Is this a disassemble most of front suspension job Chopper?
hmm fun with bushes
Steve
Shuddering problem.
_73LJWhiteSL_
, Jul 16 2006 09:54 PM
29 replies to this topic
#26 _73LJWhiteSL_
Posted 18 November 2006 - 10:43 AM
#27
Posted 18 November 2006 - 12:47 PM
Id also check tie rod's and rack ends for movement can also lead to this problem
Understand wat u mean datto thanks for the pull up on that one cheers
#28 _CHOPPER_
Posted 18 November 2006 - 02:34 PM
Never done it on an LJ. Hopefully undo the nuts at both ends and it should slide out. A hammer may be required.Is this a disassemble most of front suspension job Chopper?
hmm fun with bushes
Steve
#29 _73LJWhiteSL_
Posted 20 November 2006 - 11:16 PM
Chopper, i have the LC Workshop manaul here in front of me and i can't find the caster bar. I am not familiar with the names of all the front suspension componets, but is the think you are calling the caster bar also called the control rod?
The thing that is bolted to the lower control arm between the stub axel and the spring and goes back to the crossmember brace? You mean the bushes and tub through the crossmember brace need replacing?
Steve
Steve
Edited by 73LJWhiteSL, 20 November 2006 - 11:18 PM.
#30 _CHOPPER_
Posted 21 November 2006 - 04:15 PM
That's the one. The biggest problem I found with them is the crush tube is missing. This can lead to excesive loads on the bar. Do that to an XR - XF Foulcan and they can break. I've replaced the broken ones, so I know it can happen.
