Understand Dave, but funny things would have happened back in the day, matter of fact they still do today. Last year we had a brand new X5 turn up at work that was a special order and took 6 months to arrive for the customer and it was a special trim order(white Dakota leather) only to turn up with standard Black leather. It then sat in the shed where I work out of getting changed over for 2 or so months.Dane, my feeling is if the dealer had ordered a car to be built with the optional 4spd box then the shifter hole in the floor pan would have been stamped in the normal 'D' shape during production.
I'm still leaning towards the Dealer having organised/performed most if not all of the ordered options themselves.
As has been said many times before, the Dealers would agree to almost anything to make a sale.
Dave.
XUI BODY IDENTENTIFICATION
#26 _sunburst73-xu1_
Posted 23 January 2013 - 07:05 PM
#27 _1973bathxu1_
Posted 23 January 2013 - 07:11 PM
i also rang a friend who has a 10/71 ck xu1, his car also has the 2 screws in the exelerater
ill try and get a photo for u
regards aldo
#28
Posted 23 January 2013 - 07:16 PM
john hi i looked at my 71 ck xu1 a 1 owner unrestored, after reading this thread and the exelerater is mounted on the floor with the 2 screws,
regards aldo
Could this be another Adelaide vs Brisbane thing?
#29 _1973bathxu1_
Posted 23 January 2013 - 07:22 PM
gongs ck is only a few cars away from mine on the assembly line
regards aldo
Edited by 1973bathxu1, 23 January 2013 - 07:23 PM.
#30 _LONA-CK_
Posted 23 January 2013 - 08:34 PM
back to the shifter thing it would have being cut buy the dealer has he would not of thought to change the cross member and that alone would make the aussie 4 speed hit on the floor with the original opel cross member.
you say you needed to rebuild the box a few time was it a jurkying to drive, was it the back sharft you needed to fix or re place each time, mabe using the wrong cross member was that problem all along.
cheers gong
#31
Posted 23 January 2013 - 09:41 PM
#32 _LC870_
Posted 23 January 2013 - 09:49 PM
With it being an LC S model there would not have been a hole or a stencilled hole in the first place. So could it be either 2 things,1 the factory cutting a hole in it after the shell was put together or 2 it was in fact sent to the dealer and the dealer done the change over?????As mentioned above, I have only seen factory D shaped shifter holes. cheers
This is not correct .
My Adelaide bulit LC S model was a factory column change automatic car.
There was also a D shaped hole in the tunnel covered by and plate with 4 screws.
Regards LC870
#33
Posted 23 January 2013 - 10:13 PM
WTF does CK bloody stand for???
CK is the XU1 186 engine prefix. C = LC Torana, K =186 ci.
Prior to the change to the CK prefix the LC XU1 186 ci engine prefix was 3100X.
#34
Posted 23 January 2013 - 10:16 PM
#35
Posted 24 January 2013 - 08:27 AM
The reason the box was out - 19years old - too harsh on the changes - syncro rings replaced twice - broken circlip and destroyed the main shaft.
Meroo149
#36 _LONA-CK_
Posted 25 January 2013 - 05:20 AM
has to the shift hole, its got me stumped then.
cheers gong
#37 _1973bathxu1_
Posted 25 January 2013 - 06:18 AM
regards aldo
#38 _L34 Hooon_
Posted 26 January 2013 - 07:51 PM
#39 _LONA-CK_
Posted 26 January 2013 - 08:26 PM
cheers gong
#40
Posted 27 January 2013 - 12:36 AM
Regards LC870
My LC 4 dr SL with 3 on the tree also has the D shaped hole with a plate over it.
I was hoping it might make it easier when I convert to manual.
Edited by Potta, 27 January 2013 - 12:36 AM.
#41 _1973bathxu1_
Posted 27 January 2013 - 06:35 AM
regards aldo
#42 _sunburst73-xu1_
Posted 27 January 2013 - 06:59 AM
Having said that I've seen plenty that hasn't either.This is not correct .
Regards LC870
#43
Posted 28 January 2013 - 12:54 AM
#44
Posted 29 January 2013 - 09:30 AM
Any help is appreciated.
It seems that they all had the floor mounted pedal.
Meroo149
#45 _LONA-CK_
Posted 29 January 2013 - 07:25 PM
5-73
a double skined 73 4cyl front floor what is now in my ck xu1 and please not that the 4cyl never ha the extra under guard supports like the 6 cyl had.
2-73
10-72
9-70
7-73
8-70
i can give you heaps more and unless they have being buchered they are the same, so i really dont know what you are tring to say.
cheers gong
Edited by LONA-CK, 29 January 2013 - 07:28 PM.
#46 _LONA-CK_
Posted 29 January 2013 - 07:59 PM
lc gtr floor but i think its being cut at some stage.
#47 _mikecatts_
Posted 29 January 2013 - 08:26 PM
#48 _boynuz_
Posted 30 January 2013 - 04:02 AM
#50 _1973bathxu1_
Posted 30 January 2013 - 06:10 AM
