lj 2 door rebuild
200 replies to this topic
#76 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 01 September 2014 - 10:01 AM
Hi James,
Great colour choice.My first lj was Purr Pull loved it ever since ,so 70's.
Keep up the good work, always great seeing another lj getting back on the road.
Cheers Graham .
#77 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 01 September 2014 - 12:27 PM
James...
Make sure that you brace/tack/weld on some bracing in your door frame before you do ANY work on the sill/floor area,,To keep in position or it WILL move.. look through my build threads.. Their are some pics there some where..
Mike
Thanks Mike I have just seen your bracing so I will weld some in tonight before i cut anymore off
And thanks for the thoughts Graham do you have any pics of your Purr Pull Lj
#78 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 01 September 2014 - 08:14 PM
After-work today was able to spend a bit of time on the Torana with Dad
I made up some bracing and welded it in (thanks Mike) hope this is enough to stop anything moving when
I cut out the floor and inner sill.
The car has had a replacement floor before however it was overlapped and not But welded
You can see the rust in between the overlaps.
I took a few more pics of the LHS inner sill and floor corner not flash. and Dad took a couple of me
#79 N/A-PWR
  • 9,644 posts
Posted 01 September 2014 - 08:27 PM
Mate that is a lot of work done James,
not sure if you need a 'X' stay from side to side too,
like from the drivers door opening top,
to the passenger door opening bottom, and vise versa.
Mike will be around to say.
in any case, you look happy.   :spoton:
#80 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 01 September 2014 - 08:30 PM
Thanks Dave never thought about that hopefully Mike will let me know
James
#81 _LONA-CK_
_LONA-CK_
Posted 02 September 2014 - 07:23 AM
hi mate you need a brace from middle of the gear box tunnel to the pillar you are cutting out near, as there is more a chance that your A-pillar will twist in, rather then lay back,,,
and most of all i would be fixing the inner sill first that way you have the floor part to line up with, once you replace the inner sill dont weld to the floor pan, then move your brace so it hankers from drivers pillar to passengers pillar and one from passengers pillar to upper drivers side roof,, this would be over kill but better to be safe, then cut out floor pan,,,, sorry i dont have time for pics atm
cheers gong
Edited by LONA-CK, 02 September 2014 - 07:25 AM.
#82 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 02 September 2014 - 09:16 AM
cheers gong
Thanks John I will do that after work today and will definitely follow the replacement order of sill then floor
James
#83 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 09 September 2014 - 10:01 AM
Mikecatts you are a legend
Thanks ever so much for the parcel I received today.
It is people like you that make this forum the best place to get help and information
I can not thank you enough for the assistance and effort that you have gone to to help a young Torana mad pup .
I have not done much on the car this week as we have been flat out at work, roll on the weekend as I will be attempting some fabrication work.
:D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D
#84 _LONA-CK_
_LONA-CK_
Posted 13 November 2014 - 04:02 AM
where are you at with this car mate
cheers gong
#85 Potta
Posted 20 November 2014 - 11:46 PM
He's bought some sprinty's for it, I know that.
I had the pleasure of meeting James and his Dad and they are both top blokes.
I can tell this is going to be a really great build too.
Hope your Dad is doing well James, he certainly loves his Toranas which makes him alright in my book :-)
#86 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 15 February 2015 - 11:00 PM
Hi everyone I have not had a lot of time lately to work on the car with work commitments and helping Dad Drill on the weekends
Anyway was able to do a bit of work on theTorana this weekend with Dad.
We removed the passenger side front guard to allow better access to the A pillar rust, the inner guard looks pretty good will strip back and make sure that there are no hidden nasties.
We did a rough fit up of the outer sill panel to see what it would be like and it looks not too bad.
I have been reading all the forum stuff that I can to learn as much as I can and it was great to meet Potta (Craig) top bloke who sold me some great rims.
#87 _mikecatts_
_mikecatts_
Posted 16 February 2015 - 06:33 AM
howd u go with the inner floor seals?
Mike
#88 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 16 February 2015 - 07:42 AM
Good to see another Purr Pull LJ!
Keep it up bud.
#89 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 16 February 2015 - 08:56 AM
Hi Mike they were fun and I couldn’t have done them without your help
Thanks once again
#90 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
Posted 16 February 2015 - 10:27 AM
Click on the picture in my signature if you want some inspiration :)
#91 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 16 February 2015 - 12:56 PM
Hi Tim your car looks great
Im just on a break from TAFE so was good to have a read
#92 _fractalign_
_fractalign_
Posted 19 February 2015 - 09:47 AM
 I was complaining about the condition of mine until I saw your thread. All I can say is that what I have seen so far is a the dedication to do the job properly the first time on a project that many would have given up on. Good work and I look forward to seeing the final result.
#93 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 19 February 2015 - 10:32 AM
Hi Robert thanks for the kind words.
Hopefully it turns out ok I am getting lots of advice and ideas from forum member’s nice to see people who will help a young pup as my dad calls me.
Looking forward to the weekend and getting some more done.
#94 Potta
Posted 19 February 2015 - 10:49 AM
Keep going James, you're doing a great job.
This is going to be a great car, I can tell you're the kind of guy who does things properly and isn't scared of a challenge.
#95 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 19 February 2015 - 10:54 AM
Thanks Craig, it was a bit scary cutting the guard off
I've been following your thread best of luck at the pits you should be fine as you have covered all the things picked first time
#96 Potta
Posted 19 February 2015 - 10:56 AM
Thanks mate.
Should be all good as long as she'll steer in a straight line.
Thanks for buying those wheels too, the extra $ was a big help in getting it to where it is.
#97 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 21 February 2015 - 03:47 PM
Having a good morning working on the car with dad
Decided to replace the radiator support panel and the front valence
A few pics of the progress to date.
#98 Ice
  • 15,218 posts
Posted 21 February 2015 - 04:09 PM
Bloody hell big job you,ve taken on you go son do it once di it right
keep up the good work James
#99 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 21 February 2015 - 04:16 PM
Thanks Gene
#100 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 21 February 2015 - 05:47 PM
Does anyone have a left and right hand side inner front section that they don't need
