find what you crapped on about if someone has a question or wants more info about a particular step in the build.
Steve
#128 _greg2240_
Posted 26 March 2014 - 09:33 PM
great project, whats with the chains on the engine crane etc?
#129
Posted 18 May 2014 - 08:22 AM
Hi Steve,
Getting close to start building my engine (so far still all body work!!) - are you still interested in sending a 161 mould so I too can go down the route of making an engine size thingy for my 3.3?
Cheers,
Neil
#130
Posted 04 June 2014 - 09:25 PM
Greg the chains are the second last line of defense for any would be low life thieves that manage to get into my shed. The last line of defense is my 12 gauge
Neil PM me re the 161 badge mould and we can work something out if your interested.
Update #25
It's been a bit of a tough summer. Having to shift my attention away from the car for a little while. Was also out of work for a couple of months and spent most of my time chasing jobs and agents and doing the long list of jobs around the house. Lack of cash flow didn't help.
Wasn't motivated to work on the car and when I had spare time the call of the sea was too much and took the boat out a couple of times instead. A good feed of fresh snapper and flatties is hard to beat.
A bit off the topic but I'm sure there are plenty of Torana freaks who love their boats too!
I received my door trims from Dash Original earlier in the year. They were the most expensive of all the reproducers but they did an amazing job. Thanks to Limo who supplied the fiberglass tops, Dash turned them around pretty quickly.
I was going to cut the rear trim around the wheel tubs myself, but Dash Original offered to custom make them if I supplied a template. I made a template around my modified wheel arch and floor pan / seat rail. I was a bit nervous receiving them to see if anything was lost in translation. The rear trims fit perfectly. I was wrapped. I omitted the handle holes from the rear trims as my floor is raised and they would most likely interfere with the seat base.
Front trims are spot on.
Got my ashtrays re chromed for the rear trims too. Look gold in the photos due to my fluro lights.
Before
After
The best pair of bonnet hinges I had were on the car when it was sandblasted by the previous owner so they appeared to be a bit pitted. One reputable re plater refused to do them and said I would be better off buying another set. I spent a few months watching eBay but all were more worn than my set.
I had my tail light surrounds done by Sterling Plating in Heidelberg Victoria. They were recommended to me by a fussy Ford freak (aren't they all) that said their work is of a high standard. I was very happy with the job on my tail light surrounds they were a bit pitted but re chromed ok. I showed him my hinges and he basically said yeah they may come out shit if they were sandblasted but let's give it a try, it was only $40 to zinc them. The hinges came out fantastic with no visible pitting. To say I was happy was an understatement.
That made up my mind to use Sterling for the rest of my plating. Started putting together a list of things to be zinced. Again was constrained by time and lazy to clean everything. I really should have hit everything with a wire brush but just dropped them off. They acid bath and clean them anyway. Everything came out brilliant. Only the bonnet catch didn't come out perfect, but it was a bit rough to begin with. Then my cat looking for food knocked it off the work bench to make matters worse. Luckily the spanner in my hands that was throw by sheer impulse didn't make contact with the poor cat or I would have had some explaining to do.
I took photos of all the bits to be dropped off and labeled the photos. Knowing me they might not get put together for a month or a year. Glad I did cause when I got back a big box of nuts and bolts it was like oh shit what goes where.
Look yellowish in the photos but that's just my fluro lights all are silver but I think the correct term is blue zinc. Got most of the items I needed zinced done. Below is just a subset of the photos as nuts and bolts are a bit boring to look at.
Before
After
Before
After
Before
After
Before
After
Before
After
Before
After
Before
After
Before
After
Put another coat of Holden Orange on the sump and a few spots that needed a second coat like the oil pump, didn't take any photos but came out nice.
Got into gear to finish all the front end painting with the KBS rust seal. No bubbling this time. Changed my brushes to some very soft and thin bristled brushes. They were actually sample pot brushes from Bunnings. They don't hold too much paint so easier to do a thin coat. Also have a feeling that last time when everything bubbled I may have shook the can or not stirred it properly. Did a final coat on all suspension arms and the front cross member and came out perfect.
Went to do the Kbs Blacktop top coat and the unopened tin had gone thick and gooey. Called KBS and the Blacktop particularly in satin has lots of solids in it. I basically have to use a strong paddle/stirrer and really get into it, give it a really good long mix and it should come good. Maybe a little thinner. Was also told the Blacktop in satin doesn't brush on too well it's better spayed or applied with a foam brush. That wasn't in any of the publications, If it comes out shit I'm giving up on it. The whole appeal of it to me was being able to brush it, and the product drying smooth with no visible brush marks. Will have everything sandblasted and just sprayed with acrylic satin if it looks crap after brushing.
