Shuddering problem.
#1 _73LJWhiteSL_
Posted 16 July 2006 - 09:54 PM
I have this problem with the brakes on the Torana at the moment, that sometimes when i put my foot on the brakes, i get a shuddering feeling and vibration that travels up the steering wheel. However it doesn't happen all the time...
Any ideas?
Steve
#2 _LX8VD69_
Posted 16 July 2006 - 10:07 PM
#3 _munro_
Posted 16 July 2006 - 10:41 PM
#4 _73LJWhiteSL_
Posted 17 July 2006 - 12:13 PM
I have never replaced the wheel bearings i guess i could look into that.
thanks for the suggestions guys... i will have a look at it.
Steve
#5 _lx5008_
Posted 17 July 2006 - 12:35 PM
you can tell buy the hot spots on the rotor its self in between the slots.
#6 _73LJWhiteSL_
Posted 17 July 2006 - 01:09 PM
I got the rotors from dattoman back last year sometime. Not sure of the brand.
Steve
#7 _lx5008_
Posted 17 July 2006 - 01:17 PM
at them. can you also hear a noise when they shudder.
best thing is just check any bluey type colour marks between the slots
cheers graham
#8 _73LJWhiteSL_
Posted 24 July 2006 - 02:52 PM
I pulled the wheels off and had a look at the rotors. They looked fine, no marks of any kind i could see other than the usual cirular marks from the pads.
So i pulled the pads out. Well well well... the anti squeal shims on the drivers side were backwards. I scuffed the pads up on the concrete and took it for a drive to 'bed' the pads in again. It doesn't appear to be shuddering anymore, but i will see how we go over the next few weeks.
Steve
#9 _timbotorrie_
Posted 24 July 2006 - 06:50 PM
#10 _73LJWhiteSL_
Posted 05 November 2006 - 01:14 PM
sorry to dig up such and old post, but its taken me this long to find the time to actually check the brakes out.
According to the little gauge I borrowed off my mate, my discs have 0.4mm run out. Well the drivers one does at least. This was all i bothered to measure.
So that answers it. My 12 month old, 20,000 Mile old, disc rotars are warped. I have no idea how this has happened, as they started doing it long before i took them to a race track.
Steve
Edited by 73LJWhiteSL, 05 November 2006 - 01:24 PM.
Posted 05 November 2006 - 08:40 PM
Runout could be in the bearings or vibrations can be could be suspension related.
Since you have checked and found a .4mm runout I'd suggest youreplace the bearings. Have the discs then very lightly skimmed whilst attatched to the hubs (on the new cones) and refit
While its apart I'd be checking the pistons in the calipers are free and retracting properly
Solid rotors are not kangaroo paw by the way..... only vented could be as KP is a vent and pillar design
DBA make KP not PBR
Those 2 statements refer to previous posts made mid year (my first read of this thread)
#12 _73LJWhiteSL_
Posted 08 November 2006 - 08:07 PM
As best I can tell from my records it appears the front bearings have never been changed and the car has just clocked over 120,000 miles. I think i might just take the rotars in to get machined and stick new bearings in as you have suggested. And get the calipers checked out or maybe just rebuilt.
Steve
#13 _Oldn64_
Posted 08 November 2006 - 09:36 PM
#14 _CHOPPER_
Posted 08 November 2006 - 10:40 PM
Edited by CHOPPER, 08 November 2006 - 10:40 PM.
Posted 09 November 2006 - 05:22 PM
Cheer
Stedz
#16 _CHOPPER_
Posted 09 November 2006 - 07:46 PM
#17 _keith1962_
Posted 09 November 2006 - 09:28 PM
Could it be the shocks????????????
cheers Keith
Posted 09 November 2006 - 09:40 PM
Posted 10 November 2006 - 01:01 AM
No-one said they didn't get runoutI disagree that disc rarely get run out! I work in a place where 60% of our work is brake n clutch n id say every second falcon n commodore has run out in the rotors, major shudder/pulsation jus my 2cents worth from experience!
Cheer
Stedz
I said they rarely warped
Which is true
What your seeing on a regular basis Stedz is DTV
Which as you know on the Falcons is usually caused by the grease seal not being seated properly on the EA-EL models
And the bearings having angular float on the VS-VX Commodores due to the inner and outer cones of the sealed units being a mere 17mm apart and the tolerances between a new and worn bearing only being
NEW BEARING 0.106mm (0.0042�) MAXIMUM
USED BEARING 0.213 mm (0.0085�) MAXIMUM
And what shits me the most is people using rattleguns to do up wheelnuts
They should only be done by hand and prefferably with a torque wrench. Especially on cars fitted with alloy wheels
Gungy calipers and wrong spec pads can also result in DTV
Re warped discs
This is the best article I have seen on the matter http://www.stoptech....brakedisk.shtml
#20 _CHOPPER_
Posted 10 November 2006 - 04:44 PM
#21 _73LJWhiteSL_
Posted 10 November 2006 - 04:53 PM
I never claimed to have KP rotors mate, i if you double check the posts above, you see some people suggested i have KP rotors.Also as Neil has pointed out You do not have KP rotors Steve.
Hi guy's
cheers Keith
I'm running Koni Adjustable shockers which were only installed a few years ago, so i should hope its not shocks.
rack or tyre pressure?
Steering rack was replaced only a year or two ago. I always run 36psi all round, and i haven't changed the tyre preasure since the shuddering started.
HELL YEAH!
All four of my Sprintmasters have big divets down the sides from rattle guns, and all the shinny coating on my wheel nuts is chipped and falling off. I tell places that replace my tyres not to use rattle guns.
Thanks for the link Neil, quite interesting reading....
"...Ideally, in order to avoid either putting up with squealing brakes that will not stop the car well around town or with pad fade on the track or coming down the mountain at speed, we should change pads before indulging in vigorous automotive exercise. No one does..."
Steve
#22
Posted 10 November 2006 - 07:27 PM
you cannot rule anything out till you have actually checked it for wear.
#23 _Oldn64_
Posted 10 November 2006 - 08:12 PM
I did not state you had KP rotor nor did I infer that you stated you had KP rotors, but you where looking for colour temperature dots which are only on KP rotors hence my comment, ie dont look for them as you do nto have them, is that better instructions? remember I have worked bloody hard this week. I know you know how that feels after last night but tack on two other sites which had similar results.I never claimed to have KP rotors mate, i if you double check the posts above, you see some people suggested i have KP rotors.Also as Neil has pointed out You do not have KP rotors Steve.
Ummm, not strictly true. I always change my pads and shoes as well as my fluid before all events. I have encouraged many to do the same but they have not seen the need for it yet. AT the end of teh day the car could run like crap and not perform all day, but you can still have fun, running around without brakes, tends to destroy ones day quite quickly.
#24 _73LJWhiteSL_
Posted 13 November 2006 - 03:32 PM
I have had the discs machined, and replaced both front wheel bearings.
The wheel sometimes wobbles side to side slowly under brakes, but it doesn't seem to do it when just driving. It seems strange that it doesn't do it all the time. I';m guessing maybe suspension bushes or something?
Steve
Edited by 73LJWhiteSL, 13 November 2006 - 03:34 PM.
#25 _CHOPPER_
Posted 13 November 2006 - 07:16 PM
