lj 202 ratio?
#1 _datpsi_
Posted 07 January 2014 - 10:10 AM
Posted 07 January 2014 - 04:42 PM
#3 _datpsi_
Posted 07 January 2014 - 10:22 PM
genuinely curious to what the old girl Can do
Edited by datpsi, 07 January 2014 - 10:23 PM.
Posted 07 January 2014 - 10:27 PM
But he has 9inch with 3.9 lsd
Posted 07 January 2014 - 10:34 PM
Depends on tyre size
I used to run 3.9's in mine
As for front runners... if your running radial rears you should stick with radial fronts
If your running rags on the back... same on the front
However probably not needed unless you think your in the 11 second or faster bracket... even then not mandatory
#6 _datpsi_
Posted 07 January 2014 - 11:54 PM
Being a historic only running 205 60 13 atm..
Posted 08 January 2014 - 12:02 AM
On the back i mean
Posted 08 January 2014 - 12:11 AM
Posted 08 January 2014 - 12:15 AM
Posted 08 January 2014 - 07:58 AM
3.55 gears should get you crossing the line just short of 6000rpm(I imagine that the engine would be able to rev harder), so 3.9 gears would be better if you have them, otherwise "run what you brung" & have fun. Remember to pump the fronts up hard if you haven't got any skinny tyres.
#11 _datpsi_
Posted 08 January 2014 - 10:20 AM
Maybe we'll be able give couple the v8s some trouble
Posted 08 January 2014 - 05:12 PM
Yes, pump the fronts up hard, you don't want them to slow you down.
Posted 08 January 2014 - 08:32 PM
I found semi slicks hard to burn off the line. I had Nolethane rear end but. It just wanted to hop away.
#14 _datpsi_
Posted 08 January 2014 - 08:54 PM
Posted 09 January 2014 - 07:53 AM
My LJ is 1202kg, with me in it, so if you can get the traction off the line, 12s are doable.
#16 _datpsi_
Posted 09 January 2014 - 12:40 PM
