Lh slr 5000 full restoration
156 replies to this topic
#51 hanra
  • 11,021 posts
Posted 04 March 2014 - 02:44 PM
Are those spring locators/mounts normally just chopped off the old banjo housing that gets pulled out and then welded to the 9in housing?
#52 arrimar
arrimar
  • 3,134 posts
Posted 04 March 2014 - 03:13 PM
In my experience yes.
#53 hanra
  • 11,021 posts
Posted 04 March 2014 - 03:17 PM
So not all is lost, the OP could just lop off the mounts from his old diff and get them welded to this 9in, may need a new paint job though... bugger...
#54 _LHSL308_
_LHSL308_
Posted 04 March 2014 - 03:56 PM
I hope he still has it I am pretty sure he had it for sale.
#55 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 05 March 2014 - 07:37 PM
Luv the project. Nice work!
#56 _parsons5000_
_parsons5000_
Posted 07 March 2014 - 01:18 PM
Hey guys fitted wheels and here I have a 6 inch convo with 185/65/15 and it just touches bottom edge of guard . Would a 175/75/15 fit ? I wanna fill as much rubber in
Rear
#57 _parsons5000_
_parsons5000_
Posted 07 March 2014 - 01:22 PM
Rear height I want lower
Under diff
#58 hanra
  • 11,021 posts
Posted 07 March 2014 - 03:06 PM
How did you go with the rear spring locator/mounts?
#59 _parsons5000_
_parsons5000_
Posted 07 March 2014 - 04:00 PM
They are fine there is a groove built on it diff builder has said it's been done right
#60 _parsons5000_
_parsons5000_
Posted 08 March 2014 - 04:17 PM
Hey guys I'm thinking maybe running a 17 inch front with a 15 inch rear , how would this look ? Weird or good ?
#61 Ice
  • 15,213 posts
Posted 08 March 2014 - 04:22 PM
Why ryan
#62 _parsons5000_
_parsons5000_
Posted 08 March 2014 - 04:43 PM
Fill the front gaurd and make it look lower at the rear
#63 _A9XONE_
_A9XONE_
Posted 08 March 2014 - 05:47 PM
Great job,looks like my old 5000! :clappin:
#64 _LHSL308_
_LHSL308_
Posted 08 March 2014 - 06:03 PM
You want to put a bigger diameter rim on the front but dont you have a rubbing issue?
#65 _parsons5000_
_parsons5000_
Posted 08 March 2014 - 07:21 PM
It is all about backspace on wheels that allows room , my backspace is 3.3/8 ATM but if I get a 4.5 backspace a bigger wheel should fit
#66 _LHSL308_
_LHSL308_
Posted 08 March 2014 - 08:33 PM
Understand why you want to fill in the guards but unless you modify the guards you can only fit a certain diameter tyre. I can tell you the maximum diameter as I had the same problem.
You can only fit a total diameter size tyre of 23.5 inches. I have 195/55/15's on the front which are 23.44 inch in diameter. These only clear the front bottom of the guard by about 5-10mm. You can use this guide to help you choose a suitable tyre size that wont give you any rubbing issues when turning the steering.
http://www.jekylhyde...ightofTires.htm
Edited by LHSL308, 08 March 2014 - 08:38 PM.
#67 _parsons5000_
_parsons5000_
Posted 09 March 2014 - 09:37 AM
Seats done
Fronts :)
Fronts :)
#68 _parsons5000_
_parsons5000_
Posted 11 March 2014 - 02:05 PM
new tires fitted
front
just clears :)
lower it hopefully a lil at the front and alot at the back :)
#69 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 11 March 2014 - 07:33 PM
Great wheel choice.  What size and offest are they?  Hoping the fronts don't catch the guards when you lower it like mine used to...
#70 _parsons5000_
_parsons5000_
Posted 11 March 2014 - 08:15 PM
Convo pro 6 inch front 3 3/8 backspace with 185/55/15 should be ok
#71 _LHSL308_
_LHSL308_
Posted 11 March 2014 - 09:33 PM
Your welcome Ryan.
#72 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 12 March 2014 - 11:25 AM
Mine were 6" with 3 1/2 in backspace, 195/60 tryes and they grabbed the guards on lock when reversing or going up driveway gutters.  Hence me changing them.  Maybe you will be ok with the lowver profile and skinnier tyres.  Would hate to see you bend newly painted guards.  I would cry for you LOL...
#73 _parsons5000_
_parsons5000_
Posted 05 April 2014 - 08:58 AM
got the car back home finally , just cleaning her up then start wiring and putting her back together ,
side
need the rear springs compressed lower
#74 Shiney005
  • 9,731 posts
Posted 05 April 2014 - 09:40 AM
G,day Ryan, Love your work mate. Looks awesome. Can you tell me what the Harrop arms off the stub axles change?
#75 _parsons5000_
_parsons5000_
Posted 05 April 2014 - 09:48 AM
Helps when u do the hq stubs from torana stubs , helps with less bump steer , so if u are going to upgrade your brakes these harrop arms are a must