If it works out its assembly time. Got all the ball joints and bushes and all the nuts and bolts are zinced so not far off if I can spend some time on it.
I gave up on Kbs for the rims, just sanded them back and painted them with satin black acrylic. Need one last coat then will get the tyres fitted.
Hopefully will be able to spend a bit of time finishing things off so I can get it rolling sooner rather than later.
#131
Posted 05 June 2014 - 09:48 AM
Glad to see you're back on track, plated parts look really good.
Our progects can be a real test of endurance sometimes,
Just keep living the dream.
Cheers Graham .
#132
Posted 05 June 2014 - 08:13 PM
Steve.
#133
Posted 05 June 2014 - 08:26 PM
Don't think she believes me.
All part of the challenge I suppose.
Cheers Graham .
#134
Posted 10 November 2014 - 08:12 PM
Been ages since I have posted.
Haven't done a heap of work but have been chipping away.
Financially I don't have any spare cash to finish her off as fast as I would like so that has dampened my enthusiasm a little. Now I'm keen to keep going with what parts I have, and get it in a state where it's ready for interior without having to spend too much money.
I have given up on the KBS route and ended up just giving all front end bits I already painted with KBS a once over with a scotchbrite pad and sprayed everything with a standard satin black acrylic. As mentioned previously my KBS Blacktop paint went solid in the sealed can, and after speaking with Kbs support it has a very short shelf life as it contains so much solids. You would however expect it to last at least 12 months! They also said the satin finish is best sprayed on not brushed as it can show the streaks and unevenness when brushed.
I found the whole Kbs process a real time waster and wouldn't go down that path again. It's probably okay for floor pans where you don't see it or if it's sprayed on. Having to re strip components and sand everything back because of gassing bubbles was a pain, and wasted a lot of time. Other bits I have cleaned up eg stub axels, sway bar, etc I have just hit them with a wire brush on the grinder, a good degrease and wash, then a quick prime and a couple of sprayed coats of acrylic satin black. All have turned out ok. It's going to be a driver not a show car so I'm not after a show quality finish.
I like the KBS degreaser and paint stripper but that is probably all I will use moving forward.
Finally got my grill and headlight surrounds back from Vinneys. Took a long, long, long time but it was worth the wait. Dents knocked out, broken bars re-welded and re plated. The finished product looks amazing and it's almost a shame that the center bar is going to be blue and most of the grill and surrounds black. I prefer the painted look over the raw look on GTR's so it will have to be done.
I got rid of my spare LJ Girlock calipers a while ago as I was going to go with LX disks and calipers I had on my old LJ. I remembered I had a set of XU1 caliper spacers and decided to go back to the Girlocks for authenticity. Found a grotty second hand set, cleaned up and pulled them apart to see if they are useable. Had plenty of years of grime and asbestos built up!
Hit them with the power wire brush on the outside then pulled them apart.
Had plenty of grunge inside the bores and a bit of surface rust but nothing dramatic. Definitely useable once they are cleaned inside and out, as the piston forms a seal against the piston and rubber seal not the bore. Even if the bores are a bit rough as long as I get new pistons, seals and O rings they will work perfectly (I hope).
I knew I had a set of XU1 spaces I don't even remember where I got them from but have been in storage for 20+ years. See pic below for difference between std caliper and XU1 bolts to go with the spacers. From what I read on this site you can get away using the short bolts with the spacers but I have a full set of long bolts so will use them.
I have a set of stubs that still had the factory daubs on them. Was in two minds about stripping them back and painting them, but they were pretty grubby and had some surface rust. I cleaned them as best as I could but they looked crappy and just to retain the daubs, it wasn't worth it. They weren't even the original ones on my GTR so I blitz them with the wire brush on the angle grinder in preparation for painting.
I'm focused on now finishing my front end, pushing in the bushes and getting it mounted and rolling. The front end chassis spacers were covered in electrical tape. I remembered doing that 25 odd years ago when I did a front end rebuild on my old LJ on a minimal budget. The tape was still in place but decided to fix them a little better. When peeling back the tape I remembered the grooves that were worn into them years ago because the plastic insulation wore through and the bolts must have been loose or something.
Thought the neatest way to replace that plastic coating would be with electrical heat shrink. Took one spacer to Jaycar and found the perfect heat shrink for them. Allowed me to shrink one full coat the entire length and a double covering on the ends. The second covering was a tight fit but got it on there and seems more durable than electrical tape. Won't be seen but I know it's done right.
