Yeh it was yesterday it's back up today.
Future Tow Car
#26
Posted 04 June 2013 - 06:15 PM
#27
Posted 05 June 2013 - 09:14 PM
Just remember, these beasts only have a towing capacity of 1590 KG. Which isn't much when you consider most car trailers weigh around 600 KG.
That figure comes from Hayman Reece. That's the limit of their towbars. I'm sure it's also in one of my original manuals I have here.Where does that figure come from? I didn't think Holden stated tow capacities for vehicles of that era, leaving the maximum to the lesser of the tow coupling or the weight rule.
#28
Posted 06 June 2013 - 07:16 AM
Hey, if it moves... it's not overloaded!
#29 _Bomber Watson_
Posted 06 June 2013 - 08:16 PM
frOckin Kiwi's.
Bruce Highway is littered with the bastards towing there 9000ft caravans with a commy........
Edited by Bomber Watson, 06 June 2013 - 08:17 PM.
#30
Posted 22 July 2013 - 08:16 AM
I red an article in a magazine some time ago about moving the top control arm mounts on the chassis to get the cars to steer better, which I believe something similar was done to the Group C Camaro's in the late 70's early 80's. Can anyone shed some light on the subject?
#31
Posted 22 July 2013 - 08:39 AM
http://www.pozziraci...nsion_geome.htm
Not sure there is enough room on a full sized Holden to do this, maybe extended ball joints would work better.
#32 _Lazarus_
Posted 22 July 2013 - 09:03 PM
I've got a 27mm front swaybar and a solid mount Kmac rear swaybar with boxed lower control arms on the back of my sedan with 215s on 7" rims and it corners like it's on rails.
#33
Posted 23 July 2013 - 06:48 AM
I'm not sure, but I think the mount is moved back to increase caster, because in the story it mentioned that power steering will be definitely needed.
#34
Posted 23 July 2013 - 10:25 AM
If you have RTS caster isn't really an issue as the upper arms are already mounted further back for better caster, you can get plenty out of it and as GTR-U9X says they do handle fine (when set up properly).
#35 _Lazarus_
Posted 23 July 2013 - 08:44 PM
The panno had all urethane on the re-tempered leaves, and the sedan has rubber uppers and urethane lowers on the back.
Pretty happy with those set-ups, but if you drive alot on corrugated roads rubber is probably better to reduce the dreaded chassis cracking.
#36
Posted 24 July 2013 - 01:30 PM
I've got a mix of rubber and urethane in my HJs front, and all rubber out back, GTS 25mm front bar (no rear) and have watched many a kid in a jappa spin out in my rear view mirror... trying to keep up with me. I also boxed the rear trailing arms, surprising how much it changed doing that... and didn't cost me a cent.
