Chassis
#26
Posted 04 July 2006 - 01:53 AM
#27
Posted 04 July 2006 - 02:00 AM
if you dont need much, maybe you can notch it then sandwich a plate each side.
Edited by ALX76, 04 July 2006 - 02:09 AM.
#28
Posted 04 July 2006 - 11:32 AM
You cant modify your rocker covers a little by any chance?
Edit: how deep do you need to take the notches into the rails?
Edited by makka, 04 July 2006 - 11:33 AM.
#29 _doucmyuc_
Posted 04 July 2006 - 12:05 PM
what made you go with the infinity motor?
maybe if you showed your engineer those pics get him to design a way in which he will allow you to strengthen the rails.
but im thinking already you may have to add an extra beam inside the rail welded in and also boxing the holes your cutting as well as the front shassi strengthening kit.
go throw all your ideas at the engineer as hes the one who has the final say.
i stil think your going to have some problems with the exhaust manifolds and heat to the bushes and mounts
#30
Posted 04 July 2006 - 07:34 PM
Approx 10mm deep each sidethat rear notch will be the killer, the front one would be fine with a little plate to strengthen it. at least you have some room to strengthen that rear 1 above where you need to notch it.
And i cant really mod the rocker covers i dont think. I dont think it will leave enough room anyway if i do.
Im leaning towards low mounted motor (there is a limit to this of course) and modifying the cross member to make room for the sump.
I will see soon
#31
Posted 04 July 2006 - 09:18 PM
I may throw this one at the engineer also, even thow he wasnt keen on it.
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00242.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00241.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00240.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00239.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
Edited by Bart, 04 July 2006 - 09:21 PM.
#32
Posted 04 July 2006 - 09:38 PM
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P9100192.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P9100190.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P9100191.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
#33
Posted 04 July 2006 - 09:43 PM
#34
Posted 04 July 2006 - 09:51 PM
shave the rails and box them internally thru to the lower xmember point and beyond and u shouldnt have a problem. i know its overkill for your weight but it will be staunch.
#35 _LHoon_
Posted 04 July 2006 - 10:04 PM
Here's a few pics of my LJ which fits without chassis modifications.
#36
Posted 04 July 2006 - 10:14 PM
#37
Posted 04 July 2006 - 10:16 PM
How do you mean box them internally??i think youll find the rails in the blue torry have been reinfirced, not just shaven.
The way i had thought was to weld 3mm plate all over the outside length of the front rails down to the gearbox member after shaving down the rails.
Is this what you meant??
#38
Posted 04 July 2006 - 10:18 PM
I have but i wanted to be differentBart, have you considered a Lexus 4L?
Nice fit though mate, nice work
#39 _dannylxss_
Posted 04 July 2006 - 10:21 PM
#40
Posted 04 July 2006 - 10:23 PM
#41
Posted 04 July 2006 - 10:25 PM
#42
Posted 04 July 2006 - 10:30 PM
Ok.slice open the whole side and stitch in box section, then weld the plate your talken about back over the job. engineer approved first of cause.
Slice open, weld in 2mm wall square tube inside? is this what is boxing section? then plate over that?
Sorry just to be clear.
#43
Posted 05 July 2006 - 11:42 AM
#44
Posted 05 July 2006 - 02:29 PM
cross braces are also needed at the front (small, near rad) and another further back (see below)
note; you are going to loose a major crumple zone with this mod and suggest taking the RHS back as far as you can to link the rear suspension and cross brace at the gear box xmember, otherwise you may end up with a dash on your lap.
cheers.
Edited by ALX76, 05 July 2006 - 02:35 PM.
#45
Posted 05 July 2006 - 09:35 PM
Basically the narrowest part of the original rail is 45mm and the tallest part is 80mm
I tried the engine in from the bottom and its way too low so realy the only way is the cut the rails.
Have to shoot of some emails to the engineers. Do you think i should draw up some designs to prestent it to them in a more profosional way, kind of help convince them to go along with the idea, perhaps talk to a chassis builder and go with there engineer??
Edited by Bart, 05 July 2006 - 09:36 PM.
#46
Posted 05 July 2006 - 09:43 PM
this motor have senitmental value to you?
#47
Posted 05 July 2006 - 10:39 PM
I love a challenge i guess, the more i read about this motor the more i liked it over the years.
The motor is an engineering great i believe.
#48 _doucmyuc_
Posted 05 July 2006 - 11:00 PM
strong and realiable yes, potential hp yes, but out of the box their a touch sluggish.Sentimental, maybe
However i have a neighbour who threw one in a hq or hz ute a few years back, ill ask him how he went baout htings for you
#49
Posted 05 July 2006 - 11:17 PM
This placing it over the car as normal
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00244.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00247.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
Engine too bloody low
This is when i tried to go from under the car
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00260.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00263.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00264.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00265.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00266.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
#50
Posted 05 July 2006 - 11:50 PM
Dont laugh i got out my crayons lol
Hope it comes out clearly
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/Scan0001.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
Edited by Bart, 05 July 2006 - 11:54 PM.