The little piece in the photo is the factory coating and a double heat shrink is fairly close to that thickness.
So now with no spare money to spend on her for the next few months I will be doing everything I can with what parts I already have. Luckily I have a bit of a stock pile and have enough to finish the front end, then start sorting out things like the door lock mechanism assembly, stripping and painting the diff and arms, putting in the wiring harness, finishing the final coat of paint on the engine, etc. Bring on those hot summer nights, and spending hours in the shed with a few cold ales!
#135
Posted 13 July 2015 - 01:43 PM
#136
Posted 26 August 2015 - 07:58 AM
#137
Posted 30 August 2015 - 09:58 PM
I used boiling water and plenty of grease.My housing is powder coated so a real nightmare
trying not to scratch.But all good in the end.
Steering column looks great, nice shopping at Rears.
Cheers Graham.
#138
Posted 30 October 2015 - 11:21 AM
#139
Posted 30 October 2015 - 02:40 PM
#140 _LS2 Hatch_
Posted 03 November 2015 - 08:47 PM
Unfortunately Macka had to move his Mediterranean Blue LC on. I was lucky enough to be able to purchase the car.
Needless to say I am very interested in this build.
Can't wait to see it in the flesh and parking the two side by side
#141
Posted 04 November 2015 - 07:16 AM
Looking really nice.
#142
Posted 07 November 2015 - 12:24 AM
The car looks awesome, look forward to the next update.
I feel your pain with those bump stops, I had to do my front ones which are meant to be easier but they were still a hassle.
Rubber grease, some well directed brute force and a wide blade screwdriver did the job for me too.
But when your fingers feel like they are going to fall off and your thumbs can't grip anymore and the bump stop finally slips in you can't help but wonder why the hell couldn't you do that half an hour ago?
#143
Posted 09 November 2015 - 07:53 AM
Thanks guy's for the positive feedback really appreciate it!
Congrats Grant you scored yourself a beautiful car well done mate. Yes when mines on the road a catchup will be great, and will be nice to get some photo's side by side. They are both blue LC GTR's but also unique in their own ways.
Hey Potta yeah you hit the nail on the head with the bump stops. Frustrating but once they are in didn't seem that hard when the last attempt worked!
Have made some good progress since my last update, rear brakes done, handbrake cable connected, springs and shocks in, steering column in, front wheels (kind of) straight, 4 wheels bolted on. Ready to drop it off the stands in a couple of days, just need to put in the handbrake cable clips under the body (once I find them) and the boots that lead to the interior and bolt up the handbrake assembly. Then it's on the ground for now.
Started assembling the right hand door, both handle's on, lock in, regulator in, so getting there.
Will post a detailed update soon with pics and some issues I had.
Steve.
#144
Posted 13 November 2015 - 08:53 AM
#145
Posted 15 November 2015 - 12:54 AM
i would go the red centre caps, but the black ones look good too.
#146 _LS2 Hatch_
Posted 15 November 2015 - 06:43 AM
Black looks good, but the red does break it up.
Can you get a photo of both in the one photo.
This is a hard decision. Good thing is I don't think there will be a wrong one
#147
Posted 15 November 2015 - 07:48 AM
#148
Posted 16 November 2015 - 07:02 AM
Hey guy's thanks for the input yeah it's a hard choice, think I'm swaying toward the red but haven't decided yet. Will roll the car out in the sunlight soon and get a good side on shot.
Nstood, nah not worried I don't have the original GTR wiring loom, and won't be running the amp gauge. I'm probably going to just run an aftermarket volt gauge in the GTR dash instead. I did read a few posts in regards to that when I was researching which alternator to buy but didn't worry about it too much as didn't plan to use the amp gauge.
#149
Posted 07 January 2016 - 09:07 AM
#150
Posted 07 January 2016 - 12:36 PM
Also tagged with one or more of these keywords: Stevo, LC GTR, Phantom Grey, Tate, GTR
Holden Tech →
Electrical →
LC rear indicator screwsStarted by dacastle , 06 Apr 2024 LC GTR, indicator and 1 more... |
Holden Tech →
General Questions and Help →
TaillightsStarted by dacastle , 01 Apr 2024 taillights, LC, gtr |
Holden Tech →
Engine →
accelerator holesStarted by dacastle , 07 Dec 2022 accelerator, LC, GTR |
Holden Tech →
Engine →
2600N engineStarted by stealthxu1 , 28 Jul 2021 lc, gtr, nasco, engine, motor |
Members Area →
Members Projects & Plans →
The Sally ReportStarted by _The Handbrake_ , 23 Jun 2019 LC GTR, Restoration, 1971 and 2 more... |
